August 22nd, 2013, 07:08 AM | #1 |
question drop in filter or shimming
Hi.
I have a lot search and read in this forum and i know most people done with his bike just drop in filter and shimming needles. So I have a question before i move to next step for my bike (bike all stock jetting, just pu5 slip on and all are find). I want to improve my bike but without jetkit. So here is a couple question : 1. If i shim needles with washer, snorkel must remove? 2. If i just put drop in filter without shim would be ok, I mean not lean midrange? Thanks |
August 22nd, 2013, 07:14 AM | #2 |
First Max, every bike's jetting needs can be slightly different.
Second, these bikes come a bit on the lean side from kawi. So... You can shim and still keep the snorkel if that is what is best for your bike. No harm there. The drop in is a bit more tricky, you could be a tad lean, especially if you get a Hi Flo. You throttle, buttocks and spark plugs will tell the tale. Since shims are super simple to add/subtract, it's no big deal to try either way.
shimming question | mikedabike64 | 2008 - 2012 Ninja 250R Tech Talk | 4 | November 16th, 2013 12:22 PM |
08-12 Ninja 250 K&N drop in filter | drunyon | Motorcycle-related | 4 | December 17th, 2012 06:35 PM |
K&N drop in air filter | Zyconic17 | Motorcycle-related | 1 | October 2nd, 2012 12:21 PM |
k&n drop in filter question | greatwhiteninja | 2008 - 2012 Ninja 250R Tech Talk | 14 | June 8th, 2011 11:52 PM |
K&N Drop In Filter Available for 08/09 Bikes | kkim | 2008 - 2012 Ninja 250R Tech Talk | 34 | March 21st, 2009 11:16 AM |
