November 29th, 2014, 07:43 PM | #1 |
Join Date: Nov 2014 Motorcycle(s): 2008 Ninja 250r Posts: 2
My ninja won't turn on.
Hi, new here. So I went to the bank, and came back to start my bike. Nothing would turn on not even the lights. So i thought it was the battery. I try to jump start the bike and all light turns on (Neutral, High beams, etc). I turn the motorcycle on, and it started good. As soon as I take out the jumper cables, the bike starts dying and the rpm when all the way to 15,000. Please help.
November 29th, 2014, 08:07 PM | #2 |
Welcome Julio!
Start with a good full charge on the battery, then check the battery while cranking (under load) and then again while running. Let us know the voltages.
November 29th, 2014, 08:20 PM | #3 |
I went to go charge the battery on autozone, and they told me the battery was at 80% when i left the battery. Im going to try and crank tomorrow.
November 29th, 2014, 08:47 PM | #4 |
The battery is probably toast.
You can try charging it until it reads 12.7V (100%), but it may drop off to zip as soon as you hit the button. What you described is not uncommon for a bad battery. I've had the same thing happen to a car battery, and it was junk. |
November 29th, 2014, 08:50 PM | #5 |
Make sure your battery terminals are completely tight. If they get loose, weird things can happen. It may very well turn out to be a bad battery, but tightening the connections down with a socket (don't just use a screwdriver) is never a bad thing to check.
November 29th, 2014, 09:04 PM | #6 | |
Also check the battery voltage when you hit the button, and let us know what it is, like Chris suggested. |
November 29th, 2014, 09:36 PM | #7 |
Track Clown
MOTM - Sep '15
Possibly a charging problem. I hate electronics, so don't ask me how to fix it.
08 Ninja won't turn over | Meximario | 2008 - 2012 Ninja 250R Tech Talk | 23 | July 10th, 2014 09:59 AM |
bike won't turn over | SMW-Vikings | 1986 - 2007 Ninja 250R Tech Talk | 10 | May 4th, 2014 05:54 AM |
my ninja's headlight won't turn on | ndrszpt | 2008 - 2012 Ninja 250R Tech Talk | 11 | March 5th, 2012 03:17 PM |
HIDs Won't Turn On | lux | 2008 - 2012 Ninja 250R Tech Talk | 3 | September 11th, 2010 03:13 PM |
Fan won't turn on | Betlog | 2008 - 2012 Ninja 250R Tech Talk | 25 | March 16th, 2010 06:10 AM |
