Old February 15th, 2017, 12:22 PM   #1
markg42
Motorcycle(s): 2002 250R
Engine dies if the clutch is released too fast
If I let go of the clutch about an inch short of fully releasing it, which is how far I have to let it go in order to move the vehicle at all, let the vehicle move forward slowly for five seconds or so, then I can fully release the clutch without the engine dying and speed up. But if I let it go all the way, before moving at all, the engine dies.
It's a 2002 model, it's been sitting a while, and all I've done so far is put in fresh fuel with Stabil and Seafoam, change out the oil, change out the battery, and adjusted the clutch. I've been told it I might need to either clean out the carbs or change the spark plugs, which I'll do eventually anyway. Just wondering what you guys think.
markg42 is offline   Reply With Quote
Old February 15th, 2017, 12:50 PM   #2
Welcome Mark!
I am making a few assumptions here but...
1. Clutch lever travel - that sounds normal but check to make sure one/both of the brakes is not dragging and double check to ensure the cable is in proper adjustment. And... letting the clutch all the way out at 0 mph is a sure way to stall the bike or get off to an abrupt start.
2. Stalling on starts - You might just be looking at a tune up and carb clean. Have you checked the air filter and airbox for debris? The 250's friction zone in the clutch is known to be small, are you by chance a new rider? Your skill at feathering the clutch in the friction zone will make this pretty easy when everything is setup and working properly.
Good luck and hope it's something simple to fix.
Old February 15th, 2017, 02:19 PM   #3
taz
taz's Avatar
MOTM - May '17
adding to this another question is, can you drop the clutch on a car with no gas and expect it to not stall? My suggestion is to learn how to release/slip the clutch while adding gas as you go.
Old February 15th, 2017, 02:41 PM   #4
markg42
Yeah, I got my ride in december and haven't started driving it frequently until recently. And I was wondering if the friction zone was supposed to be small, so I guess that might be just it. I'll check that stuff out too, and practice putting on some gas at the same time. Thanks!
Old February 15th, 2017, 02:57 PM   #5
Along the lines of the above posts, if you were to be able to let out the clutch fully without the engine stalling, before the vehicle starts moving, it would mean your clutch is slipping badly and needs repair.
Old February 15th, 2017, 03:19 PM   #6
agentbad
agentbad's Avatar
So when you try this the kick stand is up right??? What's the mileage?
Old February 15th, 2017, 04:02 PM   #7
Guys, I think you're missing this part. I don't know of any motorcycle that won't stall if you let the clutch out all the way before moving at all. This is the way it should behave.
Well, I guess if you have the power to get the rear wheel smoking you might get away with it.
Old February 15th, 2017, 04:59 PM   #8
CaliGrrl
CaliGrrl's Avatar
Motorcycle(s): Ninja650
Welcome to the board!
Old February 15th, 2017, 08:31 PM   #9
Welcome, Mark !!!
I would check the proper free play of the clutch lever and adjust it as needed first.
This is how to do it:
http://faq.ninja250.org/wiki/Adjusting_the_clutch_cable
If you feel you need more practice, just put the bike on the center stand and start the engine and play with releasing the clutch while pressing the rear brake.
Two things may have happened while the bike has been resting:
1) The jets of the carbs got partially clogged.
2) The discs of the clutch dry out and do not fully separate when you clutch-in.
#1 will make the engine hard to start and weak: it takes a deep cleaning.
#2 will make the clutch act like a single disc clutch with very rough and short dragging zone: it takes riding and shifting gears for a little while.
Old February 16th, 2017, 10:03 AM   #10
markg42
Yeah, nothing to do with the kickstand. The odometer reads 6000 miles, though one of the previous owners put down that it the mileage exceeds the mechanical limits, so it might be way more than that.
The clutch has about 2-3mm of free play.
Old February 16th, 2017, 10:07 AM   #11
If you still think something may be wrong, try feeling the two exhaust head pipes shortly after you start the engine, and see if they warm up equally.
Old February 16th, 2017, 01:29 PM   #12
What happens if you let the clutch out quickly (in gear) when it's up on the center stand?
If it doesn't stall, it's an issue with your technique.
Have you taken a basic rider course?
Old February 16th, 2017, 09:01 PM   #13
......The clutch has about 2-3mm of free play.
Please, read this:
http://faq.ninja250.org/wiki/What_is..._at_startup%3F
Old February 19th, 2017, 05:44 PM   #14
juliusmichaelhonrada
Motorcycle(s): GPX250-RII
One thing i know about stalling engines, i once had a 220cc single thumper and when i let go of the clutch slowly it will start to accelerate even without giving throttle , tops at 12kph i cruise like that in our small village lol
juliusmichaelhonrada is offline   Reply With Quote
Engine Issues: Bike Dies when given throttle? Largo 5.0 2008 - 2012 Ninja 250R Tech Talk 19 August 4th, 2021 05:12 AM
Tried to adjust the clutch. Now the bike dies as soon as I start to release clutch! Wanderer 1986 - 2007 Ninja 250R Tech Talk 19 October 7th, 2016 08:17 AM
Engine Bogs and dies? xlatinox 1986 - 2007 Ninja 250R Tech Talk 4 February 19th, 2011 12:24 AM
Engine dies @ +70 mph. Memengkamatis General Motorcycling Discussion 4 December 16th, 2010 09:08 AM
Engine Dies w/ throttle + shimming needles kevlarorc 2008 - 2012 Ninja 250R Tech Talk 19 October 20th, 2010 08:19 PM
