December 27th, 2014, 04:09 PM | #1 |
Join Date: Apr 2013 Motorcycle(s): 2005 Ninja 250, 2006 SV650N Posts: 642
Friends Rebel 250 making strange rattling noise.
This sound bad to you guys. It just came back from the shop which it just got a basic tune up and now it's making strange noises. 2007 Rebel 250 with close to 40k on the engine. Having a hard time trying to pin down where it's coming from. In person it sounds like something rattling close to the engine but in the video it sounds a bit more like the engine itself.
December 27th, 2014, 04:12 PM | #3 |
Whoops I'll fix that. How about now?
December 27th, 2014, 04:55 PM | #4 |
Hmmm, not a definitive sound to my ear from the vid.
Step one, check oil level and fill/drain as needed! Step two, lube chain Tricks to isolate sounds; When does the sound change? Clutch in Clutch out In neutral In gear In motion While stopped At certain rpm On the throttle Off the throttle With the brakes on With the brakes off
December 27th, 2014, 05:54 PM | #5 |
It almost sounds like a bolt rattling around inside the engine.
December 28th, 2014, 11:32 AM | #6 |
Ok, hmmmm Is it just me or do you have little to no rattle at idle, ie Only when the throttle comes on?
Check these things too; Battery cover vibration against the frame Engine mount bolts Also, since it seems to be loudest on the right side near the can... I would also vote to check the exhaust for a broken inner layer. Hillbilly Exhaust Test - lol Get a piece of heavy rubber (I used a bicycle inner tube) and wrap it around your exhaust can (right side) and then put a large hose clamp on it. Snug it pretty tight but not crazy tight. Start the bike up and give it some throttle, the sound should be drastically lower, if it is.... time for a new exhaust. Oh! don't get it too hot or the rubber may melt.
December 28th, 2014, 11:38 AM | #7 |
Oh! for everyone else...
So you got you some chrome pipes that never turn blue aye? Why? Because they have inner layers that keep the high heat away from the chrome outer. If you get rattles, it very well may be from those inner layers vibrating against each other.
December 28th, 2014, 11:42 AM | #8 |
Join Date: Feb 2014 Motorcycle(s): Rebel 250s, Ninja 250s VN750s (currently nine total) Posts: 465
I tend to agree with Chris; sounds like one of the exhaust baffles or possibly the rear bracket hanger is loose. I'd also be concerned about what I didn't hear, which is noisy valves. When the valves on the Rebel are properly adjusted, it sounds a lot like a sewing machine. When the valves get too tight, it's going to cause damage. Honda recommends checking the valve clearance every 4,000 miles.
Tell your friend he's welcome at hondarebelforum.com Lots of knowledgeable folks and helpful information there.
Profanity is the weapon of the witless. |
Rattling noise from the engine.. | paterick4o8 | 2008 - 2012 Ninja 250R Tech Talk | 15 | February 9th, 2021 08:16 PM |
Rattling Noise | hieuster | 2008 - 2012 Ninja 250R Tech Talk | 12 | July 3rd, 2013 11:13 PM |
Rattling Noise from 8-9k RPM | 250fan | 2008 - 2012 Ninja 250R Tech Talk | 20 | August 1st, 2009 10:52 PM |
knocking or rattling noise | tinng321 | 2008 - 2012 Ninja 250R Tech Talk | 12 | May 31st, 2009 09:51 AM |
So I'm hearing a rattling noise from my engine | ARc | 1986 - 2007 Ninja 250R Tech Talk | 25 | May 11th, 2009 06:06 PM |
