January 17th, 2014, 01:57 PM | #1 | |
Jedi on Two Wheels
Join Date: Nov 2013 Motorcycle(s): 2010 Kawasaki Ninja 250r (Slightly Modded) Posts: 489
Advice on Suspension Upgrade?
I started to get some interest in upgrading suspension to be more tuned to my weight and riding style. I contacted a RaceTech approved shop and they gave a quote that was somewhat pricier than I expected. I'll post the email
January 17th, 2014, 02:01 PM | #2 |
those are standard if not cheap prices
i think those numbers for stock are not correct though. go to the race tech website and do the calculations yourself. you can do the service yourself. you don't need emulators if you're going to swap the rear you might as well upgrade to a gsxr shock while you're at it. buy a used gsxr shock ($40 ebay) and respring it before you put it on. then just swap the front springs and fork oil
January 17th, 2014, 02:02 PM | #3 |
Jedi on Two Wheels
January 17th, 2014, 02:05 PM | #5 |
if you can turn a wrench you can install new suspension. i dont think anyone should pay someone else to do something they can do themselves, so if you are physically able to ride a bike, i would think you should be physically able to fix it.
January 17th, 2014, 02:08 PM | #6 |
Seems par for course for a dealer or shop. I just did this not to long ago on my 250. If you can't follow this DIY, you need to pay someone else or get some local help.
Here is another reference.
January 17th, 2014, 02:12 PM | #7 |
Nope, I think for where you are at with your riding, you can get a better feel with just the super cheap spacer mod. And you should be able to complete it easily yourself. If you feel you need more, then go the route of springs, emulators and maybe even some caps. And after doing the spacer mod, you just might feel better about doing the springs yourself. See were I am going here?
Like I said in other threads, you can get within 4 seconds of multiple track records with the stock bits. You shouldn't be riding THAT hard on the street.
January 17th, 2014, 02:15 PM | #8 |
Ms. Personality
January 17th, 2014, 02:17 PM | #9 |
Cause he aint gunna notice the difference until later. It's a bit of cart before the horse.
January 17th, 2014, 02:19 PM | #10 |
Ms. Personality
Ok
January 17th, 2014, 02:26 PM | #11 | |
Jedi on Two Wheels
January 17th, 2014, 06:33 PM | #12 |
Rode with the Dinosaurs..
Join Date: Nov 2013 Motorcycle(s): '08 Ninja 250 Posts: 486
+1 - On the Sonic Springs. I also used heavier oil and it made a world of difference in the overall ride. Didn't go with emulators myself as I only use my bike as a daily commuter and the roads around here suck anyway.
Fortune favors the brave! |
January 18th, 2014, 12:20 AM | #13 | |
Nice folks to work with & prices are very reasonable. Changing to better fork springs geared towards your weight & usage has to be one of the best value per dollar mods. |
May 20th, 2014, 05:44 AM | #14 |
Join Date: Jan 2011 Motorcycle(s): 15 CBR300R, 14 BWS50, 09 FZ1, 09 Ninja 250, 06 CRF450R Motard, 03 ZX-6R Posts: 422
I'm looking to purchase Sonic .75 springs for my 09 250 and plan to use 15 weight fork oil. I weigh 150lbs and want to fix the wallowing I experience in the corners. I still have the stock rear shock and I'm not sure if I will replace it. What's everyone's thoughts on upgrading the front springs and leave the stock rear shock? Thank you.
15 CBR300R, 14 BWS50, 09 FZ1, 09 Ninja 250, 06 CRF450R Motard, 03 ZX-6R 636 |
May 20th, 2014, 06:21 AM | #15 |
Fighting Texas Aggie '05
I have the front setup with emulators, .90 racetech springs, preload adjusters, high quality fluid, the standard works for the stock housings on my track bike. It works reasonably well and I would highly recommend it if you have excess cash to blow through.
I have done 4 or 5 sets of emulator/spring installations now and I would personally rate it around a 3 or 4 on the 1-10 scale of installation difficulty. But then again I have done pretty much every type of mechanical work so my scale is a bit off. Now that being said, on my commuter Ninjette I have .80 racetech springs, preload spacers, and high quality fluid. I didn't need the adjustment for the street bike I saved the cash. It does just fine.
May 20th, 2014, 07:02 AM | #16 |
Did you leave the stock rear shock in place on your street 250?
May 20th, 2014, 09:25 AM | #17 |
EX500 full of EX250 parts
According to RaceTech's calc, the NewGen's fork springs are too light for any human rider (they suggest 50% stiffer for a 100lb rider), but the rear is sprung for about 220lb. It will be a bit mismatched with only the fork springs swapped, but it'll be much closer than stock.
The PreGen's rear spring is actually pretty close for your weight, but the PreGen's shock is shorter and not adjustable. I don't know of an easy way to get a slightly softer rear spring on the NewGen. One of the GSXR shocks that are commonly swapped might have a spring in the right range. *shrug* |
May 20th, 2014, 11:53 AM | #18 |
I'm going to try doing the front end first. I have a ZX-6R with a Hyperpro shock and Ohlins spring set to my weight so know what a huge difference properly setup suspension can make.
May 20th, 2014, 12:16 PM | #19 |
actually have stock shock on both, but have raising link on track bike. Track bike is getting GSXR shock shortly.
May 20th, 2014, 12:26 PM | #20 |
Great. Thank you. Let me know if you decide to sell the raising link. Where did you buy it?
Suspension upgrade | jgcable | 1986 - 2007 Ninja 250R Tech Talk | 13 | February 13th, 2015 02:22 AM |
Front suspension upgrade | Rollingmenace | 1986 - 2007 Ninja 250R Tech Talk | 3 | October 4th, 2013 07:42 AM |
New gen suspension upgrade | randomwalk101 | Ninjettes At Speed | 23 | October 18th, 2010 09:42 PM |
is this suspension upgrade possible???? | brausatch | 1986 - 2007 Ninja 250R Tech Talk | 5 | October 3rd, 2010 03:33 PM |
Possible Upgrade Advice | k1prototype | General Motorcycling Discussion | 14 | November 5th, 2009 03:19 AM |
