March 15th, 2014, 07:50 PM | #1 |
Join Date: Oct 2013 Motorcycle(s): [2] 2006 Ninja 250s, [3]DRZs, [3]GasGas450s, [1]KDX 225 2 stroke,[1]650HondaCX, [1]Honda CBR1000rr Posts: 40
larger front rotor??
I initially posted [1st post] that my 250 was low on power. I fixed it with a 6 Sigma carb kit. K&N R-0990 Pod air cleaner and put on some after market slip-on exhausts from my other bike.
What a difference. Really love that bike now. Which brings me to my question.... does any one know of a larger sized rotor that has the same bolt pattern as the 250? Question 2 Is there an aftermarket device to move the handlebars forward or do I have to make them myself? Comment: Removing the stock airbox took some time but I was happy to do it knowing that I'd not have to fiddle around with the stock air box again. Now I can Pull the K&N and use my UniSync to sync the carbs in just a few minutes. Tony |
March 15th, 2014, 09:56 PM | #2 |
Yes various large rotor kits available.
Here is one for your model I believe http://www.beet.co.jp/english/kawasa...50r/index.html As far as moving bars forward many of the clip-ons would do that Woodcraft,Driven,Vortex etc |
March 15th, 2014, 10:05 PM | #3 |
The Violet Vixen
Join Date: Jun 2012 Motorcycle(s): Perigee (250), Hotaru (250), Saturn (300), Pearl (300), Zero (S1000RR), Chibi (Z125), Xellos ('18 HP4R) Posts: A lot.
MOTM - Jun '16
I have the clip ons on my 300, same as the new-gen 250 -- they'll move the bars forward and down. Highly recommended I recommend you find a way to put bar-end weights back on -- I used the fuel-line trick, but I don't know if that works on the pregen.
March 15th, 2014, 11:06 PM | #4 | |
As for moving the bars, sorry you're also a little off. Standard clipons will touch the tank and/or fairings unless they're adjusted to an awkward angle. The best way to get more aggressive bars on the pregen is with woodcraft lowered risers. They're more aggressive and have no clearance issues. They attach to the triples just like the standard OE risers. |
March 16th, 2014, 02:18 AM | #5 |
March 16th, 2014, 07:49 AM | #6 |
Thanks for the replies. I will look into the Handlebar suggestions. In the meantime I will fabricate some thin alum sheet stock to allow for moving the stock bars forwards.
As for the larger rotor issue. I have oversized rotors on all my plated bikes except for my CBR[Those brakes are just fine]. It's not so much fade issue as "feel". It just feels different than my other bikes and I'm just not that used to applying the added pressure that's required with the smaller front rotor. I always ride with my forefinger on the front brake. With the smaller rotor I find that many times one finger just isn't enough. Tony |
March 16th, 2014, 08:06 AM | #7 |
Join Date: Nov 2012 Motorcycle(s): Ninja 300, KTM EXC610SMR Posts: 913
A 4 piston GSXR Tokico caliper and the 1/2" master off a 08-14 works really well regarding feel. IDK what master you have on an earlier bike. A custom cal bracket will need to be made.
With help from Mania, I found a 320mm rotor for the 300 but I was ready to have an aluminum carrier built to add a floating outer rotor off a GSXR or similar bike. The 2000-maybe 07 Honda 929/954 bikes had 330mm rotors, but the carrier is most likely not a match. GSXR parts seem the most common and cheapest to source off ebay in good condition in the USA. |
March 16th, 2014, 08:30 AM | #8 |
If you're going after feel, start messing with MC vs caliper combinations. Larger rotor dissipates heat and requires less pull for the same braking. But unfortunately that's not really an option on the pregen. I've looked and found nothing so far.
Stainless threaded lines and vesrah sintered pads should help get you the bite and feel you're looking for. I know they made a good change on my bike. Also, go check out old3's thread about playing with various MC+caliper combinations. |
March 16th, 2014, 08:37 AM | #9 |
I haven't had a pregen in years and never messed with bigger rotors or better calipers on them. Is there anything blocking a bigger rotor install, something on the fork tubes or wheels that limit clearance?
March 16th, 2014, 08:49 AM | #10 |
No, nothing in the way AFAIK. I've just never seen a larger rotor that matches the bolt pattern and is 'intended' (or at least marketed) for the pregen.
So maybe such a thing does exist and we just don't know about it? |
March 16th, 2014, 09:44 AM | #11 |
Just got through looking through my EBC catalog again and couldn't find anything. However they do have a blank form page where you input your size requirements and they will make up a rotor for you.
The stock EBC # is MD 4041 RS and the rear is MD 4042. I haven't checked the bolt patterns for both the front and the rears but if they are the same the 40 series might indicate the bolt hole pattern and there are quite a few 40 series rotors in the catalog. I looked at the max size that could be allowed for the 16" wheels. A 320 might be a tight fit but a 300 would be a certainty. I've made brackets for relocating front calipers before. They usually take an hour to make by using alum stock, a drill press and a hack saw to trim the alum.stock. The biggest reason for me wanting a larger front rotor is I do a lot of riding in the twisties of the Calif mountains. Because of the roads being situated right along the hillsides many of the curves are blind curves. Going uphill isn't a problem but downhill if your going too fast is really scary if you are just about to enter a blind curve and find someone coming from the other direction and they're halfway in your lane. That's why the larger rotors on all my other bikes and that's why I always have one finger on the front brake. Nope, just checked. Front and rear hole patterns are not the same. Tony |
March 16th, 2014, 12:59 PM | #12 |
Join Date: Sep 2013 Motorcycle(s): 2006 Ninja 250, 2004 Buell XB12s, Honda 110 Elite Posts: 332
I tried a GSXR caliper on my pregen. Making the bracket was very easy. However, with the caliper mounted so the pads properly match the rotor, the back side of the caliper hits the wheel hub by maybe 10mm. A bit larger disc would allow it to clear.
