September 15th, 2012, 07:36 PM | #1 |
Lays er down
Join Date: Apr 2012 Motorcycle(s): 2008 Lime green Ninja 250R Posts: A lot.
Back protectors
So i always see one pieces that have that hump thing in the upper back part of the suit, im assuming that is a back protector. Well i just bought a 2 piece sedici suit and there is no place to add something like that on. I can unzip the mesh part of the inside to an area that is just vacant between the leather and the mesh. But it is so large i dont think i could just add a back pad and have it stay in place.
It does have this foam pad but id hardly call it armor, and there is no zipper for me to get into that area to take it out and replace. There is also no front armor, just some spots of hard foam stuff and leather. So i was thinking i could get something like this http://www.cyclegear.com/eng/product...est/web1000256 to wear under my jacket. Any suggestions? |
September 15th, 2012, 07:41 PM | #2 |
No, the hump on the back of race suits is referred to as a "speed hump" and not designed to protect your back. What you need to do is google "back protector insert" for a product that will fit in your suit or get one that is designed to be worn under the suit.
September 15th, 2012, 07:43 PM | #3 |
I would strongly lean toward a knox if you go for one that is not an insert.
September 15th, 2012, 07:50 PM | #4 |
I use an Icon Stryker (pic below) Vest under all my suits because there is either no chest armor or crap chest armor in most 1 and 2 piece suits. And as you have found, the foam pad insert in a lot of suits is pretty much a joke. The knox one is pretty comfy too under the suit if the icon is a bit much and they offer a more modular product. You can were just the back, just the front or both.
Icon Stryker Knox (back and chest)
September 15th, 2012, 07:59 PM | #5 | |
crash 250, get supersport
Join Date: Apr 2010 Motorcycle(s): 2010 250R SE (Sold 6/9/14), 2009 ZX-6R (Sold 6/25/14), Subaru BRZ Posts: A lot.
I use an Alpinestars Bio Armor insert in my jacket, a great improvement over the stock foam padding. http://www.revzilla.com/motorcycle/a...back-protector |
September 15th, 2012, 08:09 PM | #6 |
Lays er down
the stryker looks like a solid deal. good reviews and a good price. knox looks good too but its basically the same price since i would want both the back and front armor so it would be around 130 euros (idk how much it is in dollars). so 130 dollars that i can go buy in person sounds good.
and what exactly does the speed hump do? |
September 15th, 2012, 09:15 PM | #7 |
aerodynamics. Cool style.
September 15th, 2012, 09:17 PM | #8 |
The stunters love them. The serious racers usually get something else.
September 15th, 2012, 09:31 PM | #9 |
Que Buenos Son!!!
MOTM - Nov '14
I just checked out a bunch of back protectors and vests yesterday. The Icon looks cool and the price is good. It is only CE 1 rated however.
I also liked the A*'s version. http://www.ironpony.com/ironponydire...EET%20PRODUCTS http://www.motorcycle-superstore.com...ic-2-Vest.aspx I didn't buy a back protector, got a cold weather jacket instead. I'm waiting to buy this. http://www.revzilla.com/motorcycle/f...-pro-kevlar-l2
September 16th, 2012, 01:33 PM | #10 |
Join Date: Apr 2011 Motorcycle(s): 2022 Honda CRF300L Rally, 2015 Ninja ZX6R 636, 2014 Ninja 1000, 2013 Ninja 300 (sold), 2011 Ninja 250R (sold) Posts: 479
Look at Forcefield.
September 17th, 2012, 03:18 PM | #11 |
Join Date: Oct 2009 Motorcycle(s): 09 Ninja 250 Posts: 56
++1 on Forcefield...saved me broken ribs on a 45mph getoff into a 6ft ditch..
September 17th, 2012, 03:26 PM | #12 |
try it on with the suit and helmet you are going to use, on the bike you are going to use it before you commit to it. (or buy from somewhere with a good return policy) i got a free protector with my suit but it was just slightly too big, really uncomfortable when it comes to actually racing in it but not something you notice when you just try it on without being in a racing position.
September 17th, 2012, 06:02 PM | #13 |
Gixxer Powered
Join Date: Mar 2012 Motorcycle(s): 2007 GSXR 600 Posts: 397
Also look into a back protector that isn't a "one and done" type of deal. I picked up a Knox Contour back protector since it's multi-use, really wasn't that expensive and it provides more coverage than forcefield.
