April 11th, 2012, 10:32 AM | #1 |
Join Date: Mar 2012 Motorcycle(s): '09 Ninja 250r Posts: 9
Slip on exhaust?
I was possibly looking into a slip on exhaust, for safety reasons and simply because it sounds better. I have heard many people say that you should shim the needles or rejet your carburetor even with just a slip on rather than a full system. However, I have only done body work on my motorcycle and have very little experience with carburetors. Is this absolutely necessary, and if so, is it a simple DIY job?
April 11th, 2012, 10:38 AM | #2 |
If all your doing is adding a slip on, then you should be able to get away with just shimming. And yes, it's a simple job that only takes about 30-40 mins following this DIY; http://www.ninjette.org/forums/showt...=diy+shim+carb
The hardest part is getting the screws out of the carb caps without stripping them. Have your non phillips replacements handy before you do the job.
April 11th, 2012, 10:40 AM | #3 |
The number of washers you might need is a bike specific thing. Some are happy with 3, others like 4 and some don't like any. lol
Slip-On Exhaust | Mrudloff | 1986 - 2007 Ninja 250R Tech Talk | 8 | October 11th, 2014 01:19 PM |
How to remove stock exhaust and install aftermarket Slip-On Exhaust System Ninja 300 | SON1C | 2013 - 2017 Ninja 300 Tech Talk | 4 | August 14th, 2014 05:45 PM |
slip on exhaust? | NinjaLINY | 2008 - 2012 Ninja 250R Tech Talk | 7 | April 30th, 2014 07:00 AM |
Looking for a Slip-on exhaust? | mariorivera830 | 2008 - 2012 Ninja 250R Tech Talk | 32 | August 26th, 2012 01:16 PM |
what slip on exhaust | bandit_fosky | 2008 - 2012 Ninja 250R Tech Talk | 14 | July 30th, 2012 07:13 PM |
