#1 |
2012 Ninja 250R Green
Join Date: Nov 2011 Motorcycle(s): 2012 Ninja 250R Green Posts: 76
Dyno Jet Kit
Hey guys. I have done 0 performance mods to my bike. It seems that the most recomended mod is:
Dynojet Stage 2 Jet Kit: http://www.motorcycle-superstore.com...50R-Parts.aspx I was wondering if someone can direct me to a tutorial or if anyone has an experience with one of these. Is it worth the $100? Do I need a new exhaust system or air filter to use it? How do I install one of these? I have stripped the bike naked about 3 times now, so I am pretty sure I can do it myself just need a tutorial. Thanks for the help and feeback ahead of time. |
#2 |
Join Date: Aug 2011 Motorcycle(s): 2008 Kawasaki Ninja 250R, 2003 Honda CBR600RR Posts: 721
I had a dynojet kit on mine for the longest time before I switched to EFI, I purchased my bike with the kit though so I cannot vouch for the noticeable performance gains with the kit. They're actually pretty easy to install if you aren't afraid to do a little work on your bike. The easiest way to install this kit is to remove your carburetors to start with. The Dynojet kit itself should come with some basic instructions, but you'll have to remove the two black caps on the top of the carburetors, pull the springs and the needles out, then replace them with the Dynojet needles. You will also likely choose to flip the carburetors over and take the bottoms out to replace the old main jets with larger main jets to supply more fuel, enrichening the air/fuel mixture since these bikes generally come lean from the factory for emissions and fuel economy purposes.
Though it is typically not mandatory to change to a different air filter or exhaust system, the performance gains would be complimented if you chose to. If you're willing to go that far, you may wish to check these threads about adjusting your mixture screws, shimming your needles, removing your snorkel, and removing your air filter box so you can switch to a filter that's easier to breathe though. Each could potentially make your bike run better: http://www.ninjette.org/forums/showthread.php?t=10246 http://www.ninjette.org/forums/showthread.php?t=9465 http://www.ninjette.org/forums/showthread.php?t=49003 http://www.ninjette.org/forums/showthread.php?t=11963 http://www.ninjette.org/forums/showthread.php?t=10090 http://www.ninjette.org/forums/showthread.php?t=11899 Also, whether you make the purchase or not, if you begin experimenting with different main jet sizes doing it this way saves a lot of time and frustration. One final bit of potential helpful information would be my personal thread with my first experience with jetting, it may help answer some questions that come along the way. http://www.ninjette.org/forums/showthread.php?t=85978 I'm quite surprised no one posted here for you to begin with especially after so long! Good luck an happy jetting!
ATGATT ![]() |
FS: Customled Kit and Area P Full Race Exhaust+Dyno Jet Race Kit | n250r | Motorcycle-related | 7 | January 30th, 2014 03:27 PM |
Dyno Jet Kit stage 2 08 and up | Shaol1n Monk | Motorcycle-related | 2 | February 2nd, 2012 10:56 PM |
Dyno Jet Stage 2 Help. #Jets, Elevation? | Bushmaster11B | 2008 - 2012 Ninja 250R Tech Talk | 15 | April 14th, 2011 11:20 AM |
Rejet?? Dyno jet? | tinng321 | 2008 - 2012 Ninja 250R Tech Talk | 7 | May 9th, 2009 10:43 AM |
DYNO JET KIT query | shporsche | 2008 - 2012 Ninja 250R Tech Talk | 3 | February 26th, 2009 05:23 PM |