September 17th, 2012, 06:26 PM | #14 |
Join Date: Dec 2011 Motorcycle(s): 2011 GIXXER 600 Posts: 381
i just toss the icon stryker under my jacket.. CE approved and comfy
"You see it's not the blood you spill that gets you what you want. It's the blood you share, your family, your friendships, your community. These are the most valuable things a man could have." |
September 17th, 2012, 07:40 PM | #15 |
So, where's the reverse?
I have the Alpinestars SMX Bionic 2 vest. It has a chest plate, a CE 2 back protector, is lightweight, breathable and with a low profile design, hardly adds any bulk at all under a jacket. One criticism is that there's no coccyx coverage.
September 18th, 2012, 08:08 PM | #16 |
Join Date: Jun 2012 Motorcycle(s): 2010 Ninja 250 Posts: 212
The hump helps with aerodynamics, and protects your neck by preventing your head from touching the asphalt and being ringed forward, I say +1 on a force field ce lvl 2 back and ce lvl1 front, reusable but pricy
September 21st, 2012, 02:57 AM | #17 |
Gixxer Powered
Forcefield also just came out with what they call the Race-Lite vest which you could look into. It's a zip on vest with a CE 2 back protector that is thinner and more flexible than the other back protectors they have.
September 21st, 2012, 10:12 AM | #18 |
I just noticed that last week. I'm wondering if I should sell my existing Forcefield protector and buy the new vest. My friend had many injuries spared last week because he was armored head to toe under his one piece. He was still critically injured at the neck, but who wouldn't be in a 60 mph cartwheel?
September 22nd, 2012, 06:12 AM | #19 | |
Gixxer Powered
September 22nd, 2012, 06:18 AM | #20 |
I've only used the Knox back armor for jackets. Forcefield covers plenty once you try it on. I shopped for protection for a while before I settled on the Pro Sub 4. I was comparing it to stuff available at Cycle Gear. None of the Alpinestars or Dainese felt comfortable to me.
September 22nd, 2012, 06:21 AM | #21 |
I just picked up one of these for $80.
http://www.alpinestars.com/shop/cate...onic-jacket-2/ So far, it's ****ing awesome.
I UPGRADED to a YZF-R6 Mods: Shermoto LF7 Levers / Proton Flushmounts / Puig Smoked DB / Woodcraft Sliders / Tech Spec C3 Tank Grips / Rizoma Grips / Jardine |
September 22nd, 2012, 06:24 AM | #22 | |
Gixxer Powered
September 22nd, 2012, 01:47 PM | #23 |
Ninjette Fanboy
Join Date: Jun 2012 Motorcycle(s): 2008 Ninja250 Posts: 307
September 22nd, 2012, 02:01 PM | #24 |
Join Date: Jun 2012 Motorcycle(s): 2013 Ninja 300 Posts: 528
I was also going to suggest the Stryker vest. Greg has one and his is sized small. I'm sure he'll let you try it on. Should've asked when you were over lol
I'm not short, I'm concentrated AWESOME! |
October 2nd, 2012, 01:02 PM | #25 |
Que Buenos Son!!!
MOTM - Nov '14
I just checked out this company after seeing one of their chest protectors in a magazine. Looks like some pretty serious gear, and worn by quite a few racers. Definitely worth checking out.
http://impactarmor.com/ Troy Corser credits his chest armor for saving his life after his BMW landed on top of him in a crash. Ouch! http://www.gaskrank.tv/tv/wsbk/sbk-2...-bmw-12982.htm
[roadracingworld.com] - Dainese U.S.A. Offering Free Back Protectors With Purchase Of | Ninjette Newsbot | Motorcycling News | 0 | August 23rd, 2013 11:10 AM |
[motorcycle.com] - Dainese Offering Free Back Protectors With Purchase Of D-Dry Or Go | Ninjette Newsbot | Motorcycling News | 0 | August 16th, 2013 03:30 PM |
[motorcyclenews.com - news] - You Ask/You Answer: Back protectors | Ninjette Newsbot | Motorcycling News | 0 | April 14th, 2013 10:40 AM |
back and chest protectors | jboyd12 | Motorcycle Gear | 18 | January 13th, 2012 01:15 PM |
[motorcycle.com] - Ducati gives away 5,000 back protectors | Ninjette Newsbot | Motorcycling News | 0 | May 11th, 2009 02:00 PM |
