September 5th, 2012, 12:48 AM | #1 |
Intrepid Adventurer
Join Date: Jan 2012 Motorcycle(s): 2004 GSXR 750 , 71 cb350streettracker, 07 Polaris Predator 500 Posts: A lot.
2008 ninja only runs on choke at idle
My 08 sat for a couple years since it first owner crashed it.
I got it and put bars on it and patched a hole in the radiator then started ridding it down back country roads . Well I let it sit for most of this last year since I got my cruiser. -I drained the fuel and it was totally shot/ refilled with gas treated with marine grade stabil -The battery shot / replaced it with AGM bat like stock -oil change w filter -checked air box and filter for mice ect and it's uninstructed When I start it it will only start with choke on It will only idle w choke indefinitely , if you twist the throttle it stalls If you turn down the choke it stalls I am going to pull my carbs this weekend I am thinking gummed up jets????? Also it never ran right originally It has a yoshi slip on and stock jets and air filter Should I re jet or just change the stock jetting and remove my snorkel Is a k and n worth it or just keep te stock air cleaner ? What ya think? |
September 5th, 2012, 04:33 AM | #2 |
pull and clean carbs - check
desnorkle - check shim needles - check try that before swapping out to pods.
September 5th, 2012, 10:57 AM | #3 |
Intrepid Adventurer
Thanks . I wasn't sure if there was some thing electrical that could cause these symptoms
September 5th, 2012, 12:14 PM | #4 |
ninja 250R + sitting + won't start/idle/well = carb cleaning.
September 5th, 2012, 12:40 PM | #5 |
Join Date: Jul 2012 Motorcycle(s): (Sold) 2007 Red Ninja 250r, 2003 Cbr 600 F4i Posts: 137
My ninja doesn't even need choke to start and go. Always puzzled me.
September 6th, 2012, 09:00 AM | #6 |
Pimpin
Join Date: Nov 2008 Motorcycle(s): Bunch of em Posts: 973
Pilot jets are clogged.
Dying at idle with choke off | jonnybravo9 | 2008 - 2012 Ninja 250R Tech Talk | 6 | October 2nd, 2014 09:17 PM |
09 Ninja 250r wont stay idle without choke | TqAmsNy | 2008 - 2012 Ninja 250R Tech Talk | 11 | March 20th, 2013 01:38 PM |
Idle jumps to 9000 rpm on choke then wont stay idle after off | Shawn250 | 2008 - 2012 Ninja 250R Tech Talk | 1 | June 19th, 2012 06:45 AM |
Bike only runs on full choke!! | UjaasG35 | 2008 - 2012 Ninja 250R Tech Talk | 13 | May 15th, 2012 06:49 PM |
Choke has no effect on idle... Help. | Jono | 1986 - 2007 Ninja 250R Tech Talk | 15 | September 14th, 2011 09:45 PM |
