October 13th, 2013, 12:15 PM | #1 |
Join Date: Jan 2013 Motorcycle(s): 1987 Ninja 250 custom gold Posts: 218
Something loose in the front end
Hey all,
So i have noticed that when i ride the bike, something doesn't feel good when I lean to turn. This problem has existed for a while, but i had bigger issues to deal with at the time. Originally i thought it may be the tires or something I couldn't describe, but then when i let a Kawasaki mechanic ride it, he told me that something is "loose." I have already re-adjusted the handlebars by loosening the triple clamp and tightening in the correct position, this helped with going straight when my handlebars were straight. I am running the Dunlop K330 which i have heard give "unpredictable control" if that makes a difference. In more detail: Whenever i lean to turn, it feels like the wheel naturally wants to resist the turn and go straight, its not a continuous pull, but more like pulsing. Sorry for the bad explanation... :\ Any help would be appreciated. P.S. i need to replace my steering bearing, if that may cause this issue. |
October 13th, 2013, 12:19 PM | #2 |
Join Date: May 2011 Motorcycle(s): 2011 Ninja 250R SE GREEN! Posts: 562
Replace the bearing and go from there, you already know it needs to be replaced
Trust me, I'm a banana! |
October 13th, 2013, 12:24 PM | #3 | |
Join Date: Dec 2011 Motorcycle(s): '86 VFR 750, '90 ZX7, '92 KZ1000, '05 ninja 500, '05 6RR, '06 10R, '07 ninja 250 Posts: 122
October 13th, 2013, 12:34 PM | #4 |
Could that really cause something to feel loose in the front end?
What are the simptoms of having a worn steering bearing? (i already know the notching that you get when you turn the handlebars). |
October 13th, 2013, 12:45 PM | #5 | |
Your steering geometry will be out of whack so to speak. Poor feedback from the frontend plus the notchy explaination from your previous post. |
October 13th, 2013, 01:55 PM | #6 |
You sure it needs replaced? Is there a popping sound when push down on the forks? Try to tighten it up a bit before replacing. You could also take it out repack with grease and tighten as needed. Otherwise, you have it in front of you and know what you need.
October 13th, 2013, 02:05 PM | #7 |
Well, when i was getting it safetied, they told me that it needs that bearing replaced, they opened it up and re-adjusted it, but that was only temporary. If i am going to dig that deep to repack them, i would much rather replace them, after all, i do not know the history of the previous 13 owners with this bike in the past 26 years...
October 15th, 2013, 03:11 PM | #8 |
sail away
Join Date: Jul 2012 Motorcycle(s): gixxer (sold), ninjette (upgrade!) Posts: 964
Have you checked your front tire pressure?
Replace with tapered roller bearings if possible. The bearings are literally a few balls of steel. If one gets dented or dimpled enough, the whole thing acts funny.
Unregistered found this post helpful. Track Day Preparation Checklist 1. Financial 2. Mental 3. Physical 4. Gear / Bike |
May 27th, 2014, 02:56 PM | #9 |
Check your engine mount bolts and look for a bend in the frame under the tank.
Upgraded front suspension, front end tuck | Ginganinja | 1986 - 2007 Ninja 250R Tech Talk | 12 | October 30th, 2014 10:27 AM |
Front fairing seems loose. | agentbad | 1986 - 2007 Ninja 250R Tech Talk | 5 | October 10th, 2014 10:03 AM |
1999 Ninja 250r - When riding front wobbles/feels loose | 99Ninja | 1986 - 2007 Ninja 250R Tech Talk | 4 | August 25th, 2014 05:31 PM |
15t front sprocket loose | Lewis3845 | 1986 - 2007 Ninja 250R Tech Talk | 2 | March 10th, 2014 02:07 PM |
WTB 08+ Front Brake lever/Bar End/ Front Turn Signal | 1LoneWolf | Items Wanted | 3 | July 8th, 2013 02:50 AM |
