Old June 16th, 2011, 05:11 PM   #721
blink
Always.
blink's Avatar
Motorcycle(s): '08 Ninja 250, '05 GSX-R600
Originally Posted by kevheads View Post
put the lower fairing & tail decals on today.
Super sexy
Goodjob. Liking the fade!
blink-182
blink is offline   Reply With Quote
Old June 16th, 2011, 05:33 PM   #722
Momaru
Momaru's Avatar
That's quite smexy Kevin. For a green bike anyway
I pulled my carbs today and cleaned the heck out of 'em. Found one of my mains was a little loose. Also seeing some of the rubber boots for the electrical systems are fallin' apart, so time for another parts order.
Definitely feeling like I'm spending more time on maintenance than on the road this summer. But gotta pay the piper sometime and I'd rather it be upfront than on the highway doin' 85... Still, glad I get to spend some QT with my baby
Proud member of the Blue Army
Old June 16th, 2011, 06:09 PM   #723
00NissanNinja
I hate driving...
00NissanNinja's Avatar
Motorcycle(s): 13 Triumph Street Triple R, 09 Ninja 250r (Sold 4/20/12)
Finished putting on my woodcraft clip ons. I was having problems getting my hand to clear on the clutch side while on the brake side I had plenty of room. Figured it out after I rode it around today, should be good to go. Lock to lock my gloves don't hit now. Plus new grips!
09 ninja 2fiddy SE Driving slow things fast
00NissanNinja is offline   Reply With Quote
Old June 16th, 2011, 06:15 PM   #724
I modded my front tire's tread pattern.
That was after many miles and when I felt it it was REALLY gummy/sticky.
Last futzed with by CZroe; June 18th, 2011 at 10:11 PM.
Old June 16th, 2011, 08:40 PM   #725
taikahn
Motorcycle(s): 2011 Ninja, 71 Honda Cafe
Rode it, 3 times.
taikahn is offline   Reply With Quote
Old June 17th, 2011, 07:43 AM   #726
Kevin, ohmygosh thats a great looking bike! is that one of the new paint schemes? beautiful!
Old June 17th, 2011, 08:03 AM   #727
Luxodave
Luxodave's Avatar
Motorcycle(s): 2009 Yamaha FZ6
Looks really good.
Luxodave is offline   Reply With Quote
Old June 17th, 2011, 09:13 AM   #728
00NissanNinja
I hate driving...
Originally Posted by Luxodave View Post
Looks really good.
Thanks man The handling is better now. It goes into turns easier than before.
Old June 17th, 2011, 08:22 PM   #729
kevheads
kevheads's Avatar
Motorcycle(s): 2011 Green 250R
Installed my tank pad that I got in the mail today but not real happy with it. Looked cool on their website http://www.srsigndesign.com/id3.html but the green is way off. Guess I'll just live with it for now.
kevheads is offline   Reply With Quote
Old June 18th, 2011, 04:04 PM   #730
Sk8dude
Sk8dude's Avatar
Motorcycle(s): 2009 Ninja 250R Black
personally changed the oil for the first time
Sk8dude is offline   Reply With Quote
Old June 18th, 2011, 04:35 PM   #731
I've had the same new grips on there for a couple weeks (well, the blue version) and I'm still waiting on my clip-ons that I ordered from eBay (Woodcraft-style under-the-triple w/ riser 41mm SV650 clip-ons). Thanks for the preview.
Old June 18th, 2011, 05:28 PM   #732
00NissanNinja
I hate driving...
A quick tip to help your levers clear with some room to spare is to pull the handlebars back as far as you can before tightening everything. Pull it tight enough that it sticks to the triple tree(the riser) and then tighten everything down. This gave me the extra room needed on the clutch side. The grips are great and help keep vibration levels at stock with the clip ons, might be a tiny bit better.Do those clip ons fit? The woodcraft are 37mm
Old June 18th, 2011, 05:44 PM   #733
Thanks. They need to be shimmed but they say that it is trackable. I need to grind an alignment peg off the clip-ons so that they sit flush under teh triple and I think the DIY says that the top triple is shimmed to sit a bit higher, which probably disables my handlebar lock, but I'm OK with that.
Old June 18th, 2011, 05:53 PM   #734
00NissanNinja
I hate driving...
Oh, okay gotcha. Good luck getting it together, In the end you should like it. Its a bit more aggressive but I can still sit almost completely upright. The past couple of times I commuted I didn't feel any new areas of discomfort.
