June 9th, 2016, 07:28 PM | #1 |
Join Date: Jun 2016 Motorcycle(s): 2003 EX250F Posts: 12
Troubleshooting a no crank situation
Firstly I would like to say I have appreciate any help I might receive.
So the issue is a no crank. The bike is an 03 EX250F with 1,600 miles. I purchased the bike about 30 days ago. The battery is new, I replaced it. The bike would crank and run the last time I tried it, which was a few days ago. I have put 20 miles on it since I got it. The battery is charged and has an approximate static voltage of 13volts. The battery voltage when the starter relay is engaged is 12.7 volts. With the plugs out bike on the center stand and kickstand up and clutch pulled in and in neutral and the key in the on position and you push the starter switch, the relay makes one solid sounding click. The starter does not make any noises and the engine does not crank. I removed the stator bolt cover and turned over the engine. It seems to turn over fine. With the transmission in 1st and the clutched disengaged its hard to push. With the clutch engaged in 1st its possible to move in reverse but impossible to move forward. When I move it in reverse it makes a sound like the starter motor spinning or some gears turning. It seems like its locked up when trying to push it in the forward direction. All of that was done with the plugs out. Any suggestions? |
June 9th, 2016, 07:31 PM | #2 |
Did you test the starter solenoid? Do you have power, lighting?
June 9th, 2016, 07:38 PM | #3 |
The cluster lights up as normal.
The relay clicks once for every press of the switch. I'm not sure how to test the relay. |
June 9th, 2016, 07:45 PM | #4 | |
If it cranks then odds are it's the solenoid, test a few times to verify, then buy a new solenoid. Caltric Starter Solenoid Relay Fits Kawasaki EX250 Ninja 250R 250 1986-2010 https://www.amazon.com/dp/B0074MNHSO..._.LIwxbG7A6B3V
June 9th, 2016, 07:56 PM | #5 |
I did try that. Nothing happened. No sounds, no anything.
June 9th, 2016, 08:07 PM | #6 |
Okay, well you've bypasses everything by doing that, no sparks? Nothing? You did touch both posts at the same time, using the metal screwdriver as a bridge, thereby closing the circuit.
If you did it correctly, and nothing happened, I would turn my attention to the grounds.
June 9th, 2016, 08:26 PM | #7 | |
There is a plug in the left cover for turning the crankshaft manually. Did you put the that cover back, verifying that the gear that connects the starter's pinion and the gear in the alternator aligns and works properly? If so, I would remove the starter and test it unloaded. If that is OK, I would open the valve's cover to verify that all the valves return to the closed position while turning the engine by hand. I see no reason for the engine not to rotate by pushing the bike forward, other than a bent valve.
June 9th, 2016, 08:30 PM | #8 |
My personal opinion is the gearing on the starter is seized or something similar.
I had the same issue last week but rocking the bike while in gear seemed to "free it up." |
June 9th, 2016, 08:32 PM | #9 | |
June 9th, 2016, 08:35 PM | #10 |
While turning the crank in the clockwise direction it sounded like it might have been spinning the starter as well, just like when I rolled the bike backward in gear. Maybe the starter is bound up?
June 10th, 2016, 08:56 PM | #11 |
If the starter is good, and the relay is good, and the battery is good, what do I do next? I am sure the problem is in the gearing the starter connects to. What would I do to fix that? When the starter was cranking the engine, it would make the bike roll forward with the clutch disengaged while in first. Is it possible the clutch plates are stuck together? I had only put a few miles on it in the last month, but my understanding is that the bike sat for at least 5 years or more.
June 10th, 2016, 09:24 PM | #12 |
Vintage Screwball
MOTM - Mar '16
Start it in neutral....if it's got enough juice to roll it in first, it should work in neutral.
Goin' fast on slow bikes! |
June 10th, 2016, 09:48 PM | #13 |
Well it doesn't crank at all now, whether in neutral or not. I'm wondering if anyone has mechanical knowledge of how the starter pinion gets to the crank. I think somewhere there is the problem.
June 11th, 2016, 12:00 AM | #14 | |
Join Date: May 2016 Motorcycle(s): GPX250-RII Posts: 296
part numbers 92122 92043 92081 |
June 11th, 2016, 04:25 AM | #15 | |
Install crank. Done.
June 11th, 2016, 05:24 AM | #16 | |
If you cannot turn (counterclockwise) the crankshaft by hand more than two full turns, you have a valve problem. If you cannot turn (clockwise) the crankshaft by hand one full turn, you have a valve problem of broken teeth in one of the gears. Starter pinion (counterclockwise rotation) -> connecting gear (clockwise rotation) -> gear of one-way clutch behind generator (counterclockwise rotation)
June 12th, 2016, 08:19 PM | #17 |
I have removed the generator cover to inspect, everything is perfect. I removed and disassembled the starter motor. After reassembly and re installation it worked, the bike ran perfectly for about 20 - 30 minutes. I stopped to get gas. No crank. Pushed home. #sad. There is 12.6 volts getting to the starter motor, I have confirmed. And the grounding is fine because the 12.6 volts makes it back to the frame through the starter.
Next step: buy replacement starter motor. |
June 13th, 2016, 05:11 AM | #18 | |
you may want to examine the armature and brushes prior to buying a starter, no?
June 13th, 2016, 04:38 PM | #19 |
you should also check the connection terminals in everything between the starter and the battery , i had an older bike and its full of white powdery stuff and the electricity cant get through i had to use a sandpaper and some elbowgrease
August 10th, 2016, 08:28 PM | #20 |
Problem solved
PROBLEM SOLVED: For anyone who reads this in the future the problem was in fact a faulty starter motor. Bench test your motor very early in the troubleshoot procces. If it does not work every time scrap it. I bought a used starter on eBay for $20 off an 09.
Thanks for every ones help |
Troubleshooting | knightdalton | 1986 - 2007 Ninja 250R Tech Talk | 4 | May 25th, 2016 05:16 AM |
Troubleshooting my Ninja | zenmike | 2008 - 2012 Ninja 250R Tech Talk | 7 | December 6th, 2014 07:26 PM |
Troubleshooting Battery/Alternator Help | bkh2 | 2008 - 2012 Ninja 250R Tech Talk | 2 | February 20th, 2012 11:45 AM |
Having some troubleshooting issues... | Cloud Strife | 2008 - 2012 Ninja 250R Tech Talk | 70 | April 19th, 2011 02:58 PM |
Troubleshooting Help (External Link) | g21-30 | 2008 - 2012 Ninja 250R Tech Talk | 3 | September 20th, 2009 02:47 PM |
