February 29th, 2020, 09:15 AM | #161 |
Join Date: Nov 2019 Motorcycle(s): GSXR 750, GSXR 600, Ninja 400, Ninja 300 Posts: 146
Here is a pic of my 2fiddy that I will be pulling the carbs out of for Mr. Gordon to work his magic!
February 29th, 2020, 03:04 PM | #162 |
Join Date: Jun 2017 Motorcycle(s): '09 Ninja 250R Posts: 180
March 14th, 2020, 09:54 AM | #163 |
EX500 refurb completed today, came out nice, predict will be fine runners after precise setup and testing.
24 hours in & out, btw.
gordon@customcarbservices.com Custom Carb Service www.customcarbservices.com Last futzed with by ducatiman; March 14th, 2020 at 11:12 AM. |
April 4th, 2020, 02:56 PM | #164 |
uh oh, Ducati carbs, wha we gonna do?
April 4th, 2020, 06:06 PM | #165 |
Yuck!!! is that algae? mould or fungus?
April 4th, 2020, 06:38 PM | #166 |
Hard to believe at one time that black stuff was fuel. The brass jets underneath, once revealed, will no doubt show some nasty damage. It'll be interesting to see, I'll leave them intact for a pic I'll eventually post. Thankfully, I've got spare jets involved.
Challenging, a lotta work ahead on these nasties, actually Mikuni BDST34 from a 750 Ducati Monster twin. Similar Mikunis were used on old 90's Yamaha FZ, some Suzuki fours too. For informational purposes...I'll try and get history from owner to see how long they sat.
April 5th, 2020, 06:18 AM | #167 |
turns out was a "barn find", sat untouched by current owner for 2 years, unfortunately no previous owner timeline available.
As the pictured carb is far worse than the other, i'll venture to say it was left on its side stand many years filled with unstabilized fuel.
April 6th, 2020, 05:10 PM | #168 |
Duc carbs finished today, before & after
April 7th, 2020, 03:38 PM | #169 |
Work commencing on Honda V4 ST1100 Keihin carburetors today. Various issues will be corrected.
April 9th, 2020, 02:43 PM | #170 |
brass (jets, pilot screws) prepped and ready for reinstall
April 16th, 2020, 01:36 PM | #171 |
separate vacuum leak diagnosed/fixed, carbs' internal circuits cleared, float levels, mixture adjustments corrected, starts on the click of the button, stable idle, responding to throttle.
New battery, intake manifolds, oil & fuel filters, oil & coolant, final drive oil, spark plugs...(basically a full service minus valves) This big-ass 650 pound touring ST1100 Honda (V4 carbed powerplant) is ready to rock after tire and valve replacement....next on the list. I await shipment.
April 18th, 2020, 03:48 PM | #172 |
My Saturday here....missing various parts, clogged in numerous areas, vent hose misrouted and kinked shut between the poorly setup carbs, bowl hardware obscenely tightened to compensate for crushed oring seals, pilot screws (missing washers) closed shut, every single oring crystallized solid, decel valve sticking, air correction jets clogged........on and on.
I'll submit the owner will not recognize them as his own AND the 250 involved will now run like a champ (provided no other issues on bike). Not quite done yet....these required some chutzpah, determination, and experience in knowing where to seek and how to eliminate problem areas. Splitting mandatory in this repair. Yeah, "carbs are easy"....right.
April 18th, 2020, 04:46 PM | #173 |
ST is so awesome! I may go for one of those eventually...
April 18th, 2020, 05:51 PM | #174 |
This 650 lb Honda behemoth is certainly the opposite side of motorcycling from the perspective of ninjette and such lightweight sporties. Their (mature) owners rave on its comfort, reliability and pile many miles on....200K+ not unusual at all.
Gulp...I will test ride after new tire install before handing it back to the 70 year old local owner (friend of a friend). Want to assure no running issues whatsoever. I gotta admit, its size and weight are rather intimidating. Being a lightweight I had to employ additional help to get it up on the centerstand!
April 19th, 2020, 06:35 PM | #175 |
2 fiddy set completed this evening, evidence of neglect and abuse, missing parts, prior setup errors all corrected. These now ready to rock, going home to Colorado.
April 27th, 2020, 03:16 PM | #176 |
Current "corona" project...in process of restoring an original Holley 1 barrel carb off a 1958 Ford F100 pickup. Goal to make both functional and return it to its former glory by owner request. I'll post before/after when done.
Interesting old brass float setup and ball bearing type check valves and drillings (rather than jets) controlling flow and spray...this one an oldie alright.
April 28th, 2020, 09:38 AM | #177 |
Netflix my ass. '58 Holley carb done this morning.....moving on to the next 250 set.
April 28th, 2020, 09:40 AM | #178 |
"a legend in my own mind"
MOTM - Feb '18
nice. we are workin too(cardinalhealth)
"trying not to get old" |
April 29th, 2020, 05:39 PM | #179 |
these 250's finished today, now onward to a Honda 750 Shadow carb/service work, bike here, live, in all its Honda glory.
May 2nd, 2020, 05:46 AM | #180 |
Honda Shadow carbs essentially done, I await new float bowl gaskets. In the meantime, doing valve clearances.
