Old August 17th, 2012, 10:53 PM   #1
Incognito
Motorcycle(s): 2012 Ninja 250
Flush mounts too small...
So while I was out today I came across a pair of flush mount signals for $20. They looked like they would be just the right size and the salesman said they should work fine. Well, I'm sure they do work fine, but they don't fit. Is there any ideas on what I can do to make these work, or do I just need for fork over more than $20 for turn signals? And the reason they're being replace is because one has been broken for about 10 months now and I got tired of looking at it.
This shows a small gap between the top and bottom, and the width doesn't have much overlap.
And this is positioned high enough to actually have the adhesive hold from the top.
Any ideas?
Incognito is offline   Reply With Quote
Old August 18th, 2012, 04:11 AM   #2
Somchai
Freedom for Germany
Motorcycle(s): Ninja 250R-FI
maybe this when you modify??? http://japan.webike.net/products/20429442.html
Old August 18th, 2012, 06:52 AM   #3
FrugalNinja250
FrugalNinja250's Avatar
Motorcycle(s): Several
Get a sheet pf black plastic, cut to fit the original recess, stock the new part to it, then use double-sided tape to stick the cut piece into the recess. Use the high strength tape.
Old August 18th, 2012, 10:29 AM   #4
^this! I have big plans doing stuff like this.
Old August 18th, 2012, 03:11 PM   #5
Incognito
Awesome, thanks. I'll give that a go and let you know how it turns out.
Old August 25th, 2012, 04:00 AM   #6
Somchai
Freedom for Germany
maybe here you find what you need? http://www.ebay.de/itm/1-PAAR-Adapte...item27c9d70ecf
Old August 28th, 2012, 10:42 AM   #7
polokid699
polokid699's Avatar
Motorcycle(s): 2007 ZZR600
Originally Posted by Somchai View Post
These are Protons and fit perfectly in the stock slots with not cutting
polokid699 is offline   Reply With Quote
Old August 28th, 2012, 08:58 PM   #8
Incognito
Thanks for the suggestions. I bought some stuff last week and I'm finally going to try and get it installed tomorrow since I have the day off. I looked all over the place for a sheet of black plastic and had no luck finding any. Everyone I asked at the stores didn't seem to know where I could find some either; I'm sure I made it more difficult than it should have been though. I eventually came across this round piece in the plumbing section of OSH and figured it would work. It's about 1/4" thick and I'll be able to cut out a couple pieces that will hopefully fit right into the socket.
This is what I have to work with. Dremel, mounting tape, turn signal that's too small, and some random piece of plastic found in plumbing department.
I'm hoping to have a final product to show you tomorrow. I probably would have been better off spending $80-$100 on ones that would fit right out of the box, but this has cost me under $30 so far.
Old August 28th, 2012, 09:00 PM   #9
Good luck with a steady hand and looking forward to the pics!
Old August 28th, 2012, 09:10 PM   #10
cuong-nutz
cuong-nutz's Avatar
If you still have the stock turn signal stalk, use the base as an outline and just outline it bigger. Then hack the stalk so you will have something solid to mount the light.... Or whatever you had in mind.
HalfFast Racing Team
Old August 28th, 2012, 09:17 PM   #11
Incognito
Hadn't thought of that. I might give that a try. Originally I was just going going to cut out an oval and round it off so it was just a tad bit smaller than the opening and then line opening with the mounting tape and kinda force it in there. This might give it a bit more of a firmer foundation, so I'll probably give it a try and see how it goes.
Old September 8th, 2012, 05:04 AM   #12
Old Guy on a '08
Chris
Old Guy on a '08's Avatar
Motorcycle(s): BLACK!!! '08 250R
I'm looking at the Proton flush mount's. What is the thing that needs to be installed for LED lights to work. Recommendations on which one to buy, where to get it and installation tips appreciated. Do you need to install a second on for the tail light, and auxillary lights???
Some roads are too good to waste on four wheels!
Riding in a car is like watching a movie...
Riding on a motorcycle is like being in one....
Old Guy on a '08 is offline   Reply With Quote
Old October 2nd, 2012, 05:11 PM   #13
Incognito
I finally got around to finishing my turn signals. For the past couple weeks I have been driving around with one flushmount and one oem turn signal. It looked pretty silly... So here's my update on it:
I found out that I suck at carving stuff out with a Dremel, so I ended up using this little plastic piece that came off of one of my daughter's old car seats.
And here's the final product:
It's definitly not the prettiest, but it's much better than the broken signal with chunks missing from it.
Old October 2nd, 2012, 05:42 PM   #14
Monkeytofu
I told you bro
Monkeytofu's Avatar
I think you put them on in the opposite directions?
edit: nevermind odd angle in picture
Flush Mounts?! scubaru 1986 - 2007 Ninja 250R Farkles 62 January 1st, 2014 02:39 PM
Flush Mounts fredhsu 2008 - 2012 Ninja 250R Farkles 16 August 27th, 2012 10:55 AM
Bikelitez flush mounts... Anyone done this? KirkyPerk23 2008 - 2012 Ninja 250R Farkles 1 January 12th, 2012 04:28 PM
Proton Flush Mounts Jerkson Motorcycle-related 6 September 23rd, 2010 05:23 PM
Flush Mounts for 500 reondadomino General Motorcycling Discussion 9 December 19th, 2009 03:01 PM
