Old January 28th, 2012, 06:19 PM   #1
THE BIG SITT
THE BIG SITT's Avatar
A couple of issues with my new levers...
I got my new levers from Thetwowheels, but I'm having two smallish issues.
1. They seem to wiggle a little bit. I've got the bolts that hold them down as tight as they'll go, but that doesn't really do the trick. Any of you have this issue? What did you do?
2. The brake seems to have lost alot of responsiveness. It seems like I have to pull in way more than before to get any kind of braking power… wtf?
THE BIG SITT is offline   Reply With Quote
Old January 28th, 2012, 07:28 PM   #2
kevheads
kevheads's Avatar
Motorcycle(s): 2011 Green 250R
If I remember right, someone else had an issue with wiggle in their levers from 2wheels and they used a thin washer or washers against the levers to correct it. Wish I could remember who it was.
kevheads is offline   Reply With Quote
Old January 28th, 2012, 07:29 PM   #3
Flying Pig
Resident Lurker
Flying Pig's Avatar
Motorcycle(s): R6, Strom, 250R, CH80 Elite
You can find a washer at your local hardware store to help take away the freeplay, but I would avoid over-tightening the lever pivot bolts as they can sometimes bind the lever in place and prevent it from returning if they are too tight.
The levers that your purchased are adjustable. Push the lever outward, and change the dial. One is soft/close to the bars and 6 is more firm and the lever remains further outwards. Or vice versa, I forget
When was the last time you checked your tire pressure?
Flying Pig is offline   Reply With Quote
Old January 28th, 2012, 07:45 PM   #4
DaBlue1
DaBlue1's Avatar
http://www.ninjette.org/forums/showp...76&postcount=7
Old January 29th, 2012, 09:52 PM   #5
pilotgeorge747
pilotgeorge747's Avatar
Motorcycle(s): 08 Ninja 250r 03 Yamaha R6 (Project bike)
Careful on how much you tighten your lever bolts as I have the same levers and had my clutch bolt break in 2 while riding causing my clutch lever to fall off. It was most likely caused by a weakened bolt from my prior drop though.
pilotgeorge747 is offline   Reply With Quote
Old January 29th, 2012, 10:15 PM   #6
jdoucet93
jdoucet93's Avatar
Motorcycle(s): 2009 R6
I'm waiting on my levers from them. How long did it take for you to receive them from the date of your order?
SOLD MY NINJETTE and got THIS
jdoucet93 is offline   Reply With Quote
Old January 31st, 2012, 12:56 PM   #7
icbm
icbm's Avatar
Motorcycle(s): 2008 Kawasaki Ninja 250R, 2006 Suzuki Hayabusa GSX1300R, 2004 Kawasaki ZRX1200R, 1985 Kawasaki 750 Turbo
I got mine from a China reseller as well but not from Thetwowheels.
Mine came in after 2 1/2 weeks. Not unusual. I have bought several things from China. Some things came in within a week and most of the time about 2 weeks plus.
My packaging was small and the levers were covered with clear plastic wrap with no packing material. Well they were fine as they were a tight fit in the box nonetheless.
The levers look good I can tell the quality is good but not like my CRGs or Pazzos I have on my other bikes. Good enough as these only cost $34 total for 2 levers. They also fit good and have the typical looseness like the stock levers so nothing unusual there. Here are some pics. I chose the shorties since I am racing the bike.
icbm is offline   Reply With Quote
Old February 3rd, 2012, 11:24 AM   #8
icbm
icbm's Avatar
I rode the bike around and these levers perform well. Great buy for $34. And they look good too.
Old February 5th, 2012, 07:01 PM   #9
NikkitaNinja
NikkitaNinja's Avatar
Motorcycle(s): 2008 Kawasaki Ninja 250 *Nikkita* - 2003 Buell XB9R
I have the same exact levers..great buy and totally worth the 34$. Can't find anything wrong with them at all. Nicely machined out of a block of aluminum.
NikkitaNinja is offline   Reply With Quote
Old February 12th, 2012, 11:00 AM   #10
jdoucet93
jdoucet93's Avatar
Finally got mine in. they actually fit better than the stock levers. Very pleased.
Old February 12th, 2012, 11:37 AM   #11
kevheads
kevheads's Avatar
Did you end up going with the green shorty levers?
Old February 12th, 2012, 12:09 PM   #12
Careful how you install ALL levers. If the brake doesn't fully release, it can drag the front rotor. If conditions are right, the brake will overheat and lock up or be over pressured and will not relax the grip on the front rotor. Just happened to my friend a few days ago.
couple of issues Old Lemon 2008 - 2012 Ninja 250R Tech Talk 7 May 20th, 2014 06:16 PM
Couple of new pics... EtienneDP Pictures 4 October 14th, 2010 12:30 PM
Couple 08-09 Parts... Tims250R Motorcycle-related 6 December 7th, 2009 05:44 PM
Couple of questions pantera 2008 - 2012 Ninja 250R Tech Talk 5 May 6th, 2009 01:27 AM
Couple Self Portraits muffinman Pictures 16 April 29th, 2009 09:21 PM