On the other hand, at Daytona, I saw some interesting stuff where Cafe' racer builders had used early CBR 600 front ends on a variety of different bikes. I will make some measurements and see if this might work for the 250.
"They don't pay me enough to ride this thing!" Kenny Roberts after winning the Indy Mile on the TZ750 powered Grand National bike. |
March 17th, 2014, 08:12 PM | #13 |
EX500 full of EX250 parts
The EX500, both the 16" Gen1 and the 17" Gen2, uses the MD4016 (solid) and MD714X (floating) up front. They're 5x280mm and match the NewGen bolt pattern (I have an MD714X sitting on my Vrossi wheel right now).
According to http://www.visordown.com/reviews/mot...tml#review2310, the R1 rotor is also the same bolt pattern, but smaller holes. It uses a 298mm rotor. I couldn't find much detail on the 250 rotors/wheels, so I'm not sure how much this helps, but I thought I'd toss it out there.
March 18th, 2014, 08:59 AM | #14 | |
I have been looking through the EBC catalog as well as the Braking website and still haven't come up with anything. Is there a place where you can look online for rotors by bolt pattern and hole size. Also can someone give me the specifications of the pregen front rotor? I like the sprocket mfgs so much better[JT,Talon] they always list the specs. Makes it easy to cross reference. Tony |
March 18th, 2014, 12:02 PM | #15 |
Join Date: Nov 2012 Motorcycle(s): Ugly 89 frankenstien special ex250, and the "Zooks" : 1982 GS450 and 1979 GS1000 Posts: 327
Seems to me I've seen a few people around the site who have swapped in a 600 fork into the pregen, but I can't seem to put my hands on them right now. I think it's mostly for the suspension upgrade but AFAIK all the 600 sport bikes have dual discs, and a lot of them have some massive calipers too.
Seems like swapping forks might kill a couple birds with one stone, and keeps you out of re-engineering a major safety system.
Oh god the bikes are multiplying!!! |
March 18th, 2014, 09:09 PM | #16 | |
I know it doesn't fully answer your question, but I thought it might end up being somewhat helpful. Or it could be completely worthless, depending on the details of the PreGen's rotor... |
March 20th, 2014, 02:50 PM | #17 |
Join Date: Jun 2012 Motorcycle(s): 1998 Ninja 250 2007 Yamaha R6 2003 Honda RC51... sold :( Posts: 205
There are plenty of guys who have raced the ex250 over the years. I've never seen a single one install a bigger front rotor. The 16 in front wheel will also limit what you can do. If you have installed stainless lines and good pads, you have a pretty damn good setup. Like Chone said, you can always mess around with different master cylinder sizes if you want.
Personally, I would be more worried about two things: tires and suspension. Tires will limit how much braking you can do long before the stock master falls short (when paired with good pads and lines). The OEM front suspension is undersprung for anyone larger than a motogp racer, and the stock damping system is ancient technology. I would suggest the following: Pads Stainless line Respring front (and install an 08-12 shock in the rear while you are at it) Install race tech emulators in the front forks Get a good set of tires If you still have issues with being confident with the brakes on the street after all that, you should probably slow down a little. |
March 20th, 2014, 05:52 PM | #18 |
I for one am looking for better front brake. It isn't a question of how hard the stock setup will stop. I have a stainless line and EBC HH pads. It WILL stop. If you have a death grip on the lever.
If all you need is big stopping power for emergencies in a straight line situation, the stock set up will do (mostly). For me, it is a question of nuance. I don't want to have to death grip the lever for excellent brakes. It locks up you wrist by and large, and affects steering inputs and feel while trail braking. A "two finger" brake makes it a lot easier to manage steering inputs and throttle control. And yes there are times when you need a little throttle with your brake. I don't know if I want to go thru the trouble of major mods, or deal with it, because in the long run I will most likely trade it on a new bike. What kind of new bike remains to be seen. I already have a "big" bike, which quite frankly does not get ridden nearly as much as the little bike, or even the scooter. The last bike I decided to make a few enhancements to became a 2 year project, and cost several thousand dollars. All because no one builds what I WANT that can be bought at a dealership. I have already had insane thoughts about GSXR front ends, and RZ-350 engine transplants. Damn I love the smell of castor in the morning. Must resist. Time will tell. The new Hero bikes are coming this summer or fall. I may get an HX-250r if the build quality is good. Or wait n see about Yamaha or KTM. I want to stay under 400 cc. The thing that burns me up, is there are tons of perfect bikes that could be had, that fit the bill exactly, but they can't be brought to the good old USA and titled for use on public roads. I would give my left'n for an RS-250 to just run Ozella Trail.
March 29th, 2014, 08:15 PM | #19 |
Just swap the 08 front end on. It has a larger front rotor.
Motorcycle noob, feel free to ignore me. |
Larger rotor with Brembo 4 pot caliper | subxero | 2008 - 2012 Ninja 250R Tech Talk | 140 | March 4th, 2018 12:24 AM |
Do I need a new front rotor? | amad1972 | 1986 - 2007 Ninja 250R Tech Talk | 14 | August 23rd, 2014 10:11 PM |
[roadracingworld.com] - FIM Approves Optional Use Of Larger Front Brake Discs At All | Ninjette Newsbot | Motorcycling News | 0 | May 22nd, 2014 09:20 AM |
Which front rotor would you recommend. | abhijitz | Ninjettes At Speed | 17 | February 6th, 2013 11:06 AM |
