July 1st, 2016, 02:20 PM | #41 |
There's something different with the ignition pickup between the Europe-spec fuel injected bike and the US-spec carbureted bike for the 2008-2012 generation.
Search for threads with the batman guy who did an OE fuel injection swap on his USA spec 2008-2012 bike with all factory parts from Europe. It was a sweet bike that made great power. It was his track-only bike and he won some races with it. I think it had a Leo Vince exhaust and the fairings were yellow with blue and green iirc. He gave some more information at some point about what was needed for the complete swap. |
July 2nd, 2016, 12:29 AM | #42 | |
I really don't want to convert this bike to injection, it would be more cost effective to buy a newgen bike and break my ZZR for spares, although I don't want to do that, I rather like the ZZR style. I am showing my age now. |
July 2nd, 2016, 05:23 AM | #43 |
July 2nd, 2016, 06:22 AM | #44 | |
I did a search for batman's post could not find it. When I get a bit more time to sit at the computer I will try again, but at least the comments so far have been positive. |
July 2nd, 2016, 08:40 AM | #45 |
His user name is Shadowwolf1117 The bat logo is on his leathers. Or maybe i'm remembering someone else.
This is his sale thread: https://www.ninjette.org/forums/showthread.php?t=260228 Scroll through this thread for all his info on what he changed. It's a long thread, but there's plenty of info in it that should help you out: https://www.ninjette.org/forums/showthread.php?t=95095 |
July 24th, 2016, 10:49 AM | #46 |
Well my search for a newgen engine didn't produce anything for a sensible price, but I did find this.
2011, one middle aged lady owner from new, 4600 miles and only 35 miles down the road from me. I could not let that get away. And now I will have to change my user name. Thanks for all the advice offered, even if it did turn out not to be needed. Ninja 250R.jpg Last futzed with by ZZRIvy; July 24th, 2016 at 10:56 AM. Reason: spelling |
July 24th, 2016, 11:35 AM | #47 |
Join Date: Nov 2012 Motorcycle(s): 2012 Ninja 250R, 2007 Ninja 650R, 2001 F650 Dakar Posts: A lot.
Oh, nice! Congrats on the new bike.
July 24th, 2016, 10:54 PM | #48 |
Join Date: Jul 2016 Motorcycle(s): '05 Ninja 250, '80 KZ750 Posts: 21
I sold my '82 kz440 that was my commuter and I bought my '05 for that role because parts were easier to find and the aftermarket was more extensive! If y'all have trouble getting quality parts for a pregen, try it for a 70's era Kawasaki.
July 25th, 2016, 05:25 AM | #49 |
Join Date: Dec 2015 Motorcycle(s): 2007 Hoodrat 250 Posts: 242
Did anyone have issues with the top motor mounts? I can only get one side to align.
"Brah, you can't be looking like that on a 250, brah. You gotta mod a 250, brah. It's like the hachi-roku of bikes." |
October 22nd, 2016, 04:57 PM | #50 | |
Eric, how different are the engine mounts between newgen and pregen? You sure the wiring is the same? I'm debating the swap to newer.
Are you able to share some more about your bike? I'm curious on what you find for the exhaust. |
October 23rd, 2016, 11:45 PM | #51 |
Join Date: Dec 2011 Motorcycle(s): Ninja ex250 1990 Posts: 761
i had to grind both sides on my pregen to get the top mount to fit.
1990 250F. ex300 motor swap, 15/42 gearing, flush side markers, newgen intergrated front fairing, rear integrated turn signals, DB Touring Bubble, zx600 rear shock, Custom DanMoto Exhaust |
October 23rd, 2016, 11:49 PM | #52 | |
Ask your questions. Bike still runs strong. Very efficient. The stock 300 header clears on the pregen but needs to be extended about 1 1/2 inches outwards and rotated upward 15 degrees to match the stock pregen header. And i just put a Dan Moto can on the end. Sounds nice. If anyone needs pics or anything just ask or any information. Engine swap takes minutes to do. Harness and wiring took me a few hours a day for a few days. But yes everything does fit on the pregen and fits inside the fairings etc.
October 24th, 2016, 03:55 PM | #53 | |
IIRC, you're running it with carbs and had to do something to make it work with the CDI? What's the jetting look like? You said you had to modify the motor mounts? Pictures and/or explanation? What's the OD of the 300 header at the point where it goes into the can? |
October 24th, 2016, 08:57 PM | #54 |
Join Date: Oct 2016 Motorcycle(s): 98 Kawasaki 250 Posts: 6
I bought a very clean 1998 ninja 250 with a rebuilt engine. The engine is a 2008 kawasaki 250 engine with 19K miles on it. The engine was rebuilt because the old one sat too long. I bought it 5 days after it left the service shop.