Old June 19th, 2011, 02:11 PM   #735
whiteboy
whiteboy's Avatar
Motorcycle(s): 2009 blue ninja 250r
Shimmed 2 washers on the needles and took the snorkle off. Plan on doing a little fathers day ride up a little mountain to do a longer test ride. O and I cleaned and lubes the chain
If you’re going to lead, then lead. If you’re going to follow, get the hell out of my way!
whiteboy is offline   Reply With Quote
Old June 20th, 2011, 07:54 AM   #736
coolbreeze
coolbreeze's Avatar
Motorcycle(s): 2000 250 sold; 2005 636 sold. BIKELESS IN ATLANTA
It's not a perfect match, but it still looks good to me.
coolbreeze is offline   Reply With Quote
Old June 20th, 2011, 07:59 AM   #737
coolbreeze
coolbreeze's Avatar
I added a qt of oil to mine. I noticed the last time I was riding that the oil light stayed on a little longer and even came on while riding. Not sure how it happened, but by the time I made it home and checked it, it was barely showing in the window. I'll be changing the oil this weekend anyway, so I can check for leaks. So far, no oil stains anywhere.
Old June 20th, 2011, 01:47 PM   #738
MattRichling
Motorcycle(s): 2011 250R Black
Thumbs up
did the first oil change at 600~km
MattRichling is offline   Reply With Quote
Old June 20th, 2011, 07:00 PM   #739
this post is more of a "what have you done to your ninjette this week" post than a "what have you done to your ninjette today" post.
my battery died. So I learned how to start it by popping the clutch and took it for a ride to try and recharge it. That didn't work and I freaked out thinking it was the R/R so I charged the battery on a battery tender. Still no juice. Found a battery at autozone that works and gave it a full charge. $55 later... and the bike runs. yay!
next thing I did was play around with my jetting. I took off the airbox lid, but that made my mains lean. So I put the lid back on. Then I tried different shimming on the needles. Thanks to kkims suggestions that I ignored the first time (sorry kkim. I'm listening more closely from now on I promise ) and tried more washers. 1 was for sure too few. 3 was a hair too many. 2 is perfect. reset the pilot jets to 2.5 turns out and the bike pulls everywhere smoothly. no chugging, and it pulls strongly starting at 5k and pulls hard starting at 6.5k-7k. beautiful.
Finally, I noticed that my idle was pulsing. Since I've been messing with the jetting, it seemed like it was time to brave syncing my carbs. followed these instructions for the two bottle method. only cost me $8 at my local hardware store.
http://faq.ninja250.org/wiki/How_do_...carburetors%3F
Now, my carbs are synced perfectly. wow. so smooth off the throttle, and the idle is even, and no more rhythmic pulsing. From now on the three things I recommend for every 250 owner to do is get better tires, shim the needles, and then sync the carbs. My bike is now purring and I'm still in love with it (even though my friend trusted me with his '98 CBR600RR and I'm in love with that too. two totally different animals) and for now the 250 is my dream bike because it's mine and I love it.
Old June 20th, 2011, 07:10 PM   #740
Live2ride
Live2ride's Avatar
Motorcycle(s): 06 yzf r6r previously: 09 ninja 250r, black 07 zx6r
Changed my oil and oil filter. Switched to synthetic oil. I played with the friction zone in my shed and the little bit I played with it it felt like the power delivery was a lot smoother when slowly releasing the clutch. Gonna see if it will stop raining for just 1 day so I can ride into work tomorrow .
Live2ride is offline   Reply With Quote
Old June 22nd, 2011, 06:34 PM   #741
slolane
Motorcyclist
slolane's Avatar
Motorcycle(s): 2014 Ninja 300 ABS
Received my 4.5" wheel today and installed it with my 150 tire that I was running on the stock wheel...
More pics posted in THIS THREAD.
slolane is offline   Reply With Quote
Old June 22nd, 2011, 08:17 PM   #742
That 4.5 wheel and tire installed looks sick ! I want one but no way to justify the cost.
I changed oil and ordered air filter for the pregen. Looking forward to getting it running properly. I "think" I have finally talked my wife into riding!
Old June 22nd, 2011, 08:46 PM   #743
slolane
Motorcyclist
slolane's Avatar
Thanks, all in all it's a cheap bike for me so I'm cool with it.
Old June 23rd, 2011, 12:15 PM   #744
Live2ride
Live2ride's Avatar
Great looking tire, slolane!
On another note, I have noticed that at the very bottom portion of my dash, there is an open space allowing me to see a small amount of the foam around the headlight and inside the fairing; is this normal? It looks as though it should be covered and I didn't recognize this before installing my new puig db windscreen.
Old June 23rd, 2011, 07:44 PM   #745
00NissanNinja
I hate driving...
^Mines is like that too. My double bubble made it more noticeable than with the stock windscreen.
Old June 23rd, 2011, 08:02 PM   #746
Live2ride
Live2ride's Avatar
cool, thank you.
Old June 23rd, 2011, 08:13 PM   #747
slolane
Motorcyclist
slolane's Avatar
Thanks man, I'm diggin it.
