Old June 23rd, 2011, 04:24 PM   #1
joes280
Motorcycle(s): 250
636 fork conversion- steering stem welded in?
I've seen a couple of indonesian 250's and a guy on stuntlife do the swap. From what I see the 08 stem is welded in. From other bikes I know they are pressed in. And you can swap them usually.
Just wanted insights before I started hackin ish. Anybody got any info, just don't wanna reinvent the wheel unless I have to.
joes280 is offline   Reply With Quote
Old August 14th, 2011, 01:43 PM   #2
Did you make any progress on this?
Old April 11th, 2012, 10:21 AM   #3
extremez31
extremez31's Avatar
Motorcycle(s): 94 EX250, 81 GS450
interesting, I have a complete 636 front end which i started to use on on a gs400 Cafe build. its tempting but im not sure if its such a good idea. The brakes are insane, also the front 636 rim is wider than the ninja rim. I believe the pregen rear rim is 2.5 inches wide and the 636 front is 3 inches. would having a wider front rim than rear rim affect handling?
the 636 front takes a 120 wide and the ninja rear takes a 130 wide. I suppose you could strong-arm a 110 on the 636 front but i think handeling would be affected more than anything.
I suppose i could just mount a single caliper and rotor which is still probably too much but would feel safer.
Anyone have any input?
extremez31 is offline   Reply With Quote
Old April 11th, 2012, 06:39 PM   #4
Jono
Jono's Avatar
Mmmhm. Doesn't seem worth it to me. And it would just look weird!
Old April 13th, 2012, 08:36 AM   #5
kamikaze
ex-ninjette.org guru :o
kamikaze's Avatar
Motorcycle(s): 2003 SV1000 S
120 front would prolly be ok if you went with a 140 or 150 rear.
kamikaze is offline   Reply With Quote
Old April 13th, 2012, 09:50 AM   #6
extremez31
extremez31's Avatar
But thats the thing, I wouldn't want to increase the rear tire width on the ninja. I love the way it rides. If the bike was putting out 42-50 hp a 140, 150 tire would be welcomed. Truth is any of those changes would hurt the ninja, it'll look cook.
Old April 13th, 2012, 11:54 AM   #7
Kevin2109
KThanksBye
Kevin2109's Avatar
Motorcycle(s): 2006 zx636r
Do a 140, thats the ideal size for this bike, gives you just enough rubber to use
----> My Youtube! <----
Old April 13th, 2012, 12:09 PM   #8
+1
Old April 13th, 2012, 12:14 PM   #9
extremez31
extremez31's Avatar
Thanks for the replies. What tires would you recommend on the pregen 250? I do want to do some trackdays so more emphasis on sport riding.
I need some rule books on the fork conversion, this would look pretty but i have a feeling it will put me up against some serious bikes.
Dampening should be ok as the bikes are not too far apart in weight. I may just do this...
Old April 13th, 2012, 05:00 PM   #10
duckracer
duckracer's Avatar
Motorcycle(s): Ducati 1098 and 04 Ninja 250 race bikes
I have done this conversion (pic's of Duc-asaki) will be posted in another thread soon. I used a Yamaha R1 front that I had lying around. So, yes the 250 triple clamp stem is press fit, then welded in, but only at the bottom. You grind the weld down and press the stem out. The 636 stem is the same size as the R1 stem. But it is aprox 1/4 inch larger diameter than the 250 stem. So you need to weld up the 250 stem larger than the press fit for the 636 lower clamp, then turn it down to a 1 to 2 thousands interfearence fit. Heat the lower clamp and cool the stem then press them together and your lower is done (you can't weld them as the stem is steel and the clamp aluminium).
The upper clamp has a smaller diameter seat so that will need to be milled to provide the correct stack height. That is all the machining you should need.
