March 19th, 2013, 08:15 PM | #1 |
Join Date: Mar 2013 Motorcycle(s): 1999 Ninja 250R Posts: 59
DIY - More Under Seat Storage
I was at Wal-Mart the other day and came across this:
The box is 6" wide, 8" long, and ~2.5" deep. The combo can be set to any 3 digit combination. It also comes with a tethering cable to secure the box to something solid. I bought it deciding that I was going to try and mount it on the bike somehow. Also, for only $15, even if I couldn't I could make use of it somewhere else. So I posted up a thread trying to find out the information I needed to know about the Ninja 250R itself, as I only just recently bought my first bike. I found out that the rear tire has a 5.1" upward movement maximum. Anything above that and the tire shouldn't touch it. I have slightly crossed into that maximum with the bottom of the box, but as I only weigh 135lbs, it would take quite a bit for me to get the bike bottomed out. So I went out to the bike and took the seat off and tried to figure out how I would do this. Luckily for me, the inside width of the rear fender is perfect match to the width of the box. I also noticed that in order to place the box where I wanted it, I had to figure out a different place to hook the spring. After a while of trying to clip the spring somewhere else I had an idea. I went and got a screw on hose clamp and wrapped it around the frame. I then hooked the spring onto the arm below the hook that latches the seat down and hooked the other end in one of the slots on the clamp. Work perfectly. Better than the original placement in my opinion. I do plan on putting one on the other side but for now, this works. I used a drill to make holes around the part of the fender I had measured to be cut out and removed it. I also used a razor blade to cut off all the little nubs from the drill around the hole you see in the picture. ( +1 if you collected them afterwards for DIY ABS Cement ) I then placed the box into the fender. The box fits very snug do to the raised piece of the inside fender wall. Once I had it in the general area I wanted the box to sit, I put the seat back on. When the seat latched the box was pushed down a bit. This ensures that the box does not stick up so high that you can't put the seat back on. Before the seat: After the seat: Picture from underneath with the seat on: ( There isn't anything holding that box in there other than the pressure of the fender squeezing against it. ) I made some brackets out of metal strip with holes in it. ( Used to hang pipes and such ) I marked the bottom of the box at the front and back on the bottom and also how far it went back. This ended up being on the rear half of the fender. I went ahead and used my ABS repair iron ( old soldering iron ) to make holes in the fender wall and used zip-ties to hold the brackets in place. I would have rather used rivets, but I don't have any at the moment. I then placed the box into the space and the project was finished. I probably could have just made a tray out of sheet metal instead of using the safe, but I kind-of like the face of having something that has an extra layer of security. I mean, car doors lock and most glove-boxes have locks also. |
March 19th, 2013, 08:22 PM | #2 |
Talk about perfect fit; nicely done!
March 19th, 2013, 08:28 PM | #3 |
Thank you. Total time was about an hour and a half. I am going to attach a strap to the top of the box because its kind-of hard to get out of there. During this build I though of a way to create a hidden seat release so I can keep a spare key in that box... Just in case
March 19th, 2013, 08:43 PM | #4 |
Nice work!
March 19th, 2013, 09:20 PM | #5 |
Yes, yes... well done, well done.
March 20th, 2013, 05:15 AM | #6 |
March 20th, 2013, 07:15 AM | #7 |
Motorcycle Hypermiler
Join Date: Jan 2012 Motorcycle(s): 1999 & 2005 Kawasaki Ninja 250R's Posts: A lot.
Nice Job!!!
March 21st, 2013, 08:21 PM | #8 |
Note to all: Zip-Ties are not the best thing for securing the box. Lost a bracket during some riding around the neighborhood and about lost the box. Rivets are soon to replace them.
March 22nd, 2013, 05:34 AM | #9 | |
To make a pop rivet work right, you'll probably need little washers on both sides to keep it from pulling through the plastic. Rivet gun kit with assortment of rivets at HF for under $5.
March 22nd, 2013, 10:49 AM | #10 |
March 22nd, 2013, 10:55 AM | #11 |
Join Date: Sep 2012 Motorcycle(s): '06 Ninja 250, 2018 Honda GL1800B Posts: 315
Nice job. I've put Radio Shack plastic project boxes to similar uses on bikes. The cost only a few bucks and are available in several sizes.
March 22nd, 2013, 08:14 PM | #12 |
Why can't you turn the brackets the other way so bolt and rivets don't interfere?
March 22nd, 2013, 08:59 PM | #13 |
DIY - How to Reshape Your Seat For More Comfort | g21-30 | 2008 - 2012 Ninja 250R Tech Talk | 11 | October 3rd, 2012 07:47 PM |
DIY- Corbin seat install | kkim | 2008 - 2012 Ninja 250R Tech Talk | 66 | June 11th, 2012 07:03 PM |
DIY: Custom Seat shaping | setasai | 2008 - 2012 Ninja 250R Farkles | 15 | November 18th, 2011 06:59 PM |
considering this rear seat storage solution. FastPack by the Cycle Guys | shift_6 | 2008 - 2012 Ninja 250R Farkles | 15 | July 26th, 2009 05:29 PM |
DIY- Recovering seats with Custom Seat Creations Seat Covers | bryan | 2008 - 2012 Ninja 250R Tech Talk | 14 | March 20th, 2009 05:42 PM |
