April 11th, 2013, 11:02 AM | #1 |
Join Date: Apr 2013 Motorcycle(s): Ninja 250r 2009 Posts: 2
Battery Connection & Tachometer Problems
New to riding, don't know much, and I'm having trouble with my battery connection. After 30 mins of riding or so, I have to constantly keep adjusting the battery connection. I got a new battery from Auto Advance, and the screws don't actually tighten, it just kind of slides in. I checked on the web, and it seems like all replacement batteries are like that. Am I missing something?
Any help would be super appreciated! My bike is a 2009 250r, rode maybe 500 miles on it? Also, not sure if it's related, but my tachometer keeps spazzing around 60 mph, it'll hit max then quickly to 5000-6000 then spaz to max again.. |
April 11th, 2013, 11:11 AM | #2 |
Welcome Jackie!
Battery issues and the jumpy tach are most likely closely related. Your connections should be solid and not work loose by normal riding. Can you post a pic or link of the battery? I have only seen screw down type batteries for bikes. I have seen some strange special stuff on batteries for mowers, tractors and other equipment though.
April 11th, 2013, 02:25 PM | #3 |
Yup - a pic would help. There is enough vibration on a motorcycle that the battery connections need to be uber-tight to prevent problems. I've only seen motorcycle batteries with nuts/bolts to tighten, so I'm curious what you're dealing with.
April 11th, 2013, 03:13 PM | #4 |
typically there is a square nut under the connection terminal for the battery. the top bolt screws into that nut which is held in place by the terminal walls. it could simply be gone.
April 11th, 2013, 04:12 PM | #5 |
Join Date: Dec 2012 Motorcycle(s): 2008 Ninja 250R Posts: 263
^what he said. Odds are, they fell out while you were handling the battery. So grab a flashlight and look around.
April 21st, 2013, 07:43 PM | #6 |
Here are a few pics! Thanks for the feedback so far!
April 21st, 2013, 08:04 PM | #7 |
So... Did ya find the square nuts?
April 21st, 2013, 08:06 PM | #8 |
Yup. Missing the square nuts that the bolts screw into. Should be easy to find some replacements at an auto parts or hardware store.
Idle issues and battery problems | Knorf | 1986 - 2007 Ninja 250R Tech Talk | 4 | May 23rd, 2014 06:04 AM |
ninja 250 battery & tender question | itslocfoo | 1986 - 2007 Ninja 250R Tech Talk | 2 | December 7th, 2013 06:02 PM |
FS: Battery Tender 021-0128 Battery Tender Plus 12V Battery Charger (Automotive) tagg | Amazon Postbot | Amazon - Popular Motorcycling Items | 0 | April 23rd, 2013 04:52 PM |
FS: Battery Tender 021-0123 Battery Tender Junior 12V Battery Charger (Automotive) ta | Amazon Postbot | Amazon - Popular Motorcycling Items | 0 | April 23rd, 2013 04:52 PM |
[motorcyclistonline] - Motorcycle Battery Unwrapped | Starts & Sparks | Ninjette Newsbot | Motorcycling News | 0 | March 19th, 2013 06:40 PM |
