May 11th, 2015, 11:17 PM | #1 |
ChocolateMilk Addict
Join Date: Mar 2015 Motorcycle(s): '05 EX-250 "Kallie" 85 KLT 110 ATC "Murdock" Posts: 329
Drain Screws
Stripped my float bowl drain screws, need new ones, any websites i can get em?
May 11th, 2015, 11:31 PM | #2 |
Join Date: Feb 2014 Motorcycle(s): Rebel 250s, Ninja 250s VN750s (currently nine total) Posts: 465
A kawi dealer is probably the best, or you might try ebay. New ones at cheapcycleparts.com or other online stores will be cheaper than a dealer, but shipping charges will eat your lunch.
Profanity is the weapon of the witless. |
May 12th, 2015, 10:18 AM | #3 |
Woah, $24.33 at cheapcycleparts.com, no thanks, ill be heading up to the dealer then! thanks!
May 12th, 2015, 03:07 PM | #4 |
The threads in the aluminum body may be stripped, rather than the threads in the steel drain screws.
May 13th, 2015, 08:06 AM | #5 |
the threads are fine lol, the "hex" is now a nice circle
May 13th, 2015, 08:44 AM | #6 |
That is a 2.5 mm Allen, if I remember correctly.
http://www.ebay.com/itm/KAWASAKI-CAR...-/161418009091
May 13th, 2015, 08:52 AM | #7 |
PM @ducatiman he sells stainless steel hardware for carburetors as well as other carburetor needs.
May 13th, 2015, 09:57 AM | #8 |
If there is a specialty bolt store in your town, you can probably get the drain screws there cheaper than from a dealership.
A hand impact driver loosens stuck bolts without damaging the heads. They're cheap, and everyone who works on bikes should have one. http://www.harborfreight.com/impact-...ase-37530.html
May 13th, 2015, 10:54 AM | #9 |
dremel a slot, use a standard flatblade screwdriver
Should I drain the carbs even though... | Runeknight95 | 2008 - 2012 Ninja 250R Tech Talk | 6 | March 14th, 2013 02:56 PM |
Drain tube weight? | chef | 2008 - 2012 Ninja 250R Tech Talk | 9 | February 18th, 2011 08:00 PM |
Coolant Drain Bolts | indr | 2008 - 2012 Ninja 250R Tech Talk | 5 | November 24th, 2010 06:01 AM |
drain gas from tank | james250ninja | 1986 - 2007 Ninja 250R Tech Talk | 6 | April 2nd, 2010 03:01 PM |
Okay, so what's that OTHER drain plug for? | adouglas | 2008 - 2012 Ninja 250R Tech Talk | 5 | August 23rd, 2009 07:18 PM |
