April 17th, 2013, 10:25 AM | #1 |
Noob
Join Date: Apr 2013 Motorcycle(s): 2009 Ninja 250r Posts: 11
Yoshi TRC slip on
Has anyone installed the yoshimura trc slip on and if so did you have to re-jet? it says they recommend a stage 2 re-jet but it seems like tons of slip ons don't need it. Thanks
Gibbed |
April 17th, 2013, 10:29 AM | #2 |
You should be fine with just 2-3 washers under the stock needles. If you haven't already done that, it's a fine mod for even the stock can.
April 17th, 2013, 10:44 AM | #3 |
Noob
have not done that I don't even really know what that means but I will look up the DIY on here and see if I can't do it sometime soon. Thanks!
Gibbed |
April 17th, 2013, 10:48 AM | #4 |
April 17th, 2013, 11:14 AM | #5 |
Jigglin' your Jiglets
MOTM - Apr '13
Don't get a pansy ass slip on, get a full pipe!
April 17th, 2013, 12:08 PM | #6 | |
Make sure you use the type of screw driver it tells you to in the DIY. I stripped the screws and had to get new ones because i didnt follow directions.....
08 250R - White |
April 17th, 2013, 12:40 PM | #7 |
Might as well replace the screws with the alen/hex head while you have it apart.
April 17th, 2013, 06:02 PM | #8 |
Noob
Thanks I am going to order it tomorrow and hopefully get it on next week.
Gibbed |
Yoshi TRC Slip-On.. | justinocean | 2008 - 2012 Ninja 250R Farkles | 25 | June 4th, 2014 08:56 PM |
FS/FT: 08+ Yoshimura TRC Carbon Fiber Slip-On | radi4fun | Motorcycle-related | 7 | July 5th, 2013 02:30 PM |
Yoshimura TRC Slip-On for Ninja 250 | Bones85 | Motorcycle-related | 2 | February 9th, 2013 12:21 AM |
Yoshi TRC Cf full exhaust ninja 250 08 | wellcraft | 2008 - 2012 Ninja 250R Tech Talk | 8 | August 3rd, 2010 09:10 PM |
Yoshi TRC Cf full exhaust ninja 250R | wellcraft | General Motorcycling Discussion | 7 | January 23rd, 2010 06:40 AM |
