Old May 26th, 2014, 09:22 PM   #5641
algs26
Motorcycle(s): ex300, gave up looking for a 250
Maybe they didn't get all the air out? I remember running my car with the rad cap open to get all the air out.
If the fan isn't connected, at highway speeds it should still be ok, right?
algs26 is offline   Reply With Quote
Old May 27th, 2014, 04:38 AM   #5642
rojoracing53
Fast-Guy wannabe
rojoracing53's Avatar
MOTM - Jan '13
Shop not doing the whole job right that sucks, good luck.
You don't have a thermo-bob installed do you? If you did they can be a PITA to bleed all the air from the coolant system. Even a stock coolant system can be hard to bleed and some people don't take the needed time to do it right.
Old May 27th, 2014, 07:14 AM   #5643
mgentz
Board Member
what do you do?
I fill through the cap and squeeze the hose coming out of the head until it stops sucking coolant in. Then I run the bike with the cap off until it heats up and wants to come out the top. No issues ever so far, but in full disclosure I did put a bleed hole in my thermostat.
Old May 27th, 2014, 07:19 AM   #5644
verboten1
verboten1's Avatar
MOTM - June '15
not today, but yesterday, I went from this:
to this:
Ride more, worry less.
Old May 27th, 2014, 07:30 AM   #5645
rojoracing53
Fast-Guy wannabe
MOTM - Jan '13
Originally Posted by mgentz View Post
what do you do?
I fill it up best I can then start it for 30 seconds to prime the system. Then with my hand I pump(squeeze repeatedly) the lower radiator hose on the left side of the bike between the bypass hose and motor. This will cause air bubbles to ride to the cap and drop the fluid level a little each time so you keep adding fluid to keep it at the top. It takes several mins to almost all air out, then make sure the radiator and reservoir are topped off and go for a short ride just long enough to get to full temp. Top off your radiator one last time if needed, you to pumped the hose by hand enough then you should need any more fluid but if you do that fine.
The normal way of filling and bleeding the system doesn't woke if you have a thermo bob and can leave you quite a bit low on fluids.
I think after the initial bleed I would normally do on most bikes the most I've squeezed it with the method is around 10oz.
Old May 27th, 2014, 09:23 AM   #5646
heyzeus
Motorcycle(s): '07 Ninja 250r, Honda CBR 500r, Ducati multistrada, MV Agusta Brutale
Might have blown mine up this weekend. Check the little bolt that holds the bracket for the coolant line. If it comes loose your coolant line will blow off the water pump. To locate the said bolt fallow the coolant line from the pump up until you see a bracket the holds the line. Make sure you don't loose this bolt. Cross your fingers for me that my motor did not blow.
Current bikes: Kawasaki Ninja 250r, Honda CBR 500R,
Ducati Multistrada,
MV Agusta Brutale
heyzeus is offline   Reply With Quote
Old May 27th, 2014, 11:51 AM   #5647
InvisiBill
EX500 full of EX250 parts
InvisiBill's Avatar
Stuffed a few more 250 parts into the 500...
The 300 chainguard/mini-hugger conflicts with the 500's undertail fender, so I've got the plain 250 chainguard on for now. I still need to do the front wheel as well (waiting on a new EBC rotor that matches the bike better than the one I already bought ).
Spools are so much nicer than the generic flat pads under the swingarm...
Old May 28th, 2014, 12:28 PM   #5648
cbinker
Track Clown
cbinker's Avatar
MOTM - Sep '15
going riding in 3, 2,....
TEAM ALFALFA
www.apexassassins.com
Old May 29th, 2014, 07:36 PM   #5649
melfice
yes, I'm famous.
melfice's Avatar
Motorcycle(s): 2009 Ninjette 250R
Spent 4 hours running wires and making things look pretty.
I cant wheelie and that makes me sad.
melfice is offline   Reply With Quote
Old May 29th, 2014, 09:47 PM   #5650
cbinker
Track Clown
cbinker's Avatar
MOTM - Sep '15
Got the new springs and emulators installed!