Old June 23rd, 2011, 08:20 PM   #748
kaiserz
There's a limit to s2pdty
kaiserz's Avatar
same here
Old June 23rd, 2011, 08:24 PM   #749
Live2ride
Live2ride's Avatar
Originally Posted by kaiserz View Post
same here
I'd imagine this is the way kawasaki decided to vent some of the hot air from the headlight. It makes sense considering the temp / clock / compass doohicky I put under my windscreen always ran hot "(temp was running way too high) while the bike was running.
Old June 23rd, 2011, 08:35 PM   #750
kevheads
kevheads's Avatar
painted my windshield, very happy with it,looks 100% better than original. Stopped at Harbor Freight and picked up their rear stand but got to take it back tomarrow, the parts that hook the spools are both for the right side. next its time for my "second" 300 mile oil change this weekend. I figured I'd do 75,300 then 600 miles.
Old June 24th, 2011, 08:11 AM   #751
DarC
DUCEATR
DarC's Avatar
Motorcycle(s): RVT1000R
I arrived home just as the my favorite UPS man was pulling away. 30 minutes later I had a sweet set of woodcraft clip-ons on the bike ready to ride. I nailed the clearance on the first go (thanks to lots of reading here) and might only adjust them slightly. I wish there was more room to get a little more aggressive but these will work and keep the bike rider friendly enough for the wife.
DarC is offline   Reply With Quote
Old June 24th, 2011, 09:44 AM   #752
road_rascal
Motorcycle(s): ___
I finished up adding additional tail/brake lights to the rear pods on my '04. Also put on a Wolo "Full Blast" low tone horn. Definitely much louder than the stock 'meep-meep' roadrunner sounding horn.
road_rascal is offline   Reply With Quote
Old June 24th, 2011, 12:16 PM   #753
shiroganeshinobi
Motorcycle(s): 2010 250R SE
Talking
Should have put this horn on. (Lower your sound volume!)
shiroganeshinobi is offline   Reply With Quote
Old June 24th, 2011, 02:40 PM   #754
MattRichling
Spent a fortune...
New Aplinestar SMX5 Boots, Used HJC Full two-peice suit (only $200!), Spools, Rear Stand, Teknic Gloves, Fender Eliminator, Chrome Visor, and Scala Bluetooth thingy! OH and Ordered the Area P Mid-High Mount Full Race Exhaust System, 12" Carbon Fiber Muffler and Jet Kit!
Old June 24th, 2011, 05:58 PM   #755
russdouble
Motorcycle(s): 1981 GS650 Cafe Racer, 2003 Naked 250 Ninja
Took it out for its first "legal" ride today. I bought it from a friend, and have had it in my garage for a month trying to get him to get to a notary to have the title transferred, and we finally got it done yesterday, so today meant a legal ride to work.
russdouble is offline   Reply With Quote
Old June 24th, 2011, 08:35 PM   #756
Havok
Internet Slut
Havok's Avatar
Motorcycle(s): 04 FZ1, 07 FZ6
A new corbin seat arrived today We got it put on and sat on it for a few min but it was too late to go for a ride tonight. I can't wait to see what a difference it makes.
Havok is offline   Reply With Quote
Old June 24th, 2011, 08:44 PM   #757
Havok
Internet Slut
Havok's Avatar
Woops, Jeff left himself logged in. Meant to post from my acct
~ Ambar (Sharon)
Old June 24th, 2011, 09:56 PM   #758
bettysmith
Motorcycle(s): 2010 ex250 (Blue)
Shimmed the carbs. Noticed a slight rattle around ~9/10k RPM's while accelerating hard but not necessarily at WOT. Anyone have input? I thought I recalled something about a front end rattle, but it's escaping me at the moment.
bettysmith is offline   Reply With Quote
Old June 24th, 2011, 10:13 PM   #759
does it rattle when the bike is in neutral and you rev it?
Old June 24th, 2011, 10:45 PM   #760
bettysmith
From what I remember, no. I rev'd it quite a few times trying to finely adjust the idle and don't recall hearing any rattle. A little late here at the moment to go check as well.
Discovered something scary about my Ninjette today... kjohng General Motorcycling Discussion 28 October 15th, 2021 01:40 PM
Sold the 2006 Ninjette today :( Renner General Motorcycling Discussion 31 October 16th, 2014 11:46 PM
Today I Gave My Ninjette Wings! BlueHairSar Pictures 5 June 20th, 2013 07:38 AM
my bro went down today on his ninjette richierich781 !%@*#$%!)@#&!%@ I crashed! 46 January 18th, 2013 11:59 AM
Ninjette. org hacked today CC Cowboy Off-Topic 9 April 3rd, 2011 08:55 AM
