Old February 24th, 2017, 01:15 PM   #1
james250ninja
james250ninjette.newbie
james250ninja's Avatar
Motorcycle(s): 1986 ninja 250
adjusting idle mixture scews
is there a way to adjust the idle mixture scews with out pulling out the carbs of the bike
if so what the best flat head screwdriver to this with
james250ninja is offline   Reply With Quote
Old February 24th, 2017, 01:32 PM   #2
Here you go - http://faq.ninja250.org/wiki/How_do_...dle_mixture%3F
Old February 25th, 2017, 06:06 AM   #3
ducatiman
ducatiman's Avatar
Finger strength on a short bit should be all thats required, you want the tip to fit the screw slot correctly, the diameter can be ground down to perfect size, as needed to enter the pilot screw cavity.
Warm engine and temporarily raising your idle a bit...the sweet spot will become more prominent (easier to hear) as you adjust the screw in/out , of course looking for your highest idle and best throttle response for *each* cylinder. When complete, lower your idle speed and double check that RPM's rise instantly with throttle application...and drop correctly..no hanging or "hunting"....dropping then raising. Needless to say, idle speed should be consistent and steady.
Of course, this is entirely predicated on having clean, calibrated carb circuits, fresh fuel, functional ignition system (spark plugs) and valves with correct clearance.
Good luck.
gordon@customcarbservices.com
Custom Carb Service
www.customcarbservices.com
Old February 25th, 2017, 08:54 AM   #4
That's the one that I learned about shortly after getting my ten year old 250. There's no point in trying to get the carbs adjusted correctly until you're sure the valves are set correctly.
Old February 25th, 2017, 10:51 AM   #5
ducatiman
ducatiman's Avatar
^ agreed, all sections got to work together like an orchestra (brass, woodwind, string, percussion)
Custom Carb Service
DIY - Accessing and adjusting idle mixture screws VeX 2008 - 2012 Ninja 250R Tech Talk 71 December 15th, 2017 03:38 AM
Question about idle mixture screw and low idle flux daverdfw 2008 - 2012 Ninja 250R Tech Talk 3 June 2nd, 2016 10:36 PM
adjusting idle mixture screws james250ninja 1986 - 2007 Ninja 250R Tech Talk 9 September 1st, 2014 10:29 AM
Adjusting the Idle Mixture Screw conrya5 2008 - 2012 Ninja 250R Tech Talk 22 March 18th, 2013 05:03 AM
Awesome tool for adjusting mixture screws - with both fairings on! headshrink 2008 - 2012 Ninja 250R Tech Talk 6 December 5th, 2011 05:14 PM