TEAM ALFALFA
Old May 30th, 2014, 07:46 AM   #5651
menikmati
crash 250, get supersport
Motorcycle(s): 2010 250R SE (Sold 6/9/14), 2009 ZX-6R (Sold 6/25/14), Subaru BRZ
Lowered the price on the Ninjette to $2,800.
menikmati is offline   Reply With Quote
Old May 30th, 2014, 10:15 AM   #5652
cuong-nutz
cuong-nutz's Avatar
Cleaned the chain from riding in the rain yesterday.
HalfFast Racing Team
Old May 30th, 2014, 03:50 PM   #5653
cuong-nutz
cuong-nutz's Avatar
Chinese knock-off stomp grips. They suck and hurt in thin scrubs. Geared up would probably OK. I'll just see how long they last until I come about a Tech Spec deal.
Old May 31st, 2014, 01:43 PM   #5654
cbinker
Track Clown
cbinker's Avatar
MOTM - Sep '15
took it for a test ride today, the new springs are amazing! the braking stability is thousands of times better!
TEAM ALFALFA
Old May 31st, 2014, 03:32 PM   #5655
NevadaWolf
Certified looney toon
NevadaWolf's Avatar
MOTM Jul '13, Jul '14
Got her back!!
Coolant problem was due to rocks and mud getting up behind the radiator and preventing the fan from turning, that caused the fuse to pop, fan never turned, engine overheated, and viola coolant ends up on garage floor.
Most awesome was that wasn't the original issue I had taken it to the, for so totally expected a second service bill. Grand total $0.00!
SWEET!
<-- Linky
Old May 31st, 2014, 03:48 PM   #5656
Good find; I think I remember a rock stopping that fan buried somewhere else on this site, so it's a good reminder of something to check. I had certainly forgotten about it.
Old May 31st, 2014, 04:00 PM   #5657
cuong-nutz
cuong-nutz's Avatar
Good news Teri!
Old May 31st, 2014, 05:26 PM   #5658
NevadaWolf
NevadaWolf's Avatar
I know right?!
When he first told me it was rocks, I was like "I haven't been off road lately!" Then remembered that the original trip last week out me on my boss' dirt driveway and it was raining, instant mud soup that coated the underside of my bike.
:knock on wood: No more problems! I have a road trip!
<-- Linky
Old June 1st, 2014, 01:58 AM   #5659
Aggrotech
Aggrotech's Avatar
Motorcycle(s): 12' Ninja 250
havent rode my bb in awhile since i dont have the proper tools to adjust the chain. Tried to start her up today and the engine was dead so i hooked up a charger to her for the first time ever to get her running. Was rly nervous D:
Aggrotech is offline   Reply With Quote
Old June 4th, 2014, 09:33 AM   #5660
CaptainPlatypus
CaptainPlatypus's Avatar
Motorcycle(s): '86 Honda VFR700
Started her up for the first time since the accident last month today. Took some doing (wish our petcocks had a prime setting) but once she started getting gas all was well. Going to deliver her to a mechanic later today and set up an insurance appointment.
CaptainPlatypus is offline   Reply With Quote
Old June 4th, 2014, 11:48 AM   #5661
mgentz
Board Member
rode it.
Old June 4th, 2014, 08:52 PM   #5662
Spent a crazy amount of time scraping the adhesive from the headlight shell. My fingernails are ruined!
Old June 5th, 2014, 05:49 PM   #5663
cuong-nutz
cuong-nutz's Avatar
Found out that I broke the main tabs that hold the front fairing to the fairing stay. Because of that I also found out that I lost a bolt that held the fairing stay to the stem and that top bolt was was backing out. Will be zip tie-n my fairings back together.
Old June 5th, 2014, 08:05 PM   #5664
mgentz
Board Member
Cleaned it
Old June 5th, 2014, 08:11 PM   #5665
cuong-nutz
cuong-nutz's Avatar
Acetoned my ZG ST windscreen together for the 2nd time.
Old June 6th, 2014, 01:22 AM   #5666
Singh2jz
Singh2jz's Avatar
Motorcycle(s): '07 ex250-F/J
Test fitted my ghetto prototype custom turn signals.
here's a pic..
The Bike | The Truck
Old June 6th, 2014, 01:28 AM   #5667
psych0hans
psych0hans's Avatar
I've bought the same thing for my bike...
