August 8th, 2015, 01:32 PM | #1 |
Join Date: Aug 2015 Motorcycle(s): 2017 Ninja 300 Posts: 24
Itty-bitty tires
Hey, anybody have any success with altering tire size? I had a 190 on my CBR 600 and it was really nice having that little extra bit of rubber on the ground, and I think the contact patch size on the 250 is making me a little hesitant to really dig into turns.
Any thoughts? I know going too big on the rear can totally screw up handling characteristics, so what's the practical limit? |
August 8th, 2015, 01:45 PM | #2 |
A 140 in a type radial compound will give you the most contact patch + traction at the expense of mileage. Some 150's are known to fit but will change the patch size or tire profile.
Do NOT let the size of the tire prevent you from riding with confidence. Think about it... sumo's get stupid lean angle + speed with skinny tires.
August 8th, 2015, 01:49 PM | #3 |
Track Clown
MOTM - Sep '15
lots of threads, try the search function.
August 8th, 2015, 01:50 PM | #4 | |
I'm still getting used to the maneuverability. I'll cheat off the seat for city street turns, and then realize that I don't even have to lean. It's weird. |
August 8th, 2015, 01:52 PM | #5 |
Search Google for Moto3 (250cc) cycles and look at the size tires they run - not very big.
Their cornering speeds are higher than MotoGP. A bigger tire requires more lean angle for the same corner at the same speed - not an advantage. |
August 8th, 2015, 01:54 PM | #6 |
August 8th, 2015, 01:56 PM | #7 | |
Still getting used to the size of the bike. Thanks for all the feedback. |
August 8th, 2015, 01:56 PM | #8 |
Differences between a 600 and a 250.
August 8th, 2015, 01:56 PM | #9 |
Track Clown
MOTM - Sep '15
ok how does that work? not to mention that the suspension, engine and weight are significantly different.
August 8th, 2015, 02:18 PM | #10 | |
I'm looking for an article I saw recently comparing MotoGP lean angles and cornering speeds with Moto2 and Moto3, but no luck finding it so far. Basically, IIRC, it was saying that MotoGP bikes need more lean angle in the same corner at a lower speed than the other bikes because of the larger tire, but I'll keep trying to find it. Another thing about lean angle that you wouldn't expect - the lower the center of gravity the more angle is required. Last futzed with by jkv45; August 8th, 2015 at 05:18 PM. |
August 9th, 2015, 12:57 PM | #11 | |
Shopping mall parking lot on a Sunday afternoon. |
Tires tires tires '90 250 | mr2peak | General Motorcycling Discussion | 4 | April 4th, 2014 08:53 AM |
Terrorizing the streets on my itty bitty scooter! | EthioKnight | Videos | 51 | June 22nd, 2012 10:16 PM |
Tires Tires Tires (ZZR) | mohns6062 | 1986 - 2007 Ninja 250R Tech Talk | 20 | June 15th, 2011 11:57 AM |
[topix.net] - More Bikes from EICMA: The Big Dorso, Bad-Ass BMW Scoot and an Itty-Bit | Ninjette Newsbot | Motorcycling News | 0 | November 5th, 2010 05:30 PM |
