September 19th, 2013, 11:40 AM | #1 |
Join Date: Sep 2013 Motorcycle(s): 2001 Kawasaki ex250 Posts: 6
Multiple Issues: Starting & Running
Apologize in advance for the lengthy post, Ive got a few issues.....
So I bought an 01 ex250 about a month back with 51xx miles on it and had been running fairly well up until about a week or two ago. I was headed home running about 50-55mph when it started chugging. I pulled of, threw it in neutral and it reved and ran fine. Back into gear--same deal. Limped it to the gas station (it was low, but not out), filled up and spent 5 minutes trying to start to no success. Loaded it in the truck to get it home. A few days later tried to start, same thing, turn over all day but wouldnt run. That afternoon i tried jumping the starter relay...nothing. Pulled the starter off and it was toast!! Probably self inflicted from the cranking. Replaced it, bike fired right up. Took it out for a spin and after it warmed up i lost ~40% of my power, just felt bogged down. It revs fine in neutral but no power in gear. I had checked the plugs when i replaced the starter and they looked fine. Over the next few day i had trouble starting again, sometimes it would hit on the first try, other times not at all, come back in an hour or so and it would start right up!?!?!? So this is where i am now, its a hit or miss start, and after its warm it loses power... Suggestions/comments/smacks to the head, they"re all welcome!! |
September 19th, 2013, 11:48 AM | #2 |
Welcome Bud! Anything in the aribox and air filter in good working order? Do you know when the last time the carb was cleaned?
September 19th, 2013, 11:59 AM | #3 |
Thanks, airbox is good, I did have to reconnect the 2 breather hoses to the back side of the carb (i saw that when i bought it), the air filter isnt the most beautiful thing but you can see daylight when you look through it and no obstructions in it. According to the guy i bought it from, the carbs were cleaned just a few hundred miles ago (<200).....
September 19th, 2013, 12:11 PM | #4 |
sail away
Join Date: Jul 2012 Motorcycle(s): gixxer (sold), ninjette (upgrade!) Posts: 964
check for adequate flow of fuel through petcock. Also check 2 inline fuel filters between gas tank and carburetor for obstructions. Thirdly, drain carburetor float bowls of possible water buildup.
Unregistered found this post helpful. Track Day Preparation Checklist 1. Financial 2. Mental 3. Physical 4. Gear / Bike |
September 19th, 2013, 12:33 PM | #5 |
Welcome to our site, Bud !!!
Drain the carbs bowls looking for water in those. If water was found there, drain the fuel tank with the petcock in reserve position. If no water is found, then check that the fuel is flowing freely into the carbs: sometimes the filters are clogged (in-line and inside the tank), some times is the vent of the tanks' cap. If the petcock still needs vacuum to work, check that the vacuum hoses are leak-free and properly connected.
September 19th, 2013, 01:01 PM | #6 |
@ motofol and lychee, im heading out to check those things, thanks, just to ad to the list it now has no power all the time, to the point of bogging down until it quits, will not restart...
September 19th, 2013, 01:47 PM | #7 |
Join Date: Aug 2012 Motorcycle(s): Ninja 250R '07 Posts: 81
When was the last time the valves were adjusted?
September 19th, 2013, 03:27 PM | #8 |
So far... inline filter(inside hose going from petcock to carbs) was virtually crushed, blowing the line, i got brown dust...
went to the carb bowl drains, got nothing, took a piece of wire and poked into the screw inlet and got very nasty gas with small trash from both carbs... Just to see, i put it all back together, cranked and ran with ease. So i guessing the best best is pull the carbs off and do some serious cleaning and soaking?? As to the valves, i have no idea if and when theyve been adjusted, honestly if ever. Its only got 51xx miles, however I really dont know what the suggested milage points are to check and adjust valves? Anybody know that? |
September 19th, 2013, 08:14 PM | #9 |
If you have a complex for that sort of thing then yea. Otherwise, do not fix what is not broken.
September 19th, 2013, 09:36 PM | #10 | |
Here is the schedule of service for your machine: http://faq.ninja250.org/wiki/Service_Schedule
September 20th, 2013, 10:07 AM | #11 |
Thanks guys for the input, I think im going to run a good bit of gas through the whole fuel system and see if i can hold off on pulling the carbs. Motofool, preciate the maintenance schedule. Also, i pulled out the inline filter (in the hose) and im thinking of going with a 'normal' inline filter, just splicing the hose and adding one....Any recommendations/hesitations for good gravity fed filter??
September 20th, 2013, 12:28 PM | #12 |
sail away
A spliced inline filter is a very good idea. Choose something clear so you can see into it.
http://faq.ninja250.org/wiki/How_do_...fuel_filter%3F
September 22nd, 2013, 10:11 AM | #13 |
Ok ill check into that, thanks
Starting Issues | FvnnyL3tt3r1ng | 1986 - 2007 Ninja 250R Tech Talk | 12 | January 22nd, 2015 10:33 AM |
Issues with starting | arieon69 | 1986 - 2007 Ninja 250R Tech Talk | 15 | September 7th, 2012 06:38 PM |
Issues starting up | Maielstrom | General Motorcycling Discussion | 2 | August 8th, 2012 08:35 AM |
Starting issues | Gorilla25 | 2008 - 2012 Ninja 250R Tech Talk | 14 | September 22nd, 2011 09:20 PM |
Starting Issues | mikkel | General Motorcycling Discussion | 4 | July 30th, 2009 01:40 PM |
