Old July 26th, 2015, 01:32 PM   #1
MattyJamm
Motorcycle(s): 2012 Ninja 250
Ticking noise... at lean angle?
So this is a strange one.. I went out on a fairly long ride yesterday (~3-4 hours total) and after a couple hours in I noticed an unfamiliar grinding/rubbing/ticking noise. Even more odd is I could only seem to create it when at lean angle to the LEFT side. Leaning to the right it would stop.
I noticed it again today at much lower speeds, and it was more clearly a ticking sound than a grinding sound. Again I could only consistently create it when leaning left. A couple times I may have noticed it when up right, but never when leaned to the right.
It's coming from the front-ish, and if I pull the clutch in it stops.
Bike is a 2012 Ninja 250 with 7500 km (4700 mi). Has anyone ever experienced anything like this?
MattyJamm is offline   Reply With Quote
Old July 26th, 2015, 03:41 PM   #2
dcj13
Participant
dcj13's Avatar
Motorcycle(s): '94 K75 std
Welcome, Matt!
Interesting observation... I have no clue what to think. It goes away when the clutch is in... Hmmm.
If you coast down a hill in neutral with the engine off and go around a left turn, will it make the noise? Or engine off, but in gear with the clutch handle pulled in (disengaged clutch)?
Old July 26th, 2015, 04:22 PM   #3
Kevin1956
Kevin1956's Avatar
Loose chain rubbing against countershaft sprocket cover, swing arm or chain guard?
Kevin1956 is offline   Reply With Quote
Old July 26th, 2015, 05:11 PM   #4
MattyJamm
Originally Posted by dcj13 View Post
Welcome, Matt!
Will have to try that. I should also try giving some throttle while in neutral during a turn.
Old July 26th, 2015, 05:13 PM   #5
MattyJamm
Wouldn't the chain rub regardless of me being in gear or not?
Old July 26th, 2015, 09:19 PM   #6
greg737
Motorcycle(s): -
Maybe it's oil related.
Maybe gravity is affecting how the oil is distributed within the cylinder head: Like where the oil flows, or maybe it changes where it pools inside the cylinder head. You could have a valve that's making noise when the oil flows away from it in a left turn, or maybe the right-hand end bearing of the camshaft.
Or maybe the issue is in the engine's sump, at the oil pump or its plumbing. Maybe the oil pump is cavitating when you lean left. Low oil quantity?
Just guessing.
Old July 27th, 2015, 08:16 AM   #7
Check the oil first. Then figure out if it is in motion or not in motion. Get a helper, start the bike lean it over by hand and see if the sound is there. Gut tells me though, if it goes away when you pull the clutch, then it must be mechanical. Just a feelin'...
Last futzed with by csmith12; July 27th, 2015 at 10:00 AM.
Old July 27th, 2015, 10:41 AM   #8
I would say something (rock, screw) stuck in the front tire, except that you said it stopped when you pulled-in the clutch. - which would make it engine/drivetrain related.
Old July 27th, 2015, 12:46 PM   #9
I'd try better earplugs.
Old July 27th, 2015, 01:44 PM   #10
what kind of noise does it make during a 12'oclock wheely?
Old July 27th, 2015, 04:20 PM   #11
MattyJamm
BRB, learning to wheelie a Ninja 250
Old July 27th, 2015, 05:43 PM   #12
if you can wheelie a 50cc, you can wheelie a 250cc
you just gotta put your legs into it.
Old July 28th, 2015, 06:56 AM   #13
accumack
accumack's Avatar
Motorcycle(s): honda crf230l & 2013 ninja 300se wife has Honda crf230l & honda cbr250r repsol
Check your wheel bearings, look for tight links in the chain.
accumack is offline   Reply With Quote
Old July 29th, 2015, 10:21 AM   #14
akima
Nooblet
akima's Avatar
MOTM - Oct '13
Glad I wasn't drinking something when I read that. You made me LOL
Old July 31st, 2015, 10:41 AM   #15
MattyJamm
I finally realised the noise is just something vibrating/rubbing under my fairing. When my leg is hugging the left tank/fairing (pretty much any time I'm not making a left turn) it dampens the noise. And when I stop pressing my leg against the left tank/fairing (when I make a left turn) it becomes audible again. So I'm not completely crazy, it was indirectly related to left turns
Old July 31st, 2015, 10:57 AM   #16
Panda
not an actual panda
Not everyone is a born ambiturner.
Old August 13th, 2015, 01:18 PM   #17
feernando
Motorcycle(s): ninja 300 ninja 250 project
wheel bearing
feernando is offline   Reply With Quote
Old May 4th, 2017, 05:48 PM   #18
strickcharles5
Motorcycle(s): 07 250 ninja , 97 600 ninja
Might be when your lean so far over the oposite side of your lean the valves arent getting oil at that point because of the angle of you lean or not as much oil rather most of the oil is going the way your leaning.I wouldn't worry about it that's not a lot of miles you have on the engine probably just the sound of the bike.
strickcharles5 is offline   Reply With Quote
Old May 4th, 2017, 05:50 PM   #19
strickcharles5
Ohhh lol
Serious Lean Angle csmith12 Ninjettes At Speed 444 June 19th, 2017 05:13 AM
ticking noise jcsalazar 2008 - 2012 Ninja 250R Tech Talk 5 October 29th, 2014 12:24 PM
This never gets old. Braking with lean angle. Gurk Riding Skills 33 April 27th, 2014 10:46 AM
Got a new Bike and some lean angle ;D WesleySnipes Pictures 7 October 29th, 2013 07:20 PM
Ever wonder what serious lean angle looks like rojoracing53 Videos 6 April 4th, 2013 12:06 AM
