Old February 3rd, 2014, 06:03 AM   #1
ally99
Ninja chick
ally99's Avatar
Motorcycle(s): '13 Ninja 300
MOTM - Dec '13, Feb '15
Choppy throttle in 1st and 2nd gear
Forgive me if there's already been a post on this topic, but a quick search didn't reveal one.
Does anyone else have issues with a choppy throttle in 1st and 2nd gear? It seems like no matter how smooth I am on the throttle, those lower gears on the 300 are jerkier than other bikes I've had. Could this be an ECU issue? Or a throttle cable adjustment? Fuel? Just wondering if this is a random isolated issue or if other 300s have it as well. Thanks!
Postwhores are COOL! ~Allyson
Old February 3rd, 2014, 06:05 AM   #2
xaple
xaple's Avatar
If it means anything, my 250 definitely suffers this problem. And I had a new ECU installed a few months back.
xaple is offline   Reply With Quote
Old February 3rd, 2014, 08:23 AM   #3
@Jiggles has complained about it on his new 300. On mine there is a slight jump when going from completely no throttle to that first bit of any throttle, but it's not that noticeable unless I'm really looking for it.
Old February 3rd, 2014, 08:57 AM   #4
Jiggles
Jigglin' your Jiglets
Jiggles's Avatar
MOTM - Apr '13
It's actually in every gear. It's like the throttle jumps from 0 to 5% throttle. You can finely control the rest of the throttle range but that chunk is missing. It can make coasting pretty annoying and so I find myself rolling with the clutch in like I often did on my ninja 650.
I prefer to take my 250 in the twisties where I like to coast/maintain speed through turns
AFM #676
Supersports are for n00bs
Old February 3rd, 2014, 09:08 AM   #5
Sirref
Private Joker
Sirref's Avatar
MOTM - Mar '14
I've only ever noticed a problem with initial roll on, in every gear at all times. The ecu recall didn't change it at all. I tightened the throttle cable but that didn't change anything for me so I've given up on a solution and accepted it as part of how the bike rides. If someone knows how to solve the issue that would be great but riding around it isn't that big of a deal to me.
Old February 3rd, 2014, 09:16 AM   #6
old3
Ally, stock gearing? Slap a 15t on the front and enjoy. Smoother everywhere, less compression braking, not that it has much anyway.
For some reason this bike has the final drive gearing of a enduro race bike.
I've chased gearing up to 15/39 which proved to be my upper limit for normal riding. I might consider it if I ever need to slab across the country as it was mellow at speed. Any combo above stock and below that should be in the ball park of what regular street bikes are normally geared like.
I GPSed the 15t too, it corrects the speedo spot on up to 80 MPH. Within 1 MPH anyway. You will see the same speeds you see with stock gearing but you will now actually be going those speeds. Stock gearing gives you a false, higher speedo reading.
old3 is offline   Reply With Quote
Old February 3rd, 2014, 09:44 AM   #7
can you reprogram the stock ecu? does power commander make a kit for the 300?
Old February 3rd, 2014, 09:58 AM   #8
old3
Yes on both, along with Area P tunes and tuners.
Old February 3rd, 2014, 10:59 AM   #9
so i'm wondering if its just a problem with the throttle position sensor... cables might be tight to the throttle bodies but maybe the TPS on the throttle bodies isn't quite aligned right or is loose?
Old February 3rd, 2014, 05:38 PM   #10
ally99
Ninja chick
ally99's Avatar
I've heard others say a 15t is the way to go too.
It's definitely something I can deal with, it just makes slow speed stuff look at feel a bit ugly sometimes.
Thank you all for chiming in!
Old February 3rd, 2014, 07:07 PM   #11
old3
Try it, $14 and I', pretty sure you will fall in love with it like that. Why this bike has that gearing stock makes no sense to me at all. It will smooth right out.
If you want to try it for free, start in second gear like I was regularly doing, even with a passenger. I'm 200 lbs. too. Second was my gear of choice with stock gearing. The bike pulls it easily.
Old February 4th, 2014, 08:40 PM   #12
jeffb502
jeffb502's Avatar
Motorcycle(s): 2013 White Ninja 300, 2010 Red Ninja 250r (Sold)
I've noticed myself jerking around a bit at low speeds in 1st gear, looking like a n00b (I guess I still am a n00b but I'd rather not look like one when I can avoid it lol) ...glad to hear it's not just me.
I've been using 2nd gear for most of my slow speed maneuvering to minimize the jerkiness; I'll have to try starting from a stop in 2nd gear and see how that works for me (thanks for the suggestion old3).
I'll have to try that 15t front also. I noticed cruising at 80-85 (indicated) in L.A. it seemed to be revving a bit high...I actually checked a couple times just to make sure I was already in 6th gear heh.
jeffb502 is offline   Reply With Quote
Old February 5th, 2014, 07:26 AM   #13
Happens to everyone and don't let anyone tell you any different. lol
Sometimes in my helmet, I'm like...
Old February 10th, 2014, 06:15 PM   #14
Xtina
Xtina's Avatar
Motorcycle(s): 2013 Ninja 300, 2007 Gsxr 600, R6-sold :(
Also make sure there is no freeplay in the throttle cables as this can make it fairly jerky too. Adjustments can be made by tightening the screws where the cables meet the throttle body. Just make sure that the throttle still snaps back.
Xtina is offline   Reply With Quote
2nd trip to TWS didn't go as well as the 1st sharky nrk Ninjettes At Speed 23 September 11th, 2014 06:43 AM
Occasionally shifts to neutral from 1st to 2nd woofer987 2008 - 2012 Ninja 250R Tech Talk 8 May 6th, 2013 08:52 AM
Going from 1st to 2nd I hit neutral?? TwoWheelNinja General Motorcycling Discussion 6 October 10th, 2012 07:49 PM
Ninja 250, 1st (2nd?) Impression Jiggles General Motorcycling Discussion 28 July 24th, 2012 09:32 PM
1st to 2nd clutch slippage atomicrm General Motorcycling Discussion 7 March 6th, 2012 01:55 PM
