Old April 13th, 2012, 08:06 PM   #1
Ninja1
Ninja1's Avatar
Oil change during break in
I currently have 300 km on the bike (200 mi) and I'm doing the motoman break in with varying high RPMs and a lot of engine breaking. A lot of people recommended changing the oil often when breaking in this way. I'm planning on changing the oil tomorrow and just wanted to know if I should change the oil filter as well?
Ninja1 is offline   Reply With Quote
Old April 13th, 2012, 08:07 PM   #2
yes
Old April 13th, 2012, 08:26 PM   #3
Jiggles
Jigglin' your Jiglets
Jiggles's Avatar
MOTM - Apr '13
Make it a habit to always change them together, filters don't cost that much anyway
AFM #676
Supersports are for n00bs
Old April 13th, 2012, 08:30 PM   #4
cuz
cuz
cuz's Avatar
Motorcycle(s): 09 ninja 250r
i all ways do
THE GOOD LIFE
cuz is offline   Reply With Quote
Old April 13th, 2012, 09:08 PM   #5
Reswob
Reswob's Avatar
Motorcycle(s): 2008 Triumph Bonneville Black
You should always change the filter when changing the oil on anything. However, Kawi does not suggest changing the oil frequently during break in. You'll be changing it again at 600 mi, kind of silly to do it now...
'08 Bonneville Black
sold->'08 Ninja 250R | OES Swingarm Spools | EBC HH brake pads | reflector delete | no-cut brake light modulator | DIY fender eliminator
Reswob is offline   Reply With Quote
Old April 14th, 2012, 06:43 AM   #6
Ninja1
Ninja1's Avatar
Thank guys, I'll change the filter as well
Resoweb, I'm not following the Kawasaki guideline for break-in and apparently when you push the RPMs during break-in there's more metal shavings that fall through early on. That's what I'm reading anyway, will find out later if that's the case. Hopefully it won't look anything like this
Old April 14th, 2012, 03:49 PM   #7
Ninja1
Ninja1's Avatar
So I went to Canadian Tire and picked up some Gastrol oil (not many choices for 10W40).
Went to the Kawi dealer to get the drain plug washer and ended up buying 2 quarts of the Kawasaki oil and used that instead.
So it went very smoothly but when I checked the oil there was definitely some shavings at the bottom of the pan.
Not sure if it's too much or what. I even tore the oil filter but did not see much shavings there.
In any case I will do another oil change in 300 kms and see if there's a difference.
Old April 14th, 2012, 03:56 PM   #8
akshay11
akshay11's Avatar
Motorcycle(s): 2012 Ninja 650
Did my oil change at 50 miles and the pan looked the same way. Had a mechanic friend do it cuz I just wanted to see how it was done the first time... turns out since the redesigned this bike you have to take off the side fairings.. which was like 9 of those press in bolt things.. but anyways went back the next day and he showed me the filter that he cut out and let dry.. could see quite a bit of metal there also.
akshay11 is offline   Reply With Quote
Old April 14th, 2012, 04:24 PM   #9
ninja250r81
ninja250r81's Avatar
Motorcycle(s): 2012 ninja 250r se
that's nasty
looks like you are paning for gold
i did mine at 100kms, 500kms, will be at 3000kms
i will be letting the dealer do the scheduled first 1000kms service and the second service at 6000kms.
then ill be changing the oil at every 5000kms with 10-40 semi syn with ester
ninja250r81 is offline   Reply With Quote
Is it normal for oil to increase a bit in the crankcase after an oil change? cadd 2008 - 2012 Ninja 250R Tech Talk 10 May 15th, 2014 08:38 PM
Synthetic oil at 300 mile oil change? anacron 2013 - 2017 Ninja 300 Tech Talk 14 July 29th, 2013 04:58 PM
Oil drain plug gasket for oil change. tsdexter 2008 - 2012 Ninja 250R Tech Talk 8 July 10th, 2012 01:00 PM
Should we change oil early during break-in? The answer is YES!!! dubojr1 2008 - 2012 Ninja 250R Tech Talk 54 June 13th, 2012 12:46 PM
change oil filter, without draining oil? peter330 2008 - 2012 Ninja 250R Tech Talk 5 May 30th, 2010 01:08 PM
