Old February 14th, 2015, 08:57 PM   #1
smp
Motorcycle(s): 2010 Ninja 250
Tricky Ignition Problem
My 2010 Ninja started idling like crap, and lost a lot of power.
Turns out the left cylinder has a very weak spark, but i cant figure out why.
i have tried the following:
-Checked plug Gap
-Swapped plugs
-Checked coil primary and secondary impedance.
-Swapped L-R Coils
-Checked for Battery voltage at coil
-Swapped IC box from another running Ninja
-Checked impedance of wiring from IC to coils (only 1ohm)
No matter what I did, the left cylinder spark was weak, or not sparking at all.
The only clue I have is the voltage being applied to the coil by the IC was much lower on the left vs. right. I don't have a peak voltage tool, but the averaged voltage read by my fluke was 10v on the right, vs 1volt on the left.
Another interesting twist is my tach stopped working about 2 months ago.
any ideas?
smp is offline   Reply With Quote
Old February 14th, 2015, 09:08 PM   #2
Welcome Seth, the problem is obviously is V-Day. I call sabotage. lol
Old February 14th, 2015, 09:22 PM   #3
Originally Posted by smp View Post
any ideas?
Welcome !!!
That 1 volt reaching the coil is not normal; the problem seems to be in the CDI.
Old February 14th, 2015, 11:19 PM   #4
smp
thanks motofool,
the 1V reading isnt real, its just how the voltmeter is averaging out the very fast pulses from the IC, the IC should be sending a pulse of 250V, but i don't have a way to measure the actual peak voltage. Anyways i tried swapping out the IC with no improvement.
Old February 15th, 2015, 06:26 AM   #5
thanks motofool,
Then, coiild the problem be in the high voltage cable or plug connector?
Old March 16th, 2015, 03:07 PM   #6
RcTechnologies
Motorcycle(s): '12 EX250JC
There may be another arc somewhere post coil, possible solution replace plug wire. This happens when cages get high miles. In fact, the peak voltage going to the plug is seriously high in energy and can generate a spark that leaps to one object (thereby electrically charging it), and by "corona effect" leap to another object where it can find a grounding path capable of handling that amount of energy.
RcTechnologies is offline   Reply With Quote
Ignition Problem - Multimeter and New Battery garman 1986 - 2007 Ninja 250R Tech Talk 6 June 27th, 2014 08:36 PM
ignition removal problem blegerton Ninjettes At Speed 27 January 28th, 2014 07:04 PM
Are Ignition Boxes a Common Problem bikertrash2001 1986 - 2007 Ninja 250R Tech Talk 1 June 5th, 2011 06:02 PM
problem with ignition? onizthegnome 2008 - 2012 Ninja 250R Tech Talk 8 May 5th, 2011 06:10 PM
Ignition problem nilo 2008 - 2012 Ninja 250R Tech Talk 8 January 9th, 2011 04:23 PM
