Old May 30th, 2017, 08:06 PM   #1
mrtransit15
Motorcycle(s): 2011 Ninja 250
Turn signal issues
I started having trouble with my turn signals on memorial day weekend.
problem, my right turn signals front and rear are blinking but when i use the left turn signal nothing happens except i here the flasher buzzing not clicking.
Is the problem the relay or is there a short in the wiring? The signal lights are the original lights NOT LED.
would appreciate any help, thanks.
mrtransit15 is offline   Reply With Quote
Old May 30th, 2017, 08:23 PM   #2
tfkrocks
tfkrocks's Avatar
MOTM - Jan '18, Sep '13
mrtransit15! Glad to have you aboard...
My Ninja 300
Old May 30th, 2017, 08:56 PM   #3
Lairot
Motorcycle(s): 2002 Ninja 250r
Sounds like a relay issue, a short would have likely blown a fuse and looking at the wiring diagram neither signal would work then.
Lairot is offline   Reply With Quote
Old May 31st, 2017, 04:59 AM   #4
Z1R rider
Z1R rider's Avatar
MOTY - 2018, MOTM - Oct '16
I doubt it's the flasher relay, there is only one flasher to do duty on left or right blinker circuit. I'd start by looking at the bulb sockets on the left side and work my way back towards the flasher.
Here's a diagram, scroll down to post #26
https://www.ninjette.org/forums/showthread.php?t=35886
and welcome to the board!
Old May 31st, 2017, 07:34 AM   #5
mrtransit15
thanks
Old May 31st, 2017, 01:22 PM   #6
Ghostt
Ghostt's Avatar
Don't forget to check and clean the actual turn signal switch on the forward control.
violente et ignorantia
ZX-2R BLOG
Old May 31st, 2017, 02:09 PM   #7
CaliGrrl
CaliGrrl's Avatar
Motorcycle(s): Ninja650
Welcome to the board!
Old May 31st, 2017, 03:43 PM   #8
mrtransit15
thank you, tfkrocks and Cailgrrl
Old May 31st, 2017, 03:54 PM   #9
mrtransit15
turn signal issue
Thank you All who helped with my turn signal issue. Spent my afternoon taking apart all fairings and seats to get to the wiring and relay. also took apart all the wires connected to the left turn signal lights and removed all electrical tape and plastic tubing that held the wires together. wiped them clean and retaped all wires and out of no where my turn signals are working again. Might have been a wire touching a ground surface.
And thanks for the wiring diagram Z1R rider.
Thank you All
Old May 31st, 2017, 04:22 PM   #10
Z1R rider
Z1R rider's Avatar
Glad you got it figured out!!
Old May 31st, 2017, 04:25 PM   #11
Wanderer
Motorcycle(s): 2007 Ninja 250 and 1991 Yamaha Virago XV750
Bad front or rear bad bulb on the left hand side?
Wanderer is offline   Reply With Quote
Old June 4th, 2017, 08:32 AM   #12
Snake
Snake's Avatar
Hello and welcome!
Old June 4th, 2017, 06:36 PM   #13
snot
sammich maker
snot's Avatar
MOTM - Apr '15
Welcome
Turn signal wiring issues StuntPuppy 2008 - 2012 Ninja 250R Tech Talk 5 February 25th, 2017 06:25 PM
Front turn signal issues... snowman7 1986 - 2007 Ninja 250R Tech Talk 6 June 30th, 2013 07:21 AM
Turn Signal Issues dsmisfits 2008 - 2012 Ninja 250R Tech Talk 9 December 19th, 2012 09:16 PM
HELP ASAP please! - turn signal issues SafetyPaws 2008 - 2012 Ninja 250R Farkles 31 June 25th, 2012 07:05 PM
Turn Signal Indicator Issues menikmati 2008 - 2012 Ninja 250R Tech Talk 9 December 12th, 2011 08:17 PM
