August 21st, 2013, 01:51 PM | #1 |
WOT WOT WOT
Join Date: Jul 2013 Motorcycle(s): '12 Ninja 250R Posts: 421
Left handlebar controls on new gen?
Parts diagram on Kawi's site isn't too helpful. It's all taken apart as in the choke lever is completely separated.
Are there any pictures showing how to put all of it back together? What I should have done is just loosen it up and slip the whole assembly out when replacing the handlebars but what's done is done. D: |
August 21st, 2013, 01:58 PM | #3 |
WOT WOT WOT
August 21st, 2013, 02:58 PM | #5 |
WOT WOT WOT
August 21st, 2013, 05:07 PM | #8 | |
What is impossible is to describe how-to. I cannot even remember it in detail. A helper would be a nice touch.
August 21st, 2013, 06:34 PM | #9 |
WOT WOT WOT
Guess I'm winging it. I'd imagine it wouldn't be that much more difficult than putting the right control assembly back together.
August 22nd, 2013, 07:24 AM | #10 |
WOT WOT WOT
Yep, it was easier than I thought.
It's amazing how Kawasaki made the bike. Everything just fits together like a puzzle. The choke cable had a little plastic piece that slides right into the rear of the left handle bar control, then there's a little piece of plastic on the rear piece that fits into a hole made in the handle bar so that it's at the correct distance. Then of course everything is plug and play like a PC tower. I've been told the old gens weren't that easy. Oh man, if anyone needs to get introduced to wrenching, this is the bike to start on. |
August 22nd, 2013, 07:25 AM | #11 |
August 22nd, 2013, 07:39 AM | #12 |
Big Dreams, Small Wallet
Join Date: Feb 2013 Motorcycle(s): 08 Ninja 250R (Sold), 93 VFR750F (In Pieces) Posts: 508
I actually understand that...
As for Kawasaki engineering...
~BRad |
August 22nd, 2013, 07:40 AM | #13 |
WOT WOT WOT
August 22nd, 2013, 07:46 AM | #14 | |
Join Date: May 2013 Motorcycle(s): 2003 Kawasaki Ninja 250 Posts: 154
It doesn't look hard. The choke cable fits into a little channel, and the lever fits into the same channel, with the end of the cable fit into it. The housing has a little pin that lines up with a hole in the handlebar. You just get that pin lined up with the hole, and screw the whole thing back together. The clutch handle perch can then be reinstalled, and the clutch switch reconnected with the electrical connector. Slide the grip on, reinstall the bar end, and you're done, I think. If reassembling the right-hand side is any indication, the hardest part will be holding the choke cable and lever in place while lining the pin in the switch housing up. |
August 22nd, 2013, 08:03 AM | #15 |
I work for a Logistics and Warehousing company (sorta)... So FIFO is king when you have items that expire.
~BRad |
August 22nd, 2013, 08:07 AM | #16 | |
If you have lived the pic below.... you know.
August 22nd, 2013, 09:25 AM | #17 |
How the Business sold is and how it was documented are my favorites!
We actually showed that in as a slide in a QBR once.
~BRad |
August 22nd, 2013, 03:52 PM | #18 | |
WOT WOT WOT
@csmith12 -- I really that pic, it speak volumes. |
WTB: (300 or 250) OEM left handlebar, left rearset, left mirror | iamakitkatbar | Items Wanted | 7 | September 1st, 2014 03:33 PM |
WTB pregen handlebar controls | Kirin240 | Items Wanted | 0 | June 12th, 2013 05:01 PM |
WTB pre-gen left handlebar in SoCal TONIGHT | cookiebug79 | Items Wanted | 20 | February 27th, 2013 11:56 PM |
Decent Aftermarket Left Handlebar Controls (Lights/Signals/Horn) | indr | 2008 - 2012 Ninja 250R Tech Talk | 3 | October 8th, 2012 05:31 PM |
left hand controls 95 bike 05 controls | mapolley07 | 1986 - 2007 Ninja 250R Tech Talk | 12 | December 22nd, 2011 10:05 AM |
