Old July 9th, 2013, 09:11 AM   #1
NinjaRed
NinjaRed's Avatar
Idles too high I think??
I've recently noticed that when I ride my bike for long enough, say 15 minutes or more, it would idle at ~3500 rpm when its about 90 degrees F outside. I am pretty sure this is too high even for that temperature. But I'd like someone to verify that its too high of an idle speed before I lower it to ~1500 rpm.
p.s. unless we're suppose to say magic words when opening the fuel cap, I have to struggle with the key to twist it open. any suggestions/tips or magic tricks on making it easier would be appreciated.
NinjaRed is offline   Reply With Quote
Old July 9th, 2013, 09:16 AM   #2
Lychee
sail away
Lychee's Avatar
Is the engine at normal operating temperature, or did you just start it?
Is the choke on?
Normal idle at operating temp is a little less than 1500 rpm.
Cold idle at 3500 rpm with choke on is normal.
Old July 9th, 2013, 10:04 AM   #3
greenaero
Motorcycle Hypermiler
greenaero's Avatar
Motorcycle(s): 1999 & 2005 Kawasaki Ninja 250R's
3500rpm is too high, adjust to ~ 1300-1500 rpm. I'd try lubricating the gascap lock and gently work it around so that you don't break the lock or the key.
greenaero is offline   Reply With Quote
Old July 9th, 2013, 10:14 AM   #4
NinjaRed
NinjaRed's Avatar
Is the choke on?
It idles after the bike has warmed up.. so at normal operating temperature i guess. Like i would be stopped at a red light and notice that it idles at 3500.
the choke would not be on then (i only use choke to warm up the bike when I first get on it, and turn it off before riding it/when its warmed up enough so it does not stall.)
Old July 9th, 2013, 10:14 AM   #5
Sounds like maybe your choke is on. Cable on the chock working right? If not, turn the idle down via the adjustment and ride on.
As far as your gas cap lock. Clean it with WD-40 to break up any tough stuff then lube with graphite spray. Any time you clean your chain, check your gas cap too. An ounce of prevention is worth a pound of cure.
Pro tip: When it's really, really stubborn, take off your seat and some gentle love taps with a rubber mallet on the mounting bolts of the tank. Should be great assist, tap while turning the key.
EDIT: For your high idle, check your air filter too.
Old July 9th, 2013, 10:18 AM   #6
Lychee
sail away
Lychee's Avatar
Turn the idle down it is too high.
Press the gas cap in before you turn the key, that helps relieve the pressure on the lock from the internal catch. Drip some 3-in-1 oil into the lock.
Engine idles to a stop after running a few minutes. MCPhotographer 1986 - 2007 Ninja 250R Tech Talk 38 September 2nd, 2016 08:48 PM
After jetting bike idles low? Mr_ek9 2008 - 2012 Ninja 250R Tech Talk 2 January 17th, 2015 02:18 PM
Bike idles higher when leaned over on kickstand cuong-nutz 2008 - 2012 Ninja 250R Tech Talk 2 September 25th, 2014 12:24 PM
[motorcycle.com] - US Highland Idles Factory Ninjette Newsbot Motorcycling News 0 January 20th, 2011 02:00 PM
Still Idles high :( M-Oorb 2008 - 2012 Ninja 250R Tech Talk 40 April 17th, 2009 07:28 PM
