June 6th, 2012, 06:00 PM | #1 |
1/4 English, 3/4 Kick Ass
Join Date: Sep 2011 Motorcycle(s): 2002 Triumph Speed Triple 955i, '05 Suzuki SV650S(retired), '11 Ninja 250R(sold) Posts: A lot.
Local shops for front wheel issue
Ok so I wasn't sure where to post this, because this pertains only to the State of Ohio.
Does anyone know how good the Kawasaki dealers/shops are in Dayton, Ohio and surrounding areas. I was looking at Competition Accessories or the Dealer in Kettering. I don't know if there are certain ones that I must stay away from or really must go to. I'm looking at getting some warrantee and regular work done. Thanks for the help guys. |
June 15th, 2012, 09:28 PM | #2 |
Did you ever find one?
June 17th, 2012, 08:36 AM | #3 |
I know of 2 near Cincinnati I could recommend but not sure if that is to far of a drive for you.
http://www.afjraceshop.com/ Ask for Brandon or Eric they own and run the place. Tell them I will pee in their leathers at Mid-Ohio if they don't hook you up. http://www.hondaofflorence.com/ 7 miles south of Cincinnati in KY. Ask for Knox, she is the service manager. Tell her I will kill her cat, (yes it's at my house) if she don't help you.
June 17th, 2012, 11:40 AM | #4 |
What is the issue?
June 17th, 2012, 06:31 PM | #5 |
June 18th, 2012, 02:37 PM | #7 |
June 18th, 2012, 02:45 PM | #8 |
describe the feeling in the handlebars.
is it one or two pops when you start accelling or decelling? a rythmic beat that follows the speed of the wheel? a continuous thumping that doesnt follow the speed of the tire directly? a random clanking sound that doesnt seem to relate directly to the speed but gets stronger when going faster?
June 18th, 2012, 06:49 PM | #9 | |
I know it's not the brakes, the same vibration was still there even after changing brake pads. |
June 18th, 2012, 08:24 PM | #11 |
Put it up on stands and spin both wheels by hand and listen. Start slow and increase the spin speeds, you should find you sound/vibration. I am with alex right now, sounds like a chain issue. Mine was funny like that on my pregen. Only under load, at lower speeds and felt it in the grips but heard it in the center/front.
June 18th, 2012, 08:59 PM | #12 |
if it didn't happen when he gased it i would put the money on a rotor, but if he gets it under gas also i would say chain. like he said it should be pretty obvious on stands spinning the wheels.
June 19th, 2012, 03:27 AM | #13 |
Good thoughts guys. Upon visual inspection of the chain, I notice that a few of the links are somewhat stuck in a slight v-shape. It's almost as though they don't flex right until it goes on he sprocket. Not sure if that is an issue, but I'm going to take it to the shop here soon anyways. Whats a good replacement chain to look for?
Fix for front wheel squeak noise/Front wheel removal | cuong-nutz | 2008 - 2012 Ninja 250R Tech Talk | 13 | April 23rd, 2014 12:25 PM |
250 ninja front wheel and 300 ninja front wheel | JasonG134 | 2013 - 2017 Ninja 300 Tech Talk | 2 | March 30th, 2014 09:12 PM |
Wtb shifter assembly,front forks,front wheel and bearings | Rumple | Items Wanted | 1 | June 24th, 2013 12:06 PM |
WTB: Front forks and front wheel for '10 Ninja 250 | Zakenda | Items Wanted | 1 | March 16th, 2012 07:30 PM |
