November 12th, 2009, 11:10 AM | #1 |
certified ninja 250r FAN
Join Date: Oct 2009 Motorcycle(s): Honda XL 125 and Kawasaki Ninja 250r '09 Posts: 59
Redline
Hi guys just thought i'd let you know that i took my baby to redline tonight
Is it normal for my ninjette to redline at 13 500 RPM ? and man does she scream wow ...
'09 Green 250R -Pro Grip Tank Pad -Green Rim Tape |
November 12th, 2009, 11:13 AM | #2 |
Live Life
Join Date: Nov 2008 Motorcycle(s): 2009 Green SE Ninja 250 Posts: A lot.
What were you expecting?
- ATGATT - Scorpion EX700 Hi-Vis Helmet, First Gear MeshTek 3.0 Jacket, TourMaster Transition 2 Jacket and Flex Pants, Sidi Doha boots |
November 12th, 2009, 12:59 PM | #3 |
The Sportisi Master
Join Date: May 2009 Motorcycle(s): 2008 Ninja 250 Posts: A lot.
on a stock bike 13500 is norm. mine goes up to 14500 cause I'm special
Sportisimoto USA is born. |
November 12th, 2009, 02:15 PM | #4 |
November 12th, 2009, 02:41 PM | #5 |
Join Date: Oct 2009 Motorcycle(s): Black 09 Ninja 250 Posts: 20
Has anyone kicked the rev limiter in? I've taken mine up to 14 grand and the rev limiter never kicked in. I also realize the tach is innacurate.
November 12th, 2009, 02:49 PM | #6 |
The Sportisi Master
I can't kick mine in. The BRT Tis lets me set it where I wish. I have it set at 14500 which is what the valvetrain is rated to. I've hit 14300 but no higher.
November 12th, 2009, 03:01 PM | #7 |
Live Life
I was thinking more of a purr .
I had the day off yesterday and with the beautiful weather took the bike out into the country for a couple of hours. No twisty's but plenty of chances to wind it out to ~13 each time I left a stop sign. She does love to sing and that close ratio transmission makes it so smooth at the high end. Got some rain coming but more riding weather is supposed to come before the snow really flies.
November 12th, 2009, 03:17 PM | #8 |
All the time. It feels pretty soft when it hits the limiter. The engine isn't pulling as hard at those high revs, and when it cuts ignition there isn't such a huge hit as you bounce off the limiter as there is on some different type of bikes (Ducati's are the opposite example). It will just stay at the limiter without moving any higher.
November 12th, 2009, 04:57 PM | #9 |
I have hit the rev limit and like Alex said it is very soft. You reach the rev, the engine stops pulling and it just kinda floats at that speed and rpm.
November 12th, 2009, 07:04 PM | #10 |
I run my bike at 7,500+. I try to keep the RPM in that range. The bike seems to like that "Sweet Spot". Just because we have six speeds does not mean we have to get there all the time. I kick in six at 65MPH+. In town, I rarely get past third gear. I have heard people on this forum complain about throttle response. The answer is--Don`t lug the machine down. This bike is designed to run at high RPM. If you can`t do that maybe a Harley is in your future.
November 12th, 2009, 07:28 PM | #11 | |
Live Life
November 12th, 2009, 10:59 PM | #12 |
Join Date: Dec 2008 Motorcycle(s): '08 Kawasaki EX250 "Yoshi", '99 Kawasaki Concours "Grace", '06 Concours "Belle", '06 Yamaha YZF600R "Slick" Posts: A lot.
< ATGATT > Sweat you can wipe off, Road rash you can't. HEY!! Unregistered!! Does your bike have a name? |
November 12th, 2009, 11:12 PM | #13 |
I've tagged the rev limiter a few times in 1st and 2nd and it 'bounced off'. Really spooked me the first time, still seems a bit strange so I try not to do that anymore
November 13th, 2009, 10:49 AM | #14 |
I'm confused. People ITT are talking like the "rev limiter" = "redline" and then later talking about it like I understood it to be (redline is where your needle enters the red zone on the tach, not where your rev limiter prevents going any higher).
November 13th, 2009, 11:33 AM | #15 |
I think it's just a terminology thing. Redline is the fastest engine speed that a manufacturer believes that the engine can perform safely and fulfill all of its reliability and longetivity expectations. More detail from wikipedia right here. In years past, only the operator was choosing to keep the machine below the redline, as going over that could have some pretty significant and pretty immediate consequences.
Just about all modern engines have rev limiter functions that try and prevent an engine from turning faster than is safe, and they do that by either cutting spark, cutting fuel, or both. These rev limiters are set in the ECU, and are typically placed right at what the manufacturer would describe as the redline. In some cases a manufacturer might set the rev limiter a few hundred RPM below the nominal redline, as a bit of insurance just to make doubly sure that engine speeds are kept in check. If the motor is already tailing off and not making much power at those extreme revs, there's little benefit in allowing it to rev to the theoretical redline anyway. What the rider sees on the tach as the redline before that red zone may or may not be in sync with the actual redline as measured off of the ECU. Just like our speedometers, tachs are notoriously optimistic, and typically read high, especially in the higher rev ranges.
