Old April 17th, 2014, 09:25 AM   #1
scorch
scorch's Avatar
Motorcycle(s): 250
Changing cam chain
Anyone change the cam chain on their bikes yet? Mine needs it since my mnanual cam chain tensioner is almost all the way in.
I was wondering if i could remove the chain by using a chain breaker, and then using a small master link to fit it together?
scorch is offline   Reply With Quote
Old April 17th, 2014, 09:35 AM   #2
i wouldn't trust it. there's a video on youtube of a guy welding it back together also. again i wouldn't trust it. it's not terribly hard to replace. pull the engine, split the bottom half case off, slide the new chain in. put it back together
Old April 17th, 2014, 09:35 AM   #3
rojoracing53
Fast-Guy wannabe
rojoracing53's Avatar
MOTM - Jan '13
Sorry I have no input to your question but was curious about how many miles on your bike?
Old April 17th, 2014, 09:37 AM   #4
scorch
scorch's Avatar
Motorcycle(s): 250
Why wouldnt you trust it?
Pulling the engine sure sounds like an awful lot of trouble. I was thinking i can replace it with a cam chain and use a master link or even rivet it without having to pull the engine and split the bottom half.
The bike in question has 81k miles
Old April 17th, 2014, 10:14 AM   #5
81k miles!
Old April 17th, 2014, 10:15 AM   #6
rojoracing53
Fast-Guy wannabe
MOTM - Jan '13
Holy **** that's a lot of miles. I'm at 40k miles which is still more then most new-gens and was worried I may have overlooked mine chains wear level. Anything else failing on the bike motor wise so far? I plan to continue logging in 20k a year for many years to come and was thinking of picking up a cheap spare motor so when mine dies, that way I can rebuild it at my leisure and keep riding. I'm just not sure how long this little thing with last. If I can get at least 80k before a complete rebuild and I'd be pretty happy.
Old April 17th, 2014, 10:20 AM   #7
mah f'in 81k
Old April 17th, 2014, 10:58 AM   #8
scorch
scorch's Avatar
Motorcycle(s): 250
so im told that the chain cannot be broken by racerx. Since he is an expert i might have to do this the old way.. now the question is, how do i even replace the cam chain? Do i have to remove the engine completly?
Old April 17th, 2014, 11:11 AM   #9
removing the engine isn't hard. up on the rear stand, bodywork off, take the chain off, gas tank off, undo the two carb clamps, remove the 3 wire connectors and undo the ground bolt, take off the clutch cable and drain the fluids and undo the radiator hoses. take out the plug wires and put a jack under the engine. undo the front 4 bolts first, then the back top bolt, let the engine rotate down then take out the last bolt and move the engine to the work bench.
splitting it isn't terrible, there's about 20 or so case bolts. some are hard to find. the one inside the oil filter hole took me awhile to find. remember there are bolts going in on both top and bottom and all around the sides. remove the two side panels first. you'll want a clutch hub tool and an impact wrench to remove the clutch hub so you can get behind it to remove the oil line running between the two case halves. at 81k i would completely disassemble and inspect everything since you're already there. just don't mix anything up. and take lots of photos to post here.
Old April 17th, 2014, 11:36 AM   #10
scorch
scorch's Avatar
Motorcycle(s): 250
lol, thanks ALex. I am going to look into buying a new engine instead. way too much work and time.
Old April 17th, 2014, 11:57 AM   #11
rojoracing53
Fast-Guy wannabe
MOTM - Jan '13
this guy gets me
Old April 17th, 2014, 12:01 PM   #12
i'll give you $100 for your old engine
Old April 21st, 2014, 06:17 PM   #13
mgentz
Board Member
4 hours in tear down time. Stock rebuild would be 6 hours back to running.
no too much time!
Old April 22nd, 2014, 05:42 AM   #14
scorch
scorch's Avatar
Motorcycle(s): 250
no too much time!
thats assumning i know what i am doing . but 6 hours isnt much. but do you guys recommend me changing the cam chain or buying a new engine?
Old April 22nd, 2014, 06:13 AM   #15
Racer x
Racer x's Avatar
MOTM - Sep '18, Feb '16
How many miles on the engine? Is it the original bottom end. I know I replaced the top.
Worlds fastest 250 ninja
Old April 22nd, 2014, 06:16 AM   #16
mgentz
Board Member
Also, I have a cam chain with 10 hours of run time on it that I will sell for cheap. the stock ones are expensive....but I always go overkill....
Old April 28th, 2014, 06:48 AM   #17
scorch
scorch's Avatar
Motorcycle(s): 250
how much for it?
Old April 28th, 2014, 08:46 AM   #18
mgentz
Board Member
new is $65. I would sell for $25 shipped.
Cam Chain Issues, need advice Drg805 1986 - 2007 Ninja 250R Tech Talk 7 May 21st, 2014 07:54 PM
cam chain tensioner kittyslasher 2008 - 2012 Ninja 250R Tech Talk 2 June 16th, 2013 09:17 AM
Do cam chain tensioners ever need to be replaced? Monkeytofu 1986 - 2007 Ninja 250R Tech Talk 6 July 17th, 2012 05:17 PM
stretched cam chain alex.s 2008 - 2012 Ninja 250R Tech Talk 22 June 28th, 2012 06:52 PM
Cam Chain Tensioner Replacement pongoo4u 2008 - 2012 Ninja 250R Tech Talk 4 July 23rd, 2010 05:11 AM