Old June 6th, 2014, 03:36 AM   #5668
Insane Pie
Motorcycle(s): '08 Ninja 250
Became one with my bike..kinda. Tachometer light went out and most of my riding has been at night lately, so I've been having to rely on ear rather than looking at the tach when shifting. Conflicted whether I should fix it or not.
Also two roadside repairs. First one of the nuts came off the shift connecting rod (don't know the name..), so had to reconnect that. Couple days later, the bottom bolt fell off of the left rearset while trying to shift..it was swinging. Luckly, the bolt fell between the kickstand and peg..
Also, both of the times happened around 3 am. That was fun..
Insane Pie is offline   Reply With Quote
Old June 6th, 2014, 03:59 AM   #5669
mgentz
Board Member
Rode it.
I have already done everything to it.....
Old June 6th, 2014, 05:13 AM   #5670
DCMoney
DCMoney's Avatar
Tail section Number plate template, turned out pretty got for taking a picture of the tail section with a ruler in it for scale and tracing the plate to scale.
MCRA.com
Old June 8th, 2014, 06:04 PM   #5671
menikmati
Cleaned, lubed and adjusted/aligned chain, lubed clutch cable and checked tire pressures.
Old June 8th, 2014, 06:48 PM   #5672
Hero Danny
Inline 4!!!
Hero Danny's Avatar
Cleaned the carbs for the 3rd time.
Be careful. Remember you are
invisible
Old June 8th, 2014, 07:15 PM   #5673
cuong-nutz
cuong-nutz's Avatar
Experimented with "welding" abs together.
Old June 9th, 2014, 06:48 AM   #5674
mgentz
Board Member
rode it to work again!
Old June 9th, 2014, 07:25 AM   #5675
NevadaWolf
NevadaWolf's Avatar
Rode it to make sure there really are no leaks anymore, plus to check balance of a full load of luggage.
My awesome daddy figured out a way to hold my soft saddlebags up and keep them from flopping inward under the tail (and potentially against the exhaust). He wrapped a strap around the bags and up over the tail to hold them in place.
Bonus, I get my rear pegs back to hook my boot on while riding!
<-- Linky
Old June 9th, 2014, 11:50 AM   #5676
menikmati
Sold it, I never noticed how awesome it sounded until I watched it being ridden away.
Old June 9th, 2014, 12:16 PM   #5677
melfice
yes, I'm famous.
melfice's Avatar
last night i installed my 2nd hand two brotherrs exhaust and found out that it didnt come with the clamp that hold it to the midpipe...so i need to improvise some sort of way to hold it together. most likely the guy who sold it to me kept it and never planned on sending it or he forgot about it, no biggie. after work (in about 40 min) I plan on installing my Yoshi rearset risers and my black ebay pegs. pics to follow soon.
Last futzed with by melfice; June 9th, 2014 at 05:13 PM.
Old June 9th, 2014, 01:18 PM   #5678
cuong-nutz
cuong-nutz's Avatar
I had that issue with my bags acting like a sail on one of my road trips a while back. The next time I go out again I'm just going to mount some brackets to secure them.
Old June 9th, 2014, 01:35 PM   #5679
NevadaWolf
NevadaWolf's Avatar
I think if I am going to do this kind of trip again, I am investing in a set of hard bags with proper mounts and that lock. I can foresee one of the hassles on this trip is going to be unmounting and remounting the bags each evening and morning. Ugh.
<-- Linky
Old June 9th, 2014, 01:37 PM   #5680
NevadaWolf
NevadaWolf's Avatar
Congrats on the sale.
I see you also have the ZX6R listed in your sig. Getting a new bike or what's the next adventure?
<-- Linky
Discovered something scary about my Ninjette today... kjohng General Motorcycling Discussion 28 October 15th, 2021 01:40 PM
Sold the 2006 Ninjette today :( Renner General Motorcycling Discussion 31 October 16th, 2014 11:46 PM
Today I Gave My Ninjette Wings! BlueHairSar Pictures 5 June 20th, 2013 07:38 AM
my bro went down today on his ninjette richierich781 !%@*#$%!)@#&!%@ I crashed! 46 January 18th, 2013 11:59 AM
Ninjette. org hacked today CC Cowboy Off-Topic 9 April 3rd, 2011 08:55 AM
