Old May 25th, 2012, 01:51 PM   #1
lostdaemon
lostdaemon's Avatar
Motorcycle(s): 2009 Ninjette
Question N00b ? - I got rained on!
So this is kinda dumb, but I'm still a relatively new rider, and don't know much about maintenance...
I got caught in a very unexpected downpour this morning on my way to work Since when does it rain in SoCal?!
So Max got wet, and my sister has me freaked out that I need to wash Max, clean his chain, and re-lube it IMMEDIATELY or I/Max will die.
I don't have a stand, I don't have lube, I don't know how to do anything other than wash him.
How urgent is this truly, what products do I need, how do I do it, and is it possible to do this without a stand?
Thanks, sorry for n00b-ness.
lostdaemon is offline   Reply With Quote
Old May 25th, 2012, 01:56 PM   #2
NJ Ninjette
NJ Ninjette's Avatar
Motorcycle(s): 2012 Ninja 250R, 2007 Husky TE 250, 2002 KTM EXC 250r
It's not urgent in anyway as motorcycles are meant to be out in the elements.
NJ Ninjette is offline   Reply With Quote
Old May 25th, 2012, 01:58 PM   #3
Whiskey
You should lube the chain regularly, but it's not absolutely needed immediately just because it rained.
I put 15,000 miles on a chain commuting in Ireland (rains every 3rd day or so) lubing it once a week.
You need a can of chain lube & a stand, or somewhere you can roll the bike about 50ft
Old May 25th, 2012, 01:59 PM   #4
Not urgent. When chains get wet (or dusty), they need to be lubed a little more often than they would have been otherwise. They should be lubed every 500 miles or so anyway, so the next time you're on the bike take care of it.
Old May 25th, 2012, 01:59 PM   #5
xSean13
xSean13's Avatar
I also have a question, as I have never ridden in the rain or elements, but I had read that after doing so, it is recommended to clean the air filter: any input?
Old May 25th, 2012, 02:03 PM   #6
NJ Ninjette
I've never heard that and don't even clean my filters on my dirt bike after a full days dusty ride...
Old May 25th, 2012, 02:04 PM   #7
Whiskey
clean the air filter after each ride???
no
do it a bit more often, maybe every 1500 miles rather than 3000 (even still that's pushing it) ... Don't know where I got 3000 from, I usually do it with the oil change & use the excess oil to wet the air filter... thinking out loud here...
RTFM, both are in there, as is the reccomendation not to go over 4k rpm in the first 1000 miles... RTFM & filter out the bullshit
Last futzed with by Whiskey; May 25th, 2012 at 05:15 PM.
Old May 25th, 2012, 02:06 PM   #8
xSean13
xSean13's Avatar
no
That's not what I said at all. I said after riding in the elements, aka heavy rain, snow, areas with heavy dust, etc.
Old May 25th, 2012, 02:11 PM   #9
Whiskey
Where I am it rains quite a bit, so if I followed the handbook I would be pulling out the filter for a rinse & oil about twice a week.
Slight exaggeration saying after every ride but still... nothing a good dose of common sense can't fix
Old May 25th, 2012, 02:27 PM   #10
xSean13
xSean13's Avatar
Well, it was just a question, as the ninja 250 faq website mentioned it and I have only owned and been riding a motorcycle for about 2 months. Condescending answers are unnecessary.
Old May 25th, 2012, 02:37 PM   #11
lostdaemon
lostdaemon's Avatar
Thanks all for assuaging my fears - my sister's got some crazy notions about how to care for a bike (she put 4 qts of oil in mine because it was starting rough a long time ago...that ended badly, thank G-d my mechanic was able to fix!)
So what do I use to clean and lube the chain?
Old May 25th, 2012, 02:48 PM   #12
Boom King
So, where's the reverse?
Boom King's Avatar
How To: Clean/Lube Chain
Old May 25th, 2012, 02:59 PM   #13
lostdaemon
lostdaemon's Avatar
Perfect!!
Thank you!!
Old May 26th, 2012, 06:50 PM   #14
tac12345
Motorcycle(s): Ninja 250r 09 SE
please don't let your sister touch your bike anymore !
tac12345 is offline   Reply With Quote
Old May 29th, 2012, 12:41 PM   #15
lostdaemon
lostdaemon's Avatar
She rides an R1 (that her boyfriend does almost all the work on) but because she's older, and has been riding longer, she *thinks* she knows everything about motorcycles, and while I wasn't riding, she was 'maintaining' Max...so well that I had to drop almost a grand to get him working afterwards... (I'm guilty too, but damn did she mess up...)
So now that I'm riding, she's no longer allowed to touch Max
Old June 10th, 2012, 03:49 PM   #16
According to the manual, you are supposed to use a Wizard of Oz-style oil can with 90W oil to lube your chain and you aren't supposed to use a nozzle or cover the tip of the hose when washing it and you can't use anything but soap and water (which does nothing to brake dust and lube on the rims).
I knew the air filter element cleaning "requirement" after each rain or dust ride was BS as soon as I read that the procedure required me to soak in a high-flashpoint solvent. Just what am I supposed to do with all this dirty solvent than I can't pour down a drain?!
Old June 10th, 2012, 03:59 PM   #17
Boom King
Boom King's Avatar
Do you have a community recycling centre or hazardous waste disposal collection site near you? That's where I take all my used chemicals and hazardous fluids.
Some N00b questions :p himynameisjoe 2013 - 2017 Ninja 300 General Discussion 16 November 19th, 2012 10:16 PM
New bike, new rider... just a N00B massacremasses New Members 17 September 14th, 2011 08:28 PM
n00b from OH ninjette250 New Members 10 June 30th, 2011 05:23 PM
Old n00b from Michigan here JoeLansing New Members 14 June 21st, 2011 02:24 PM
n00b Here PeterJasonMN New Members 16 June 11th, 2009 07:39 PM