March 3rd, 2010, 02:11 PM | #16 | |
Fastly Slow!!!
Join Date: Feb 2010 Motorcycle(s): 2007 Kawasaki Ninja EX250, 1980 Honda XL125 Posts: 467
Have never hit the limiter myself. Been once or twice I thought I should have, but never did. |
March 4th, 2010, 01:13 PM | #17 |
Join Date: Dec 2008 Motorcycle(s): 2008 Ebony Ninja 250R Posts: 137
I'll normally shift around 12k, when I do stretch it out. Around town, I'll keep it down to 9k or so. I've never hit the limiter either.
Posted via Mobile Device |
March 4th, 2010, 11:19 PM | #18 |
Join Date: May 2009 Motorcycle(s): 2009 Ninja 250 (sold) Posts: 755
On a fast take off I usually shift at 11k after that the power just levels off very noticeably. I usually have the engine running between 6 to 9k. Seems like the sweet spot. 7 to 8k seems to be when the fairings like to buzz. The engine likes to cruse at that rpm range, but I don't because even with ear plugs that fairing buzz really starts to wear on me after a few miles.
The Ninjette is not a disposable bike. You are not ever supposed to get rid of it. It is like a [friendly] herpes virus.... once you got it, you get keep it forever. Originally posted by-Headshrink |
March 5th, 2010, 08:17 AM | #19 |
Join Date: May 2009 Motorcycle(s): '98 EX250, '02 EX250, '08 250r, '03 SV650, '98 GSXR750 '03 Hayabusa, '87 YSR50, '84 ZX900, +MORE Posts: A lot.
I try not to let the revs fall below 10,000rpm. I usually shift at about 13,000rpm but I often spin it well past 14,000rpm to keep from having to make an extra upshift before a turn.
CraigHarris.org Pacific Track Time CraigsWeb See you at 2014 MotoGP Laguna Seca! We'll be camping on Fox Hill. AFM #278 |
March 5th, 2010, 09:46 AM | #20 |
Wartown, USA
Join Date: Nov 2009 Motorcycle(s): 2009 Ninja 250R SE, 2007 Ninja 650R, and assorted other bikes Posts: A lot.
Here is pretty much how my shift pattern goes. Bear in mind this is on the new gen 09SE.
If I want to really twist that sucker... From a stop...1st gear to 10k, 2nd gear to 13k, 3rd gear to 13k....by that time Im low level flying. If I just want to get in front of the pack and quick... From a stop...a real quick 1st to 9k, click it to 2nd and hammer it. That usually sticks me out front of most of the cagers. Normal cruising type start.... From a stop...1st gear to 9k, 2nd gear to 9k, etc. On a highway or something, I get up to speed in whatever method, then I gear it to whatever is needed to keep it in the 7K range or so. The pull from 8K+ is good, so if I need the power, its on tap in that gear. I really dont see any need to go past 13K. Beyond 12K the powerband is dropping off, and all your doing is just converting a full tank to an empty one, and making the bike work hard for very little results. Its funny getting on another motorcycle, because you are used to running high revs, and you gotta be careful or you'll blow up the other bike without even thinking about it. |
March 8th, 2010, 05:02 AM | #21 |
Join Date: Jun 2009 Motorcycle(s): Ninja 250R Fuel Injected Model 2009 Posts: 357
Max Torque 22 N·m {2.24 kgf·m} / 8,200 rpm
Max Power 24 kW {33 PS} / 11,000 rpm So your optimum power-band is 8200 rpm to 11,000 rpm. Red line on mine is 12,500 rpm, so between 11,000 and 12,500 you are not producing any more power just making more noise. I've no idea where the limiter is probably around 13,500 rpm. This is useful as when you lean over you should be on the gas just to maintain speed as the tire is thinner when over on the side so you actually need about 500rpm more just to maintain speed the same speed from when you where upright. Also you have some scope to continue your turn and accelerate without needing to change gear (and use that power to keep 60% of the weight on the rear wheel and help the bike turn). In normal riding I use about 7,000 to 12,000, only lower than 7,000 for slow moving traffic. It actually pulls ok for slow traffic from 3,000rpm in 2nd bellow that its a bit lumpy. Even though mine is fuel injected the carb bikes are 99% similar. Mine might be a bit smoother at low rpm as the FI bikes have a dual throttle system where the rider controls 1 throttle body and the ECU adjusts the input with the other throttle body for each cyclinder.
My vlogs on Youtube are here |
Redline Water wetter | almost40 | Ninjettes At Speed | 29 | March 27th, 2017 11:37 AM |
cl-17 high vis redline | jschorr | Motorcycle Gear | 7 | May 30th, 2014 07:58 AM |
Bike won't redline in 6th... | LoneRonin | 2008 - 2012 Ninja 250R Tech Talk | 17 | November 22nd, 2012 01:43 PM |
Redline | Keenan84 | General Motorcycling Discussion | 3 | March 30th, 2010 07:03 AM |
RedLine Fuel System Cleaner... | cnichols79us | 1986 - 2007 Ninja 250R Tech Talk | 5 | March 3rd, 2010 01:32 PM |
