March 28th, 2012, 10:28 AM | #1 |
Join Date: Mar 2012 Motorcycle(s): '08 Ninja 250R (SOLD - 2/16/2013) Posts: 492
Acceleration issues from a stop
Hi guys,
I got a used '08 about 3 weeks ago. I've been riding it around the block since then every other day. I've cleaned and lubed the chain and also changed the oil and oil filter. The bike does take a while to warm up even after I adjusted the idle speed to around 1500rpm (was idling at ~900-1000 before). The problem I keep noticing because it's very annoying, is that from a dead stop (stop signs, yields, or turns around my block) the bike looses power if I accelerate even a bit suddenly. Example, I'm taking off from a stop, I give it enough gas to take off, it begins moving, so I continue to roll on the throttle to accelerate the bike responds 2-3 seconds later. For those 2-3 seconds I'm feeling like an idiot because I'm only barely rolling along sometimes it even feels feels like the bike is going to die. I have to admit I'm just learning to ride, so I'm not 100% used to the clutch, so I might be releasing the clutch too suddenly and giving too little gas. Although my worries are something backed up by trying to give it throttle while it's just sitting in neutral idling. If it's idling and I try to give it a large amount of throttle suddenly the bike dies. If I smoothly raise the rpm to 3000+ then gas it suddenly everything is fine and the engine responds immediately. I just put 1/2 tank of gas with the appropriate amount of seafoam so I'm waiting to run through that before I do any work, and even then I want to wait 'till we have SoCal tech day to get some help from experienced members instead of taking it to a shop I know nothing about. If you guys have any ideas, or if this is normal for the bike please let me know. Thank in advance guys. P.S. Bike is completely stock, could this be caused by a super filthy air filter? EDIT: http://www.ninjette.org/forums/showt...ght=air+filter A quick search came up with Kkim's shimming thread, and the first thing he mentions are that it solves all of the problem's I've mentioned here, go figure. If it could be anything else, please post it though guys. Last futzed with by edxmon; March 28th, 2012 at 11:32 AM. |
March 28th, 2012, 10:55 AM | #2 |
Join Date: Nov 2011 Motorcycle(s): 2007 Ninja 650R Posts: 317
You're encountering one of the most common problems with a 250R. They don't like to be spurred until they're warmed up. If you're only riding it around the block, you're likely not getting it very warm, and until it's warm, it's gonna be bitchy about how much throttle you give it in the low RPM range. Take it for a real ride and you'll probably notice that this issue clears up when the engine reaches operating temperature.
March 28th, 2012, 10:58 AM | #3 | |
P.S. is that a 250 in your AV? something looks different about it and I like it! |
March 28th, 2012, 11:08 AM | #4 |
If everything is right. With 3-5 minutes of warm up time, it should accept any amount of throttle you want to give it.
Next Steps; Check/New air filter Check throttle cable adjustment Seafoam Shim/desnorkle at a tech day or in your spare time Hopefully your good to go after that.
March 28th, 2012, 11:10 AM | #5 |
A stock Ninja has very little power in the low rpm range. A good & common rpm to launch the bike is close to 3k and above. Trying to launch the bike just off of idle can be done but as you can tell it's not good in a traffic situation. Launching the bike at a higher rpm speed will require a little more twisting of the throttle, something you may have to get used to as a new rider. One caveat of the CV type carbs is a tiny lag in throttle response when snapping open the throttle. This is normal and is due to the slides in the carbs being vacuum operated as opposed to being mechanically operated by the throttle cable.
Being that you bought the bike used a little preventive maintenance should be in order. One item that is included in that maintenance checklist is the air filter. And yes, a super dirty air filter can cause throttle response problems. It is easy to check and clean or just replace. Shimming of the needles will help a little with throttle response in the low rpm range (about 1/8 throttle) but is most effective in the 1/4-3/4 throttle (midrange). My suggestion would be to continue practicing riding the bike and getting more familiar with the clutch, throttle and engine operating speeds. Once you are comfortable with that then look at doing intake mods. |
March 28th, 2012, 11:17 AM | #6 |
March 28th, 2012, 11:29 AM | #7 | |
March 28th, 2012, 11:31 AM | #8 | |
Join Date: Mar 2012 Motorcycle(s): 2003 Ninja EX250 blue Posts: 78
March 28th, 2012, 11:36 AM | #9 |
What do you mean down shift as I brake? This problem is only when taking off from a dead/0mph stop. I usually leave the bike in 1st gear and hold the clutch for a stop sign, this whole issue is about taking of from first. I think you might have misunderstood something, unless there is a gear lower than 1st I don't know about.