The engine at idle when I start it sounds really good and when you rev it, it sounds good too. But when it revs down or when you let off the throttle it has a weird like rumbling noise. Its not pings, pongs, clicking, squeaking, the best way I can explain is like it has asthma and under pressure, like its trying to exhale. Is that normal idk?? Its like a really bad depressing asthma with really bad bronchitis sigh...??? When I let off the throttle and when I turn the throttle it jumps. I have to slowly literally millimeters pull the throttle to not let it jump. This is probably just lube the throttle cables? The 250 would warm up at around 15-20 minutes at 45F o 8C. I would then take it off the choke and it wouldn't stay on. It cranks right up with choke all the way when cold but after it warms up I take the choke off it idles slowly down and then shuts off. When I contacted the person it was last serviced, the person who rebuilt it, he said all it needs is the petcock replaced because its old and thats whats clogging up the fuel line. Why I haven't visited a mechanic is because I'm short on time and most of the shops open late and close early?_? My questions are(if there are other threads that help answering please post them): What can I do or what did the mechanic forget to do for a bike that has been sitting so long that had its engine rebuilt forgotten to do? What tools do I need to be able to service my own bike? -clean carbs -clean petcock -clean pilot jets What would you do in this situation(aside from ride the bike off the nearest cliff or lake)? What are some checks you would do? Yes I'm a total newb, but I did the most basic stuff when I went to buy it. Made sure everything mechanically was good, oil was right color/level, no rattling, made sure frame was good(wasn't wrecked), gas tank was nice and clear not milky,? Aside from all of this I can ride the bike just fine, I just haven't took it past 50mph... Any criticism is appreciated as long as you have some helpful advice. Edit: I can't get the bike to a mechanic because I'm at work most of the week everyday -_- |
October 24th, 2016, 09:44 PM | #55 |
Superiorknightz: I replied to your post over on Ninja250.org
also, now that you're here you should look at the Ducatiman carbs thread. |
October 25th, 2016, 07:06 AM | #56 |
Thx Greg
November 20th, 2016, 08:43 PM | #57 |
Join Date: Aug 2016 Motorcycle(s): 2004 ninja ex250, 1996 Honda cbr900rr Posts: 31
Congrats on the new bike!
January 20th, 2017, 07:18 AM | #58 |
Join Date: Nov 2016 Motorcycle(s): 2008 Ninja 250R, 1986 Ninja 250R (x2) '06 ZX6R 636 Posts: 88
January 20th, 2017, 07:46 AM | #59 |
January 20th, 2017, 07:56 AM | #60 |
re:
Weird...it qouted highvoltj sucks at riding (me) and I don't believe I have ever met!!
May 13th, 2017, 06:18 PM | #61 |
Join Date: Feb 2017 Motorcycle(s): 07 250 ninja , 97 600 ninja Posts: 17
May 13th, 2017, 06:25 PM | #62 |
May 13th, 2017, 06:51 PM | #63 |
May 14th, 2017, 01:06 AM | #64 |
June 3rd, 2017, 06:52 PM | #65 | |
June 3rd, 2017, 07:38 PM | #66 |
Charles, funny you bumped this thread today. I was just working on my swap.
RacerX is right, the electrical connectors all appear to be identical. Wire lengths, connectors, locations for terminals, etc. No concerns there. The exhaust flange design is definitely different between generations as well. The way the header mounts to the head and seals is different. I have a newgen exhaust on order from Tyga. Hopefully the hanger/clamp setup is flexible enough to allow it to hang on the pregen. (I bet it's fine) The upper mount presents the fun part of this. The meat at the mount point on the pregen head is ~120mm wide. The mount bolt goes through the left side bracket and threads into the right side bracket. The mounts are the same style for the newgen, but the material at the mount point was beefed up to ~130mm from my measurements today. From eyeballing it, it looks as though the added width on the newgen is symmetrical and both pregen front mounts need to have 5mm taken off of them. Or... use the newgen front mount brackets, but RacerX tells me that the pregen radiator mount pattern is different than the newgen radiator mount pattern, so if you're not wanting to modify things, you'll have to pair a newgen radiator with newgen front mount bracketss or a pregen radiator with pregen front mount brackets. I'll share whatever I end up doing as I get there. I'm thinking of machining just because I have such a nice machine shop at my disposal, but we'll see how that goes. The brackets might be a bear to mount up square on the Bridgeport. EDIT: The good news is the rear two mounts are identical. My newgen engine is currently dangling in my frame by just the two rear mount bolts. No worries for now. |
June 4th, 2017, 06:13 AM | #67 | |
June 4th, 2017, 04:41 PM | #68 | |
June 4th, 2017, 05:29 PM | #69 | ||
No idea. I don't know why that would change anything related to the physical dimensions of the engine though. Likely just the fueling and/or ignition timing are different between regions of sale to comply with the laws for that area. Example: California model vs the standard 49 state model of pregen.
