Old August 4th, 2016, 02:00 PM   #1
Lap202
The Mechanical Noob
Exclamation Bolts stuck on front brake caliper
Title says it all, I need to swap out my speedo drive, so tire needs to cone off, but can't get these bolts to budge. Yes ime turning them counter clockwise.
My other option is the reason I have to replace drive is when I rotate the cable that's still attached, it spins the threading also.
Help!
Lap202 is offline   Reply With Quote
Old August 4th, 2016, 02:03 PM   #2
ForceofWill
Blind 250 Loving Whore
ForceofWill's Avatar
You have a breaker bar?
Old August 4th, 2016, 02:05 PM   #3
Lap202
The Mechanical Noob
Um no, might try the pipe method and see if it comes loose. Literrally bent the connector on my socket wrench using a pipe -.-
Old August 4th, 2016, 02:12 PM   #4
ForceofWill
Man, shop must have put them on with an impact gun lol. I've sheared off the 3/8" drive on a breaker bar before but that's hard to do with a normal sized socket wrench. Did you stand on it or are you just a beast?
Either way, you might be better off hitting the wrench handle with a mallet to jar them loose, if they're already on that tight.
Old August 4th, 2016, 02:17 PM   #5
Lap202
The Mechanical Noob
Well I used a broken hockey stick so had a ton of leverage :P
Old August 4th, 2016, 02:17 PM   #6
When pressure will not do... you need heat or vibration. Heat is easy via a propane torch from the hardware store. Vibration is a bit more expensive but worth every penny in the end.
Old August 4th, 2016, 02:23 PM   #7
SLOWn60
n00bie to wannabie
SLOWn60's Avatar
Motorcycle(s): 2012 250R (Red), 2005 VFR800A (Red), CRF450X (Red), 2012 F800GS (Wants to be Red!)
MOTM - Nov '15
....Ok what am I missing here
Why are you taking the calliper off to remove the wheel & speedo?
You do need to service those bolts sometime but not to do what you've originally set out to do.
The Smart Money: #1 - ATGATT, #2 - Training (machine skills and survival skills), #3 - The bike; whatever floats yer boat with the money you have left over
SLOWn60 is offline   Reply With Quote
Old August 4th, 2016, 02:24 PM   #8
While we both know that it is not a requirement, there is no harm either.
Old August 4th, 2016, 02:27 PM   #9
SLOWn60
n00bie to wannabie
SLOWn60's Avatar
MOTM - Nov '15
You beat me to my edit! You need to get a real job!
Old August 4th, 2016, 02:29 PM   #10
Old August 4th, 2016, 02:36 PM   #11
SLOWn60
n00bie to wannabie
SLOWn60's Avatar
MOTM - Nov '15
LOL! @csmith12; my mom has a lot of pictures of me with that expression!
Sorry OP for the thread jack. I'll try to find the thread on this forum about 6 months old that thoroughly covers this very problem of seized calliper bolts. Lots of great info in it!
Old August 4th, 2016, 02:42 PM   #12
SLOWn60
n00bie to wannabie
SLOWn60's Avatar
MOTM - Nov '15
Turns out that thread was calliper pad pins but the same remedies would apply:
https://www.ninjette.org/forums/showthread.php?t=109517
Old August 4th, 2016, 03:38 PM   #13
As an old hand at turning a wrench myself. I totally forgot about the #1 goto. Penetrating oil soak/spray for about 15 or so mins. In KY that would be WD40, in other areas that would be liquid wrench. lol
Old August 4th, 2016, 04:19 PM   #14
Hellmutt
Vanilla Gorilla
Hellmutt's Avatar
Motorcycle(s): '11 Triumph Sprint GT & '06 625SMC
If you're trying to pull the caliper mount bolts and they're seized, and you dont have an impact gun....use the boxed end of THE CORRECT SIZED combo wrench. Make sure the wrench is firmly against the sidewall of the bolt so it's ready to loosen and strike it with a deadblow hammer. May take a few good whacks to get it to break loose. Seems someone overtorqued those. Shouldn't be but maybe 25-30 ftlb.
