Old February 10th, 2016, 09:56 PM   #1
daverdfw
Motorcycle(s): 2009 Ninja 250
At wits end trying to bleed front brake after new line install
So I installed new SS brake line. And have been trying to bleed the brake. NO matter how many times I pump the lever, I never feel any pressure build up. Have tried reverse-bleeding by using a syringe on the caliper end. Is there still just too much air in the system? Do I need to get a vacuum pump?
daverdfw is offline   Reply With Quote
Old February 10th, 2016, 10:00 PM   #2
RacinNinja
Vintage Screwball
RacinNinja's Avatar
MOTM - Mar '16
Here's what works for me, YMMV.
Leave the bleeder open, with a hose attached, in a container with CLEAN brake fluid in it. Pump the lever until fluid moves from the master cylinder.
Now you can bleed as normal.
Goin' fast on slow bikes!
Old February 10th, 2016, 10:07 PM   #3
daverdfw
yeah I started trying that, but it never pushed much fluid out , dribbles at best. I guess just keep going to get all the air out?
Old February 10th, 2016, 10:17 PM   #4
RacinNinja
Vintage Screwball
RacinNinja's Avatar
MOTM - Mar '16
When I did mine, it took a minute or three of pumping before things happened. Don't pump slow, put some effort into it.
Old February 10th, 2016, 10:27 PM   #5
daverdfw
it just worked! Thanks! Now I gotta get the pads separated so I can put the wheel back on!
Old February 10th, 2016, 10:29 PM   #6
RacinNinja
Vintage Screwball
RacinNinja's Avatar
MOTM - Mar '16
Good job!
Old February 10th, 2016, 10:30 PM   #7
daverdfw
Good job!
I appreciate your quick help! This forum rocks!
Old February 10th, 2016, 10:37 PM   #8
Video for reference on the "bleed tube" method. Use a Mt. Dew bottle for added braking power. hahahahahahahah
Old February 10th, 2016, 10:40 PM   #9
daverdfw
how do you mark a post as helpful on here?
Old February 10th, 2016, 10:52 PM   #10
It's a perk you get after reaching 1k posts, you're well on your way.
Old February 10th, 2016, 11:02 PM   #11
I did it for you
Old February 11th, 2016, 05:58 AM   #12
adouglas
adouglas's Avatar
Motorcycle(s): Aprilia RS660
erm....
you're supposed to bleed with the wheel on the bike....
Be careful when you pry the pads apart. That displaces fluid, which will move back up into your reservoir. If the reservoir is already near full, you might have a mess on your hands as it overflows.
It's also easy to damage the pads.
Old February 11th, 2016, 10:18 AM   #13
daverdfw
erm....
Yeah I kinda realized that halfway through, I am going to take the pads off, and use a C-clamp to push the piston back
Old February 11th, 2016, 10:24 AM   #14
HoneyBadgerRy
HoneyBadgerRy's Avatar
69 down, 931 more to go.
Old February 11th, 2016, 10:32 AM   #15
SLOWn60
n00bie to wannabie
SLOWn60's Avatar
Motorcycle(s): 2012 250R (Red), 2005 VFR800A (Red), CRF450X (Red), 2012 F800GS (Wants to be Red!)
MOTM - Nov '15
No need! Just use a large, wide blade flat screwdriver and gently pry on the metal part of the brake pad, not the soft brake material.
The Smart Money: #1 - ATGATT, #2 - Training (machine skills and survival skills), #3 - The bike; whatever floats yer boat with the money you have left over
SLOWn60 is offline   Reply With Quote
Old February 11th, 2016, 10:34 AM   #16
If everything is right, you should be able to compress the pads with your hand. If not, it's not clean enough. ijs
But yea, the metal backing part of the pad is safe to pry against.
Old February 12th, 2016, 09:49 AM   #17
Ralgha
Ralgha's Avatar
Really? I better get posting!
Old February 13th, 2016, 02:54 AM   #18
hfd1 tuner
Motorcycle(s): many mostly racebikes cbr565 fzr490 ex250ish
Glad you got sorted out I have a TIP for future bleeding problems. If you take the master cylinder off the handle bar with the cap off and hold it at angle so air bubble will come up into the res. you can gently pump lever and watch the air come out. saves you a ton in brake fluid...air rises in line and ends up in master cylinder.
hfd1 tuner is offline   Reply With Quote
Old February 13th, 2016, 11:18 PM   #19
daverdfw
Thanks! this forum has been fantastic helping a new 250 owner learn about how to work on these things. I appreciate everyones help
Old February 14th, 2016, 06:02 AM   #20
adouglas
adouglas's Avatar
Here's an invaluable tip about maintaining your bike.
Brown-bag your lunch for a week or two. Take the money you have saved and
BUY THE FACTORY MAINTENANCE MANUAL.
Just do it. And follow it.
The investment will pay for itself many times over in error avoidance.
Old February 14th, 2016, 03:19 PM   #21
hfd1 tuner
manuals are great because some factory personal wrote down how they thought it was best on how to do something. Never rule out that there maybe a better way to achieve the same result only faster and better.
Old February 14th, 2016, 03:33 PM   #22
2fiddy-trackpair
Motorcycle(s): 2012 250r
Usually you can let gravity do most of the work before you start bleeding with the lever. Even on a dry system the fluid will flow down to the lowest point after a while. When fluid starts dripping out of the bleeder you can close it and start doing the manual bleed procedures.
2fiddy-trackpair is offline   Reply With Quote
Old February 14th, 2016, 04:17 PM   #23
A few brews helps the wait process...
Old February 14th, 2016, 04:18 PM   #24
2fiddy-trackpair
An excellent way to pass the time.
Old March 3rd, 2016, 11:26 AM   #25
Dsheumaker
Dsheumaker's Avatar
Motorcycle(s): 14 Ninja 300 (Track Only), 07 CRF150RB
When i first got my SS line i had a rough time getting it to bleed. Used a vacuum bleeder to get fluid through the line and then went back to the old school manner. IF no air bubbles are coming out at the caliper you may need to bleed your banjo bolt on the M/C.
Dsheumaker is offline   Reply With Quote
Old March 3rd, 2016, 09:55 PM   #26
daverdfw
after I opened the bleed screw more, I was able to pump tons of fluid through.
Wits end. No spark. BLKBLKEvan 1986 - 2007 Ninja 250R Tech Talk 13 March 24th, 2014 04:46 PM
Apex Stainless Steel brake line Install Asspire 2008 - 2012 Ninja 250R Tech Talk 1 August 26th, 2013 09:29 PM
SS brake line install... help? mfresh 2008 - 2012 Ninja 250R Tech Talk 42 March 8th, 2013 12:38 PM
DIY spiegler stainless steel front brake line install 00NissanNinja 2008 - 2012 Ninja 250R Tech Talk 34 August 28th, 2012 08:29 AM
