August 10th, 2016, 06:05 PM | #1 |
Join Date: Aug 2016 Motorcycle(s): 2012 Ninja 250r Posts: 5
Left Turn Signal Issue
Hi everyone. New to the forums. New to the Kawi Ninja. New to the moto world, in general. I just bought my 2012 Ninja 250r a week ago, & have discovered an issue with the turn signals.
So here's the rundown. The previous owner installed an integrated tail light, kept the OEM signal relay, & utilized 2 50w resistors. I've since clipped off the resistors, & replaced the signal relay with a LED-compatible one from TST Industries. So now, the right side turn signal works, but the left side keeps blowing the 10a fuse. Here's what I've done to troubleshoot so far: I've snipped off the b/w wire that was spliced to the power wire for both side turn signals. Right side works fine, but left blows fuse. I then snip the left side power wire & push the left signal switch. Blows the fuse. So then, I begin trying to isolate the issue. I disconnect the front-left turn signal. Hit the switch, & the fuse blows. As it stands right now, I'm just assuming that there is a short in the circuit. Somewhere between the battery & the fuse box. I'm very much circuitry inept, so my next step was to cut all of the sheathing between the battery & the fuse box to see if there's an exposed wire or some other means of a short. Any advice on this issue is greatly appreciated. |
August 10th, 2016, 06:31 PM | #2 | |
n00bie to wannabie
Join Date: Sep 2015 Motorcycle(s): 2012 250R (Red), 2005 VFR800A (Red), CRF450X (Red), 2012 F800GS (Wants to be Red!) Posts: A lot.
MOTM - Nov '15
Welcome Jeremy! Don't worry; achievement awards are badges of honour! Sorry I can't help you with the technical glitch but there will soon be help arriving!
The Smart Money: #1 - ATGATT, #2 - Training (machine skills and survival skills), #3 - The bike; whatever floats yer boat with the money you have left over |
August 10th, 2016, 07:25 PM | #3 |
On it Bill...
Welcome Jeremy!
August 10th, 2016, 07:34 PM | #4 |
Great forum name man!
August 10th, 2016, 07:37 PM | #5 |
August 10th, 2016, 07:52 PM | #6 |
n00bie to wannabie
MOTM - Nov '15
Hey Jeremy; quote this post and copy the image text below that will appear in the quote instead of the image, into your signature to get it to appear in your signature:
August 10th, 2016, 08:13 PM | #7 |
I assume I include the "[IMG]" and "[/IMG]", then put it all in the big text box...?
August 10th, 2016, 08:49 PM | #8 |
n00bie to wannabie
MOTM - Nov '15
Not the big box. Copy the image stuff as you described. Go to your profile page. Select "Edit Signature". Select "Add Signature image". Paste the image text into the box. Save changes.
August 10th, 2016, 09:12 PM | #9 |
the "upload signature picture" keeps giving me a "invalid file" message.
https://www.ninjette.org/forums/pict...ictureid=12996 |
August 10th, 2016, 09:20 PM | #10 |
Certifiable nontundrum
MOTM - Sep '13, Sep '16
I think that's the quickest one ever
I don't like electrical
August 10th, 2016, 10:02 PM | #11 | |
n00bie to wannabie
MOTM - Nov '15
August 11th, 2016, 11:58 AM | #12 | |
EX500 full of EX250 parts
Everything in the turn signal circuit is shared between both sides except the green or gray wire running from the switch to that side's lights. If the problem only happens on the left side, the problem inherently has to be in the green wire.
August 11th, 2016, 12:01 PM | #13 | |
Achievement sig
[img]https://www.ninjette.org/forums/picture.php?albumid=1580&pictureid=12996[/img]
August 11th, 2016, 12:07 PM | #14 | |
[sigpic]https://www.ninjette.org/forums/picture.php?albumid=1580&pictureid=12996[/sigpic] The sigpic tag is what I am using.
August 11th, 2016, 01:18 PM | #15 | |
Achievement sig
In this case, since the image is already hosted here, he can just use the IMG tags around the URL of the pic (like you would to insert an image in a post). If he wants to make it so he's not dependent on your album, he could save a copy of it, then reupload it as his sig pic, then use the SIGPIC tag to insert it.
August 11th, 2016, 04:48 PM | #16 | |
August 12th, 2016, 07:39 AM | #17 |
I always start with a multimeter before I start taking parts off
Odd turn signal issue | Whelming | 2008 - 2012 Ninja 250R Tech Talk | 16 | March 26th, 2016 11:21 AM |
Turn Signal issue, looking for opinions | ArsnlTim | 2008 - 2012 Ninja 250R Tech Talk | 14 | August 2nd, 2013 02:47 PM |
Stock turn signal issue | sshikari | 2008 - 2012 Ninja 250R Tech Talk | 5 | July 25th, 2012 04:59 PM |
Stock turn signal issue. | larson38 | 2008 - 2012 Ninja 250R Tech Talk | 3 | July 24th, 2012 09:49 PM |
Turn signal issue... | YMCMB | 2008 - 2012 Ninja 250R Tech Talk | 8 | July 21st, 2012 04:58 PM |
