Old August 10th, 2013, 10:47 AM   #1
greenmachine
Motorcycle(s): Green Ninja 250 2008!!!!
Question Clutch not fully engaging?
When I start my bike it moves forward about 2-3 inches as the engine fires, in gear, clutch pulled in. I assume this is because my clutch is not engaging all the way, which means it would be wearing down my clutch at reds lights and such and thats no good. Also, the swingarm where the clutch cable attaches to the engine does not go as far back as it can, when i release the clutch I can push it back another 3 centimeters as if my cable is perhaps gunked up and not sliding in its casing?
Also, I plan on fixing my slightly tweaked handlebars today, if someone would be kind enough to link me information on the torque specifications for the pinch bolts on the front forks.
greenmachine is offline   Reply With Quote
Old August 10th, 2013, 10:51 AM   #2
Normal. There's always a little clutch drag. It's not really wearing anything, it's just light pressure. Same thing when you put a bike up on a rearstand. In 1st, with the clutch pulled in, the rear wheel will still rotate. It sometime will even rotate in neutral.
That's why you always hold one of the brakes on when you shift into first gear from neutral. If the clutch drag is enough to move the bike forward even with the brakes on, then there is a problem, but otherwise, you're fine.
Old August 10th, 2013, 12:18 PM   #3
Originally Posted by greenmachine View Post
..........Also, I plan on fixing my slightly tweaked handlebars today, if someone would be kind enough to link me information on the torque specifications for the pinch bolts on the front forks.
http://www.ninjette.org/wiki/Fastene...Specifications
15 ft-lb upper and 22 lower.
Cold oil induces more drag due to its high viscosity.
After the engine is hot, the effect should be reduced.
Are you sure about those 3 cm?
The cable heads and the hand lever do not have so much range of movement.
Old August 10th, 2013, 01:05 PM   #4
greenmachine
Yeah, it was resting at about 2-3 cm above where it could have been, IE you could push tiny swingarm down that 2 cm after you had already released clutch and it was resting, I went out to buy me some spools and my dad fixed it though... Everything is tight now and it doesnt lurch when fired up and the cable moves smooth, my dads a boss i guess lol
Why is my Clutch not fully engaging? Kbeezer101 1986 - 2007 Ninja 250R Tech Talk 16 November 23rd, 2012 06:12 PM
Clutch doesn't fully disengage power when pulled in. reaubideux 2008 - 2012 Ninja 250R Tech Talk 11 November 3rd, 2011 10:11 AM
Clutch not fully disengaging. Mountain Dew 2008 - 2012 Ninja 250R Tech Talk 5 September 12th, 2011 09:17 PM
Engaging clutch to shift.. Penguin250 Riding Skills 25 May 29th, 2011 08:03 PM
Help Please! Clutch not engaging! splittrain 2008 - 2012 Ninja 250R Tech Talk 13 August 19th, 2010 01:43 PM