I bought a complete radiator, engine mount brackets, mount bolts, and all the cooling hoses from a newgen off fleabay for $50 shipped. $50 is worth my time and sanity. You're doing a fairly painless engine swap, don't shy away from $50. |
June 7th, 2017, 07:57 PM | #70 |
Join Date: Aug 2015 Motorcycle(s): 2013 Ninja 300 Posts: 37
June 8th, 2017, 03:25 PM | #71 |
Newgen motor mounts (and the one newgen bolt for the front mount) work great. I ground off the welds for the newgen coils so I can bolt up my pregen coils. Bueno.
The newgen radiator is too wide for the bodywork, so I'll be making a bracket to run the pregen radiator. Not sure if I'm using 1/8" metal (likely steel or aluminum, whatever is available at work) or 3/16" ABS sheet (depending on some research into temp ranges). I have a water jet and light duty laser cutter at my disposal, so I have some flexibility there. After that, I need chain and sprockets because mine are worn, and I need to figure out if the airbox fits or if I will use pods. Then clean the carbs because they've been sitting so long |
February 7th, 2018, 07:11 AM | #72 |
I havent touched a motorcycle in over a year.. Lets go.
January 3rd, 2019, 07:58 PM | #73 |
Join Date: May 2018 Motorcycle(s): 2007 Ninja 250r Posts: 11
I just finish putting newgen engine into a pregen bike and we did not need newgen motor mount. Fits in old one just fine.
January 3rd, 2019, 09:02 PM | #74 | |
Did you bend the tabs on the frame that the motor mounts bolt up to? |
January 3rd, 2019, 09:33 PM | #75 |
Very little grind a bend. Much easier then try new motor mount.
January 5th, 2019, 04:26 PM | #76 |
I'm not planning on doing this swap or anything, I'm just asking out of curiosity.
Does Ninja 400 engine fit? I believe Ninja 400 and 250 have the same external dimension? (Ninja 400 for US/Canadian market, 250 for Asian/European) |
January 5th, 2019, 06:29 PM | #77 |
No way will 400 fit. Engine mounting points are completely different. Not to mention sub-frame and rear swingarm is attached to 400 engine. So you'll need to chop off entire rear section of 250-frame and use 400 sub-frame and swingarm.
Look up Bruce's engine-builds, actually got more power from them than stock 400. |
January 5th, 2019, 06:35 PM | #78 | |
January 7th, 2019, 11:36 PM | #79 |
Join Date: Jan 2018 Motorcycle(s): 2007 Ninja eX250 Posts: 49
Sorry for me to jump in on this, but it’s dont I just keep having problems, got a 300 from Craigslist, crank was bad apparently, then it was timing chain and tensioner, and now after finding the timing jumped on the chain, the flipping intake cam shaft broke. I am running the 300 with pregen lectricals, need to make a bracket for the radiator, new 300 front motor mounts. Soldered an extension for the oil sensor. And installed a aftermarket radiator fan (low profile) I should have an update on my page but I am waiting on a carb jet kit
January 7th, 2019, 11:39 PM | #80 | |
Will Newgen crankshaft fit in my pregen? | wankerboy | 1986 - 2007 Ninja 250R Tech Talk | 17 | March 5th, 2015 04:17 PM |
Newgen exhaust on pregen? | !!(0_o)!! | 1986 - 2007 Ninja 250R Tech Talk | 26 | April 16th, 2013 08:26 PM |
pregen engine in newgen? | alex.s | 2008 - 2012 Ninja 250R Tech Talk | 6 | October 19th, 2012 11:09 PM |
Are the newgen and pregen cranks the same? | n4mwd | 2008 - 2012 Ninja 250R Tech Talk | 2 | July 26th, 2012 12:27 PM |
Pregen vs. Newgen | ambudriver | General Motorcycling Discussion | 7 | May 7th, 2011 07:36 PM |
