June 16th, 2014, 02:59 PM | #1 |
dirty boy
MOTM - Apr '14
new rear shock swap... perhaps i went a little too far?
Ok here is story in a nut shell
Did gsxr shock swap... it was ok, found out the hard way (or stupid way) i had no high speed compression dampening adjustments. after i lost most of the oil out of the shock i ended up needing to get the gsxr shock serviced, local dealer wouldn't touch it because book states it is unserviceable and no specs for anything are given. Would have cost more to get it serviced than i paid for it So i figured i could put oil in myself, but would still need nitrogen but would still have a shock i wasn't super crazy about so that is when ebay happened. used aftermarket ohlins gsxr 1000 shock think i got it for a decent price, otherwise well i would not have bought it. Bought new spring for it because the one on it was a 10.6kg/mm Figured it would swap on similar to gsxr 600 shock. It did... kind of Needed to trim the battery box a good bit more, i need to clean that up a bit yet. I already had hugger so this is non issue, the hugger keeps everything in that area clean. i also had to grind a little bit off the bottom of the upper shock mount on the frame I was in to deep to go back at that point. It is non issue IMO besides my bike is to much of a botch job at this point to consider selling it anyway, plus i never plan to either way. So yeah, took a little off the bottom, painted it up and GTG! It is a little longer than the OEM shock so i went back to the stock dog bones (had shorter bones for gsxr600 swap) which means the rear will be up a little bit vs stock. I could make new ones or buy adjustable bones to get things back to stock spec if i feel like it in the end, but for right now will ride it as is. Ok to the goodies 3 clicker Ohlins with hydraulic hand adjustable preload Rebound, high and low speed compression dampening adjustments Bolted everything up yesterday took it for a ride today and sought out some ****** bumpy roads...(didn't have to look very hard ) and first impressions are good. Purposefully seeking out the rougher line never felt so good. Felt good in the turns as well but wasn't able to push it to hard... these roads were **** to say the least. here are some pixies
June 16th, 2014, 03:16 PM | #3 |
dirty boy
MOTM - Apr '14
^hell ya, i just need to start adding the chrome now
June 16th, 2014, 03:20 PM | #4 |
Join Date: Sep 2013 Motorcycle(s): 2015 Yamaha FZ07, Ninja 250r 2012 Limited Edition (Sold) Posts: 529
Getting into some hardcore mods. Looks premo.
Gonna have to start calling your bike the ningixxer.
"Take it easy driving. The life you might save might be mine." |
June 16th, 2014, 03:25 PM | #5 |
Blind 250 Loving Whore
Mmmm, shiny.
June 16th, 2014, 04:07 PM | #6 |
If you chrome that out and ride it only to Bike nights, I'm gonna have a heart attack!!!
June 16th, 2014, 06:44 PM | #7 |
I like it. Time to get some drop-in cartridge fork internals though. Gotta match the front to the rear.
June 16th, 2014, 07:58 PM | #8 |
#squid
Join Date: Jul 2011 Motorcycle(s): Track dedicated 2008 ZX6R Posts: A lot.
MOTM - Jul '16
That's a bike I'd actually like to look at, not those crappy 'custom bikes' at the car show I was just at. Good work. Jelly.
June 16th, 2014, 10:16 PM | #9 |
Join Date: Mar 2014 Motorcycle(s): 2013 Ninja ZX6R, 2009 Ninja 250R Posts: 256
Woah there.
June 16th, 2014, 10:27 PM | #10 |
Certifiable nontundrum
MOTM - Sep '13, Sep '16
That is good ****
June 17th, 2014, 03:01 AM | #11 |
That is SU-WEET !
June 17th, 2014, 05:48 AM | #12 | |
dirty boy
MOTM - Apr '14
or as I say, go big and then go home likely because you either hurt yourself or are broke as result of "going big" oh it has adjustable length as well, forgot to mention that, but unfortunately the shortest it goes is still a couple mm longer than OEM shock. So it will go a good bit longer but no shorter so it doesn't help much. I did think about getting lowering links and then making up the drop from the links with the shock adjustment but I am not sure how that much change in geometry would effect the performance of the shock? and if there was the clearance for it? So figured it was probably better off this way with stock bones. I might end up making new bones just to save some weight if anything, the T6 bones I made for the gsxr shock swap worked great and were way lighter than the OEM steel ones.
I love the smell of burning pre-mix in the morning I don't think I'm a lot dumber than you thought that I think that I thought I was once. Last futzed with by subxero; June 17th, 2014 at 04:47 PM. |
June 17th, 2014, 06:23 AM | #13 |
Lighter is better
June 17th, 2014, 08:02 AM | #14 |
Fighting Texas Aggie '05
I was thinking about the same thing lol. Find a used aftermarket GSXR shock lol
June 17th, 2014, 01:24 PM | #15 |
Board Member
aftermarket race shocks are typically stiffer (valving at least) than stock. Be careful that the thing doesn't ride like a steel rod.
June 17th, 2014, 01:31 PM | #16 |
December 20th, 2016, 12:17 PM | #17 |
not an actual panda
Join Date: Aug 2012 Motorcycle(s): 2008 Ninja 250, 2009 CBR600RR (Sold) Posts: A lot.
What model # is the shock?
December 21st, 2016, 08:56 AM | #18 |
Join Date: Feb 2016 Motorcycle(s): ZZR250, VFR800 Posts: 478
I fitted a new gen Ohlins to my ZZR250, lifts the rear 2" & works great . A 750's spring would be too stiff.
December 22nd, 2016, 05:57 AM | #19 |
dirty boy
MOTM - Apr '14
Could have told you a year or two ago but it eludes me at the moment. I want to say it is a SU503?? SU530??? Something like that. I will see if I can't find any stamps on the shock when I get home or dig up some old info laying around that has it.
January 24th, 2017, 12:00 PM | #20 |
dirty boy
MOTM - Apr '14
Shock info
Ohlins SU503 Rear Shock Suzuki GSXR 1000 05-06
Race-prepped 250 GSXR shock swap question | Braden07 | 2008 - 2012 Ninja 250R Tech Talk | 7 | November 15th, 2014 07:03 AM |
GSXR shock swap questions | subxero | 2008 - 2012 Ninja 250R Tech Talk | 75 | March 13th, 2014 12:09 PM |
CBR600rr rear shock swap | Gorilla25 | 2008 - 2012 Ninja 250R Tech Talk | 59 | April 1st, 2012 11:39 AM |
For sale: 2003 ninja 250 rear brake pedal and rear shock | ReDnEcK | Motorcycle-related | 0 | October 6th, 2010 12:02 PM |
Replacing my rear shock with a newgen rear shock... | ReDnEcK | 2008 - 2012 Ninja 250R Tech Talk | 4 | September 10th, 2010 12:38 PM |
