#1 |
Down Under
Join Date: Jun 2014 Motorcycle(s): Kawasaki ZXR250C Ninja Posts: 296
New slip on
I went with a red Musarri.
Really can't complain for $179 AUD as I dinged up my M4 one during a low side a few months ago ![]() |
#3 |
^^^ what he said
#4 |
Nooblet
Join Date: Jul 2011 Motorcycle(s): 2011 Ninja 250R FI Posts: A lot.
MOTM - Oct '13
Looks awesome at that zoom level.
I'm looking at that warm and dry pavement also visible in the picture and feeling jealousy. Maybe I should move to Aus. |
#5 |
Down Under
#6 |
Inline 4!!!
I have mussari slip on, On my 2nd one, had one on my newgen and my 300.
![]() ![]() For the price you cannot complain. I got my first one for about $200 and the carbon fiber one for $250. The slip ons don't really make the bike run too lean either. You definitely don't have to tune it, although it wouldn't be a bad idea. One things for sure, they do weigh a LOT less, and make the bike look a ton better.
#7 |
Looks great!
#8 |
Down Under
I will be doing a needle/jet kit because it surges with the choke on, and the revs hang around 3k-4k rpm with no choke once warmed up
#9 |
Same company makes a set of sweet carbon fiber ones
Kawasaki ZZR250 ZZR 250 1990-2007 Musarri Carbon Fiber Dual Exhaust Slip-on http://pages.ebay.com/link/?nav=item...989823&alt=web How you you rate sound compared to the OEM muffler?
violente et ignorantia ZX-2R BLOG Twitter and Instagram = Ghostt_Scott I'm not here to change your mind, just to inform. ![]() |
#10 |
It's summer time in the land down under, I should buy home there and use it as my winter home
#11 | |
Down Under
#12 |
How does it sound? How much louder? What's the tone, higher, lower etc...?
#13 | |||
Down Under
![]() Quote:
The best thing about summer here aside from riding... beach babes galore! Also a vid of the exhaust sound, the mic isn't great quality though... mono 22khz |
#14 |
Has a nice throaty sound to it, I've heard other ones that makes the bike sound like a pissed off weed wacker
I'm guessing the dual ones for the pre 08' might sound nice.
#15 |
Down Under
I'm sure it will sound better once the carbs have been jetted
#16 | |
Nooblet
MOTM - Oct '13
My FI 250R has a little dial tucked inside the vent on left side of the fairing. You can turn it to adjust the idle rpm. Maybe the carb 250R has this dial too?
![]() Quote:
250R races often sound like a swarm of angry bees. I much prefer the sound of my 250R now it has an Area P exhaust: especially the low rpm ( less than 5k ) sound. |
#17 | |
Down Under
With little or no choke, if you blip the throttle, it goes down and starts to hang at 4k RPM, then slowly drops down to normal. By slowly I mean it takes longer to drop from 4k rpm than from redline/high revs to 4k rpm. In any gear, if I back off the throttle and coast, the revs stick at 3-4k rpm until I pull the clutch in. The revs stick for a second or so and drop. The low-mid range is lean for emissions testing purposes. Upon thinking, rejet/new needles is a must for new carb bikes! |
#18 | |
Nooblet
MOTM - Oct '13
![]() ![]() Your bike looks really awesome btw. It's a bit like a 2fiddy version of Mordeth 13's bike: maxresdefault.jpg |
Slip on? | Somchai | Off-Topic | 3 | June 13th, 2013 08:18 PM |
Slip On Q.. | YMCMB | 2008 - 2012 Ninja 250R Farkles | 3 | August 9th, 2012 10:33 AM |
Slip on | fredhsu | 2008 - 2012 Ninja 250R Tech Talk | 18 | August 8th, 2012 09:16 AM |
Slip-on Exhaust | Zaydoc | 1986 - 2007 Ninja 250R Tech Talk | 7 | February 18th, 2012 09:34 AM |
used slip-on for 08+ | nebraskan | Items Wanted | 0 | May 9th, 2011 05:40 PM |
