April 29th, 2016, 05:42 PM | #1 |
Join Date: Apr 2016 Motorcycle(s): 2012 Ninja 250 Posts: 4
Having trouble removing rear brake caliper...
Hi all, I'm trying to remove my rear wheel to get my tire changed but I'm having some trouble removing the caliper. The caliper mounting bolts on the bottom are stuck, and I might have stripped one of them trying to get them off. Any solutions? I didn't want to try anymore because I didn't wanna make it worse than I already did.
Also, those bolts are really hard to get to because the brake fluid line(?) is in the way, and doesn't give me much clearance. Will there be anything I can do to get around it? |
April 29th, 2016, 05:44 PM | #2 |
Vintage Screwball
MOTM - Mar '16
You don't have to remove the caliper to remove the rear wheel.
Pull the axle. The bracket the caliper is on slides on a bar on the inside of the swingarm and is held in place by the axle.
Goin' fast on slow bikes! |
April 29th, 2016, 06:23 PM | #3 |
MOTM - July '15
fwiw i found a small blob of JB weld was on one of my caliper bolts. Effing PO's.
April 29th, 2016, 06:36 PM | #4 |
:\ Damn...
April 29th, 2016, 08:12 PM | #5 |
n00bie to wannabie
Join Date: Sep 2015 Motorcycle(s): 2012 250R (Red), 2005 VFR800A (Red), CRF450X (Red), 2012 F800GS (Wants to be Red!) Posts: A lot.
MOTM - Nov '15
I was going to give you an "unhelpful" but I mean it for the PO!
The Smart Money: #1 - ATGATT, #2 - Training (machine skills and survival skills), #3 - The bike; whatever floats yer boat with the money you have left over |
April 29th, 2016, 10:58 PM | #6 |
MOTM - July '15
OP if that's your case, find an allen key that'll JUST fit with some hammering (be gentle, I think some of those parts are alum), and a long pipe. Then, replace the bolt and possibly the part if you need to. Lucky, I didn't. You don't need to take off your brake caliper in this instance, but you probably will want to eventually.
Rear Brake Light Trouble | Devita818 | 2008 - 2012 Ninja 250R Tech Talk | 16 | April 18th, 2015 07:50 PM |
Rear Brake Bleeding Trouble | dwright0723 | 2008 - 2012 Ninja 250R Tech Talk | 14 | May 7th, 2014 07:26 PM |
Rear Brake Caliper Help | blap6798 | 2008 - 2012 Ninja 250R Tech Talk | 4 | April 2nd, 2012 07:25 PM |
Rear brake caliper mounting help. | fbalsam | 2008 - 2012 Ninja 250R Tech Talk | 4 | April 1st, 2012 08:21 PM |
Rear brake caliper | Reswob | 2008 - 2012 Ninja 250R Tech Talk | 4 | April 8th, 2010 08:16 PM |