March 28th, 2012, 11:42 AM | #10 | |
I start my bike with choke. Finish putting on gear and such (3 or 4 mins tops), hop on and have none of the issues you describe. If your riding for 1+ hours and it still doing that, something isn't right or your not giving it enough throttle to launch from a stop. Since your new to this, try giving it more throttle to get your rpms up as DaBlue1 stated. It's all part of learning to ride. Hey! Speaking of learning, did you take the MSF? If not you really should, it's a great place to start. And as for what dburgess1231 said. Yea... I guess for the engine to fully warm the block through and through maybe. But I will stand by what I stated early. 3-5 minutes and you should be able to PIN it. Don't make me go film it.
March 28th, 2012, 11:45 AM | #11 | |
March 28th, 2012, 11:48 AM | #12 |
Ok, you're ruled out the 'cold-natured' issue. Tell us about your acceleration style. How high are you revving it, & how aggressive are you being with the clutch? If you're not giving it enough throttle before you enter the friction zone in the clutch, you may be bogging it down. If you're allowing it to get below 2500 rpms and then squeezing the throttle hard with the clutch fully engaged, you're lugging the engine, which can feel like it's about to die. I'm not suggesting that you need to be doing 8,000 rpm launches, but it also doesn't like to be lugged.
March 28th, 2012, 12:04 PM | #13 | |
March 28th, 2012, 12:08 PM | #14 | |
March 28th, 2012, 12:11 PM | #15 |
it's all good brah, no harm no foul
March 28th, 2012, 12:33 PM | #16 | |
If you're launching at low RPMs, giving it full clutch engagement, then rolling hard on the throttle, you're gonna be waiting until the engine has entered its power band before you're going to feel anything significant. If you do that when the engine's still cold, it's going to protest. But...if you're launching at higher rpms and you're still feeling a lag, you may have a carb problem. I attempted the carb shimming trick on my 2005, and it created an obvious dead spot just above idle that made it very difficult to get a smooth launch, so I took the shims out. But that experience taught me how little it takes to screw up how the bike runs. You MIGHT have an issue with your carb slides , or one or more jets may be dirty or clogged, but I can't say that with any certainty because I'm not sitting in the seat experiencing what the bike's doing. It could be your fault, it could be the bike's fault. Start with adjusting your riding technique, and see if that doesn't alleviate the issue. |
March 28th, 2012, 12:39 PM | #17 | |
God bless guys. |
March 28th, 2012, 04:54 PM | #18 | |
When you open the throttle, more air than fuel moves into the engine, making the mix lean and the engine weak. The passages in the carburetor could be partially clogged.
March 28th, 2012, 04:57 PM | #19 |
March 28th, 2012, 05:13 PM | #20 | ||||
March 28th, 2012, 05:17 PM | #21 |
10-4. Got some SS shims and a K&N filter. I reckon these should help some, paired with a more aggressive take off from stops
March 28th, 2012, 05:31 PM | #22 |
Leave it in stock form for a while.
Those things just introduce more variables into the problem. A good carbs' clean up should suffice.
March 28th, 2012, 05:34 PM | #23 | |
March 28th, 2012, 05:44 PM | #24 | |
March 28th, 2012, 05:48 PM | #25 |
unless the bike is dead cold (like under 40 degrees), it should run fine within a minute of running. if it doesnt its either clogged up, or tuned improperly. if its an 08 im guessing both. we just took apart a stock set of carbs and it turned out that one of the mix screws had screwed itself all the way in. still had factory screw covers on when we pulled them. ran pretty much how you describe. we cleaned it, set the mix screws, and synced it and it ran like a brand new bike. warmed up to run well in only a few seconds vs seemingly taking upwards of 5-10 minutes to warm up before. and this was on a bike that is ridden pretty much every day
March 28th, 2012, 05:53 PM | #26 | |
March 28th, 2012, 07:08 PM | #27 |
Join Date: Aug 2011 Motorcycle(s): RED 2010 Ninja 250r Posts: 304
Check the mixture screws. Sync the carbs. If that doesn't work, shim the needles.
[motorcycle.com] - Stop Sale and Stop Ride Ordered for Polaris Slingshot | Ninjette Newsbot | Motorcycling News | 0 | January 20th, 2015 02:00 PM |
[motorcyclistonline] - RECALL ALERT: 2015 Polaris Slingshot Stop Sale-Stop Ride Notic | Ninjette Newsbot | Motorcycling News | 0 | January 19th, 2015 06:30 PM |
[speedTV.com] - GEARBAG: Condor Pit-Stop / Trailer-Stop | Ninjette Newsbot | Motorcycling News | 0 | July 30th, 2013 07:50 AM |
Tips for fast acceleration from a stop on ninja 250? | fr1dayn1ght | General Motorcycling Discussion | 25 | June 23rd, 2013 07:53 PM |
Tachometer fluctuation at stop and idle issues | naturalphenomena | 1986 - 2007 Ninja 250R Tech Talk | 6 | November 28th, 2011 12:24 PM |
