Old July 31st, 2010, 03:49 AM   #41
adouglas
adouglas's Avatar
Motorcycle(s): Aprilia RS660
Spooph, that's excellent!
The different angles and editing really make it crystal clear.
What clip-ons are those? Never seen or heard of any like that.
Old July 31st, 2010, 08:49 AM   #42
JeffM
Mr. 988
JeffM's Avatar
Motorcycle(s): One
Home made clipons? Nice video spooph! The view at 2:18 is great as it shows both hands working.
JeffM is offline   Reply With Quote
Old July 31st, 2010, 11:19 AM   #43
spooph
spooph's Avatar
Motorcycle(s): '08 Ninja 250R
MOTM - Oct '15
Alex, thanks for the embed info!
THanks for the compliments folks!
I designed those clip-ons and had them machined... My machinist bailed on me for v2. These still rub a bit, and are just a tid bit too low and forward... I have the re-design, I just have to find a machinist willing to work with me....
Oh yea, and since I'm cheap, I just cut my levers to shorties. I'd love a set of Pazzos, but c'est la vie ya know!
Old August 10th, 2010, 09:30 AM   #44
Talonne
Talonne's Avatar
Motorcycle(s): '09 Metallic Diablo Black
Originally Posted by spooph View Post
I'm no Keith Code, nor is this video instructional, but rather simply illustrational. I said I would make it, so I have. I hope it helps. This was made on my commute to work, and some riding in-town.
Thanks for the video!
I don't think I can physically do what you do on downshifting without jerking the throttle around too suddenly or accidentally grabbing the brakes too hard. Looks like I'll have to avoid this technique until I spend $200 on adjustable levers...
Talonne is offline   Reply With Quote
Old August 10th, 2010, 09:53 AM   #45
Key007
Ride Rain or Shine
Key007's Avatar
Motorcycle(s): '09 Ninja 250
A great way to practice in the meantime, in my opinion, is to just work on the mastering the downshift / clutch / throttle combination - take the brakes out of the equation at first. For example, from 5th gear, at a fairly low RPM (maybe you would've downshifted by now), try to drop all the way down into 2nd gear without allowing the bike to buck underneath you. You should hear it, but you shouldn't feel it:
Nee*Downshift*Neeee*Downshit*NeeeeEEE*Downshift*NEEEEEE
etc . Like was stated in the video / posts, this is kind of hard on the bike, and I don't do it regularly, but sometimes I'll just drop gears super quick and see how smooth of a transition I can make it between 5th-4th-3rd-2nd-1st. Be weary of overriding traction on the rear break if you drop gears at too high of an RPM though!
Edit: & Make sure you have plenty of space in front of you to stop, because your speed will decrease waaay slower then if you were using the brakes at the same time. I used to do it on highway offramps as a means of practicing before I got comfortable using the brakes too
Edit2: Neee = engine noise
The Optimist says the cup is half full
The Pessimist says the cup is half empty
The Engineer says the cup is twice the size it needs to be.
Key007 is offline   Reply With Quote
Old August 10th, 2010, 04:29 PM   #46
spooph
spooph's Avatar
MOTM - Oct '15
Ha! I'm checking out the replies, and look at what the adds popped up:
http://www.rideitmoto.com/
No go on for the 250 though... Bastards...
Old September 27th, 2010, 10:18 PM   #47
heylookitsfranco
heylookitsfranco's Avatar
Motorcycle(s): 2008 Ninja 250r, 2006 Ninja 636
haha @OP... I laughed when i read what you posted because I did exactly what you described on the MSF bike they gave me (kawasaki eliminator), but when I got my ninja, it seemed completely natural to do the index/middle on brake.... I think maybe it's got something to do with the size or position of the lever/handlebar? the eliminator was really uncomfortable hehehe
heylookitsfranco is offline   Reply With Quote
Old September 28th, 2010, 08:22 AM   #48
johnjohn
Motorcycle(s): Honda, Buell, Kawasaki, Suzuki, Yamaha
Jeff has got it! No need to fully compress the lever in either up or down shifting.
johnjohn is offline   Reply With Quote
Old September 28th, 2010, 04:36 PM   #49
Apex
Livin' the Minimoto Life
Apex's Avatar
I actually measured how far I pull the brake lever in on my downshifts. The outermost portion of the lever only moves 3/16" - 1/4". I just barely pull in the clutch and it creates enough slippage to do make the downshift much smoother.
Many like to overdo the motion. Now that is my bike, another bike may need 1/2 or more of the full lever movement. I know how they vary because my old GS you'd have to pull it in 1/3 of the way, and my bike on the MSF would need about 1/2. I can use just my index finger on my up/downshifts and it is totally fine on my ninjette.
Old September 28th, 2010, 07:38 PM   #50
Flashmonkey
Professional belly dancer
Flashmonkey's Avatar
Motorcycle(s): 1992 GSX-R 750
Obviously, the big difference between this vid and Code/MCN's video is that this is actually a 250, driven where it's most likely to be driven - the open road.
For those that don't know, this is also relevant because the 250 twin motor is more unforgiving of a botched rev match as opposed to the I4 motors of the SS bikes. You botch a rev match on an I4 engine and it won't kick you as hard...unless you're redlining the damn thing. This is true for all twin bikes I think. You mess up a rev match on a twin bike and that thing will let you know. Food for thought.
With that said, my rev matching skills have gotten seriously lazy hahaha.
Old September 28th, 2010, 11:30 PM   #51
edbro
Motorcycle(s): 2009 250r
+1 on the 600 SS with I4's, I think everyone one of them comes with a slipper clutch nowadays which makes it even easier.
edbro is offline   Reply With Quote
Old September 29th, 2010, 10:26 AM   #52
Havok
Internet Slut
Havok's Avatar
Motorcycle(s): 04 FZ1, 07 FZ6
I could not hear the audio in the video so I am curious how how you blip the rpms up when rev matching.