The front tire is now a 120/70. I run a single caliper and have more than enough stopping power. On the rear I am running a 17 inch new gen wheel with a 140 tire. Keep an eye open for the new thread and you will be able to see how I eliminated the rear caliper torgue arm. My rear caliper is mounted with a one off caliper mount/wheel spacer that retains the caliper vie the swing arm top and bottom.
The turn in will be just a tad slower with the bigger tires. That is easy to fix by raising the rear or lowering the front. I have my forks set 10mm from the top triple and the turn in now matches my Ducati 1098 race bike.
So this is a good conversion, but for most racing orgs it will be illeagle and push you into 250 superbike. Check your rule book. My org's 250 lw gt is a run what you brung 250 only class so mine is accepted
duckracer is offline   Reply With Quote
Old April 16th, 2012, 01:24 PM   #11
gt_turbo
gt_turbo's Avatar
Motorcycle(s): '09 250R, '13 CBR500R
@duckracer what did you do with the ignition switch? i am working on a 636 front conversion on my 09 250r, the 250 ignition seems too small to fit the 636 triple.
gt_turbo is offline   Reply With Quote
Old April 16th, 2012, 01:27 PM   #12
extremez31
extremez31's Avatar
I think using a 636 ignition and key would be the simplest solution
Old April 16th, 2012, 01:38 PM   #13
gt_turbo
gt_turbo's Avatar
i thought about that, but not sure if the connector between the two bikes would fit or not. if it doesn't then i'd have to splice it up, but i'm trying to keep it as close to stock if i want to go back. plus carrying 2 different keys for the ignition/tank is something i want to avoid.
Old April 16th, 2012, 05:00 PM   #14
duckracer
duckracer's Avatar
Sorry, been busy. I used the stock ignition switch. The R1 top triple just needed to have the ignition switch hole bored out slightly, and I added longer bolts with spacers made from aluminium round stock. After I locktited the bolts I ground the heads to help prevent theft. The cool thing is the steering lock feature still works. Most ignition switches use a standard bolt pattern since the factories usually don't make them, and source them from an outside vendor. Unless you buy a Ducati then like me you are screwed! Damn Italians!!!! The 250 ignition switch has a plastic cover that can be removed and it would probably fit as is, but the plastic cover makes the switch look better. If you don't have access to a mill or lathe you could use and dremel to open the hole.
Old April 16th, 2012, 05:24 PM   #15
gt_turbo
gt_turbo's Avatar
I have the opposite problem, the 250r ignition is about a quarter inch too small than the 636 triple. I'll have to find some thing to fill the gap. Rubber gromet maybe.
How do you try to retain the stock 250r geometry with the fork conversion? Is it like measuring the fork length from axle to top of the triple tree and trying to keep that distance? Unfortunately I did not measure anything before i dis-assembled.
Old April 16th, 2012, 07:43 PM   #16
duckracer
duckracer's Avatar
The geometry will be way different. You are going to have a lot less fork offset with the 636 front end. This will give you more trail and make the bike hold a line really well. I use rake and trail as well as swingarm angle to set my race bikes up. But you can plan on having around 10 to 15mm of fork above the top triple clamp. This is because you have less fork offsett and the forks will be standing up more straight than stock. Just start at around 10mm and make sure you have front wheel clearence, then raise of lower the forks untill you get the turn in where you like it and gives you good feedback.
Steering stem bearing justdrew 2008 - 2012 Ninja 250R Tech Talk 3 February 5th, 2015 07:57 AM
RAM on Steering Stem? headshrink 2008 - 2012 Ninja 250R Farkles 15 May 30th, 2014 06:28 PM
Inverted fork conversion old3 2013 - 2017 Ninja 300 Tech Talk 69 February 15th, 2014 07:41 PM
Upside down fork conversion from 636 bolt on joes280 Motorcycle-related 46 April 11th, 2012 05:58 PM
steering stem nut snowfish 2008 - 2012 Ninja 250R Tech Talk 2 April 14th, 2010 07:12 AM
