March 8th, 2012, 10:08 PM | #1 |
Mirror plastic washer??
I removed my mirrors off for track day purposes by removing the bolt that hold the stalks to the fairing. Apparently there's suppose to be a plastic washer under the bolt that squeezes against the bolt to keep the mirror stalk from pivoting. I can't seem to find it on the fiche in any of the parts catalog... Anyone know where I can find this part??
I circled in red where the bolt and said plastic washer is located. If you removed the foam adhesive cover you'll gain access to the allen bolt: I'll get the a photo tomorrow if it helps.
March 13th, 2012, 01:24 PM | #2 |
Well that plastic washer is more like a nylon nut except it's not threaded. I headed to Lowes and found the closest size nylon nut in the hardware section. I can't recall the size but it was a tad bit too big and a bit too tall. I used my dremel to file out the threads so that the allen bolt would fit through and cut down to size to fit inside the bracket. Works good now
March 13th, 2012, 01:28 PM | #3 |
Very resourceful of you and a great tip!
washer preload forks | eddiekay | 2013 - 2017 Ninja 300 Tech Talk | 2 | July 22nd, 2014 09:55 AM |
caught a plastic bag today on my mirror | subxero | General Motorcycling Discussion | 11 | April 23rd, 2013 09:51 AM |
missing a washer! | seedanpaint | 2008 - 2012 Ninja 250R Tech Talk | 6 | March 9th, 2009 03:17 PM |
