September 22nd, 2014, 07:53 PM | #1 |
Join Date: Aug 2014 Motorcycle(s): 2009 Ninja 250R Posts: 2
Right turn signal doesn't blink when clutch in
Hello All,
Like the thread title says, I'm having an issue where the right turn signal works normally, except when the clutch is in. As I pull it in, both right side signals (and signal indicator on dash) go solid-lit. Left side is unaffected. Possible hint- I installed roaring toyz handlebar risers, and they seem like a sliiiight stretch on the cables at full-lock. I don't think the bike had this issue before I installed them. I'm guessing something is shorted-out or rattled-loose, but if you guys have any ideas on where the culprit might be, I'd really appreciate it. Thanks! |
September 25th, 2014, 11:51 PM | #2 |
Welcome Joe!
I was hoping someone would have already chimed in by now. I would assume the same as you and take apart the controls and have a look. Maybe you fixed it by now?
Turn signal won't blink | demp | 2008 - 2012 Ninja 250R Tech Talk | 7 | August 28th, 2014 06:58 AM |
WTB: Left side turn signal/clutch lever/ shift lever/fairing (green/red or black) | daedrick | Items Wanted | 0 | April 3rd, 2012 12:44 PM |
Rear turn signals don't blink, front turn signals don't turn on | andyuc88 | 2008 - 2012 Ninja 250R Tech Talk | 3 | March 23rd, 2012 02:47 PM |
HELP! Turn signal wouldn't blink | axu1977 | 2008 - 2012 Ninja 250R Tech Talk | 7 | July 13th, 2009 09:33 AM |