The reason I ask is I have found a 1-2 k difference dropping gears so when rev match I pull the clutch about 1/4 way or so bring rpms up 1k shif and let clutch out. I don't rev the engine way high up in rpms. I let my rpms drop to about 5k before I down shift to the next lowest gear if stopping and ratchet down till then, I don't drop into fist until I am pretty much stopped.
For passing If I want to drop to get higher rpms and have pull I clutch, rev up 1.5k rpm and dump the clutch.
You can also just not blip at all and slowly release the clutch letting the gears catch up but you have to have good clutch control as to not let it out to fast, it will work your clutch more. A high rpm throttle blip is a bit antiquated if you ask me, back when most bikes had 4 gears you would have to rev it all the way up but with modern 6 gear boxes the gears are so much closer together 1-2 k rpm should do it just fine.
If you have to turn the throttle a lot to get that 1-2k rpm jump I would have your throttle adjusted as it should not be an exaggerated turn for that little bit of rpm.
Havok is offline   Reply With Quote
Old September 29th, 2010, 10:30 AM   #53
TrueFader
Motorcycle(s): '08 250
smooth is fast, do what's comfortable. there's no right or wrong way. just keep the bike settled
TrueFader is offline   Reply With Quote
Old October 1st, 2010, 09:21 AM   #54
spooph
spooph's Avatar
MOTM - Oct '15
thx Monkey!
Havok, being that we're dealing with ratios, the higher up the revs are, the bigger the difference in RPM's between gears. I'm also running 15/44 gearing, so there's a bit bigger difference between the gears than on a stock bike.... To rev-match, I just listen. Experience has taught me how high to rev to match. For instance, at 40mph to downshift from 6th to 5th, there is no reason to blip, but at that same speed, going from 3rd to 2nd is a big blip, I think 2.5K change on my bike... and going to 1st in 40mph would go past red-line....
and just letting the clutch out slowly between shifts is fine if you drive like a granny, but I prefer the shift to be done and over with ASAP (milliseconds). The more time I spend shifting, the less time I have power to the wheel.... I've just kind of gotten use to it, and it's the way I ride.
I agree with Fader, and whoever else said this, there is no absolute right way to do this. It's more about, if you want to shift as quickly as possible, here is one technique to get it done, reliably and consistently, without causing damage to the bike...
Old October 1st, 2010, 10:40 AM   #55
Havok
Internet Slut
Havok's Avatar
thx Monkey!
Thing is we are talking about comming to a stop. If it was trying to shave a 1/4 second off of your lap time then yes rev matching is a must. Comming to a stop at a red light not so much. I rev match on pretty much all of my down shifts and like you I use the engine sound. More racers are starting to feather the clutch now rather then blip as well. If I am looking to pass/gain speed rev matching is the only way, if I am taking a turn and wantto be higher up in the band then rev matching is the way to go, stoping at a light or stop sign or if traffic is slowing in front of me I feather the clutch all mist like a double clutch in a car.
Easy way if I want to maintain current speed or speed up I rev match. If I am slowing down or coming to a stop I feather the clutch. It's what works for me though and it's what you are comfortable with.
Old October 1st, 2010, 11:12 AM   #56
Blackwidow
for braking I keep my thumb and index finger on the throttle and use my middle finger, ring and pinky on the brake, but for the clutch, I have my thumb on the cylinder with all 4 fingers over the clutch.
sometimes I aim to please, but mostly I shoot to kill
Blackwidow is offline   Reply With Quote
Old October 1st, 2010, 12:59 PM   #57
Flashmonkey
Hehe this is how I do it too....or at least used to. This is the Rossi style grip
These days I just use my middle finger to brake. But I still use my entire hand to clutch.
Old October 1st, 2010, 03:47 PM   #58
00NissanNinja
I hate driving...
00NissanNinja's Avatar
Motorcycle(s): 13 Triumph Street Triple R, 09 Ninja 250r (Sold 4/20/12)
I use the same technique as you spooph for blip-ping the throttle while braking. Thanks to the MSF I use all my fingers to brake(which has become a habit) and then I just use my thumb to twist the throttle. Works pretty good for me.
09 ninja 2fiddy SE Driving slow things fast
00NissanNinja is offline   Reply With Quote
Old October 1st, 2010, 07:59 PM   #59
Havok
Internet Slut
Havok's Avatar
That is how I do it as well but I have big hands so the cradle if my thumb and hand is enough to twist the theottle
Old October 3rd, 2010, 07:07 AM   #60
JeffM
Mr. 988
JeffM's Avatar
Motorcycle(s): One
Another technique that will make braking and blipping easier (aside from lots of practice) is to let the fingers you are braking with slide up and down slightly on the brake lever as you blip and pull on the brake lever. It is subtle and helps keep your braking smooth.
Who'd of thought that so much action is going on while riding? It is a lot to coordinate; braking, blipping, clutching, and shifting. But boy, when you get it right is really does feel cool.
"I'm the one that's got to die when it's time for me to die, so let me live my life, the way I want to" - Jimi Hendrix
Cancer
Downshifting & Throttle Blipping akshay11 Riding Skills 90 May 2nd, 2015 01:20 PM
wtf is he blipping the throttle?! alex.s Riding Skills 9 March 7th, 2013 10:33 AM
Proper Braking Technique Seananniganss Riding Skills 30 May 17th, 2012 10:31 AM
Throttle Blipping at Red light/intersection codestp202 General Motorcycling Discussion 64 April 25th, 2012 01:48 PM
Blipping while braking JeffM Riding Skills 74 October 10th, 2011 01:33 PM