FWIW, I rarely break wheel end fasteners loose with a socket wrench. Almost always use combo wrench to get them untorqued, then ratchet out or turn by hand.
Oh, and once they're out....put a dab of antiseize on those threads before you put it back together....makes it much easier the next time
Hellmutt is offline   Reply With Quote
Old August 4th, 2016, 05:17 PM   #15
Lap202
The Mechanical Noob
Does the wheel just come off, would make my life so much easier!
Old August 4th, 2016, 05:25 PM   #16
SLOWn60
n00bie to wannabie
SLOWn60's Avatar
MOTM - Nov '15
Yes. Just slide out the axle and the wheel drops right out. You do have to tilt the wheel to clear the caliph but it's simple & pretty obvious. Just be sure not to squeeze the brake lever!
Old August 4th, 2016, 05:30 PM   #17
Hellmutt
Vanilla Gorilla
Hellmutt's Avatar
The rotor and wheel should clear the caliper.
What I do for my wife's 300 is get the front of the bike off the ground AFTER you loosen the axle, you could topple the bike while breaking the axle loose while on a stand. I support the tire with a couple planks of wood under it to take the load off of the axle, then drive the axle out. Take note which axle spacer goes on which side when you take the wood planks out from under the tire, cant remember if they're different on these bikes or are the same part.
Old August 4th, 2016, 10:47 PM   #18
Lap202
The Mechanical Noob
My lifting technique involves driving it up a car ramp and having a friend help me lift it off the end and set it on the engine :P then he'll hold it till I'm done
Old August 5th, 2016, 04:10 AM   #19
ForceofWill
Just think if you had a front headlift stand!
Old August 5th, 2016, 04:52 AM   #20
adouglas
adouglas's Avatar
Motorcycle(s): Aprilia RS660
VERY VERY important note... if you ever use an impact wrench (or a hand-held manual impact driver), DO NOT use it to tighten a fastener. The torque it applies (hundreds of ft-lb, delivered over a very brief time, over and over) can easily snap a stud or stretch threads.
Mechanics do use impact guns to install big, non-critical fasteners (e.g. lug nuts) because it's faster, so it can be done... but it doesn't gain you anything except a few seconds and it's very risky.
Super-handy for getting stuff off, though. I have a simple hand-held impact driver (the kind you whack with a mallet) and it's saved my bacon on a few occasions.
If you want to use a power tool to put stuff on, use a cordless drill or ratchet, then finish off with a torque wrench.
Old August 5th, 2016, 05:18 AM   #21
You're so right good sir! There is not one single bolt on my bikes that I would use that to torque down. The cordless drills that have clutches on them are even better for preventing overtorquing.
Old August 5th, 2016, 05:32 AM   #22
JohnnyBravo
Certifiable nontundrum
JohnnyBravo's Avatar
MOTM - Sep '13, Sep '16
I hate working on stuff after an idiot hahaha, you wouldn't believe some of the crazy stuff I've seen, and once maybe I've been the idiot someone else worked after
Old August 5th, 2016, 05:42 AM   #23
ForceofWill
This.
I love my Bosch 18v, just set the clutch really low and it saves me lots of time installing bolts.
Check front brake caliper bolts old3 2013 - 2017 Ninja 300 Tech Talk 8 November 20th, 2012 04:01 PM
08 ninja 250 front brake caliper randomwalk101 Items Wanted 0 December 24th, 2011 06:15 PM
Help! Installing front brake caliper strakka 2008 - 2012 Ninja 250R Tech Talk 5 November 2nd, 2011 08:31 PM
Front brake caliper bolts...wtf? Bleak21 1986 - 2007 Ninja 250R Tech Talk 9 November 16th, 2010 08:59 PM