Interesting older Honda/Keihin carbs...some parts/orings common to 250!
May 9th, 2020, 09:26 AM | #181 |
24 hour refurb turnaround, received USPS Friday....shipped back Saturday
May 10th, 2020, 06:50 AM | #182 |
yet another 250 set on deck
May 15th, 2020, 12:08 PM | #183 |
The formerly spitting, sputtering, loudly popping Honda 750 Shadow is now done and complete, a successful victim of carb voodoo. Fully serviced and fully rideable, though the open, loud fishtail exhaust is utterly obnoxious, IMHO.....back to owner it goes. And today has officially left the building. Direct quote via text from owner "unbelievable, great throttle response, no hesitations, just perfect".
gordon@customcarbservices.com Custom Carb Service www.customcarbservices.com Last futzed with by ducatiman; May 16th, 2020 at 09:29 AM. |
May 15th, 2020, 12:59 PM | #184 |
Awesome work!!!
May 16th, 2020, 09:31 AM | #185 |
Ty. Got lucky I guess.
June 6th, 2021, 05:27 AM | #186 |
ZR7 carbs refurbed/completed this week. Now a break...nothing planned or going on at this point forward. Great opportunity to actually ride my own!
August 1st, 2021, 10:56 AM | #187 |
latest iteration of my splitting and non-splitting carb kits
$35 non split, $50 for split shipped USPS 1st class in CONUS
April 5th, 2022, 05:58 PM | #188 |
Just a reminder, I welcome petcock repair inquiries, with or without being accompanied by carbs.
As new 88-07 petcocks retail at $115, I'd guess it would be worth it to inquire. All spares are in stock, no delays.
June 1st, 2022, 02:45 PM | #189 |
until further notice.......
a CCS ink pen to be provided with every service/purchase!
June 24th, 2022, 12:14 PM | #190 |
Join Date: Jun 2013 Motorcycle(s): 2005 EX250, 1975 Suzuki T500, 2018 Kawasaki Z900RS Posts: 28
I sent the carbs from my '05 over to ducatiman back in 2020, I think, and I'm such a lazy forum member I'm only just getting around to saying it was the best decision I could have made.
Everything worked flawlessly out of the box and all my terrible, chewed-up fasteners had been replaced with nice stuff I can actually put tools on. The bike has been perfectly happy ever since. |
June 24th, 2022, 12:32 PM | #191 |
superb, great to hear Ash.
December 3rd, 2022, 06:07 AM | #192 |
Subscribing to this
December 3rd, 2022, 07:02 AM | #193 |
I'd opt to suggest you follow the thread named "my day"
https://www.ninjette.org/forums/showthread.php?t=348623 more current, timely posts
December 3rd, 2022, 02:29 PM | #194 |
Done!
December 3rd, 2022, 03:10 PM | #195 |
June 22nd, 2023, 01:29 AM | #196 |
Join Date: Jun 2023 Motorcycle(s): 2012 Kawasaki Ninja 250R EX250J Posts: 1
Still offering these formentioned services?
I have a 2012 Kawasaki Ninja 250R EX250J that I could use some carb work done on. I bout the hike off a guy who stooped rebuilding it due to family issues, and I finally got all the mechanical pieces hooked up to there respective spots but my carb is leaking fuel from somewhere on the bottom near the bowls.
June 22nd, 2023, 05:25 AM | #197 |
yes, of course
i'll PM in a bit
February 3rd, 2024, 12:46 PM | #198 |
February 3rd, 2024, 01:27 PM | #199 |
a rather rare Honda Hurricane 1000!
Further detail? total mileage? a runner? year?
February 4th, 2024, 11:48 AM | #200 | |
Screenshot_20240203-064659.jpg 1987 Honda Hurricane 1000, 19k miles, it runs, but only with the choke on, and that's about it. It's had a hard time, cracked fairings, etc... but it's got good bones. AKA "Hurricane Harvey" PS you'll be getting the carbs soon.
violente et ignorantia ZX-2R BLOG Twitter and Instagram = Ghostt_Scott I'm not here to change your mind, just to inform. Last futzed with by Ghostt; February 4th, 2024 at 01:03 PM. |
FS: Motion Pro Syncpro Carb Tuner (Carb Sync) $60 Shipped | menikmati | Motorcycle-related | 4 | April 8th, 2020 12:39 AM |
Full service manual says to turnout one carb pilot more than the other....why? | RcTechnologies | 2008 - 2012 Ninja 250R Tech Talk | 17 | March 25th, 2015 09:45 AM |
Valve adjustment, carb clean, carb sync? | amad1972 | 1986 - 2007 Ninja 250R Tech Talk | 2 | July 29th, 2014 09:42 PM |
[roadracingworld.com] - Race Tire Service To Provide Trackside Dunlop Sales, Service | Ninjette Newsbot | Motorcycling News | 0 | February 20th, 2012 11:10 PM |
[motorcyclistonline] - Sargent Cycles Custom Seat Service | Ninjette Newsbot | Motorcycling News | 0 | February 12th, 2011 07:30 AM |
