Old March 30th, 2012, 12:01 AM   #1
47ninja
Purchased used ninja... what now?
Hi everyone, I just recently purchased a 2010 Ninja 250r with 3,400 miles on it. This is my first motorcycle, so I am a complete newb, but I've ridden it the past few evenings after work and overall it is in great shape and runs beautifully. But at the same time, I want to "reset" the service of the bike since I don't have the maintenance history. For all I know the last oil change was 100 miles ago, or 1,000 miles ago.
What would you suggest I have done to the bike? I was thinking of changing all the oil and fluids (coolant, brake fluid, anything else?) and having the chain and sprocket checked, cleaned and lubed. I'm not too concerned about having a major inspection such as engine or transmission unless someone here recommends it. But is there anything else i should maybe have done? Also, how much should I expect to pay for service? I know a lot of you guys are do-it-yourselfers, but I'm honestly not very mechanically inclined and I have limited garage space and tools. Maybe down the road I can pick up a few things here or there, but I don't want to be tinkering with the bike on my own at this stage.
47ninja is offline   Reply With Quote
Old March 30th, 2012, 02:53 AM   #2
thurt88
thurt88's Avatar
Motorcycle(s): 2014 Honda CRF250L, 2010 ninja 250r
im no mechanic either so I have the kawasaki dealer do all my work.
maint is due every 4k miles is what they say, the first 4k one i think all they do is tighten bolts, grease cables, lube chain and change oil i believe. I think that one was like in 300-ish area but I cant really remember( my carb was also gummed up from winter storage and they cleaned my carb too). my '10 has like 5k something and ive only had one service done.
usually when i get a new bike i take it to the dealer and just have a safety inspection done. just for my piece of mind.
thurt88 is offline   Reply With Quote
Old March 30th, 2012, 03:38 AM   #3
streetsquid
streetsquid's Avatar
Motorcycle(s): 2011 ninja 250,2005 suzuki drz400 supermoto,2005 cr150f supermoto,2009 klx 110,1998 Z-50
Start buying parts for to make it your own.
SQUID-Rider who overestimates his abilities.And rides Really slow in the corners,and sudden bursts of acceleration when a straight appears.Squids wear no protection,an thinks there invincible.
streetsquid is offline   Reply With Quote
Old March 30th, 2012, 06:46 AM   #4
cbdallas
cbdallas's Avatar
Motorcycle(s): 2007 Ninja 650R
Oil & filter change, clean, lube & adjust chain, check coolant level, flush brake fluid, visual inspection of brake rotors & pad thickness, check tire pressure & tread depth.
cbdallas is offline   Reply With Quote
Old March 30th, 2012, 07:10 AM   #5
^^^ what he said
Basically, find a service manual or DIY and do the 600 mile service yourself. It's quick and easy and well worth your time to get to know your bike.
Old March 30th, 2012, 10:14 AM   #6
47ninja
Tire pressure and tread wear I check myself. What should I reasonably expect a dealer to charge for the rest?
Old March 30th, 2012, 10:32 AM   #7
Ichiro
Motorcycle(s): 2008 250r(sold). 2013 Kymco Super8 150
New gen maintenance schedule is here:
http://www.ninjette.org/forums/showthread.php?t=10577
Ichiro is offline   Reply With Quote
Old March 30th, 2012, 11:28 AM   #8
cbdallas
cbdallas's Avatar
I have no idea what dealers charge, as I do all this stuff myself. Call around to your closest dealers, and call a few independent shops as well....it's nothing a non-Kawasaki shop can't handle and you may get a better price.
Purchased first Bike mmmitchell14 New Members 15 September 10th, 2013 11:39 AM
Purchased my 300! Arbatrix 2013 - 2017 Ninja 300 General Discussion 15 December 16th, 2012 12:02 PM
Has anyone purchased aftermarket fairing sets? LoneRonin 2008 - 2012 Ninja 250R Farkles 2 May 20th, 2012 03:39 PM
First piece of gear purchased! The All-Important Helmet. ajcadoo Motorcycle Gear 13 April 19th, 2012 09:02 PM
Gerbing - Anyone purchased from this place? g21-30 Motorcycle Gear 10 October 22nd, 2009 01:14 PM
