Go Back   ninjette.org > 2013 - 2017 Ninja 300 > 2013 - 2017 Ninja 300 General Discussion
Old October 2nd, 2014, 05:48 PM   #1
Scott1620
Scott1620's Avatar
Motorcycle(s): 2008 Ninja 250r(sold), 2007 650R (sold), 2013 Ninja 300
Unhappy 2013 SE knocked over in lot, damage assessment
So my 2013 SE was knocked over in my work parking lot by an inattentive driver.
She got the receptionist to get me and was nice about it but now I have some damage assessment to do before her insurance person looks at it. I was hoping to get some insight into some damage that may not be visible.
First, I do not remember the tire line not lining up with the front fender center as seen in the attached picture. Could her car have knocked something over on the front tire? I was able to ride it home and it felt ok.
Second, my T-rex frame sliders took some of the brunt of the damage so I do not think i need to replace my fairing but it looks like the slider mount flexed into the top of my head leaving a small dent (pictured).
Any thoughts? Should I be concerned about the head?
Scott1620 is offline   Reply With Quote
Old October 2nd, 2014, 06:46 PM   #2
Flying
Motorcycle(s): 2010 Ninja 250
I don't know about the head, but the front fender bracket is likely bent:
It's not the strongest part of the bike.
Old October 2nd, 2014, 06:48 PM   #3
Sirref
Private Joker
Sirref's Avatar
MOTM - Mar '14
wow that frame slider didn't do it's job properly, there shouldn't be a scratch on that fairing
Old October 3rd, 2014, 01:30 AM   #4
JohnnyBravo
Certifiable nontundrum
JohnnyBravo's Avatar
MOTM - Sep '13, Sep '16
That sucks... At least it wasn't a hit n run though
Old October 3rd, 2014, 05:54 AM   #5
LittleRedNinjette
Certified Troublemaker
LittleRedNinjette's Avatar
Looks like the same problem i had with mine. The "no cut" sliders for the 300's are, imo, crap. Its to far of a distance from the mounting point to the fairing hole in most cases.
The insurance should cover the slider but i would recommend upgrading to the Shogun sliders, this is what i did. Still no cut but it has two mounting points and they are very solid.
Hope they take care of it all for you. Nice to her she didn't hit and run.
Raven's Rejuvenation
Old October 3rd, 2014, 06:06 AM   #6
Rustitution
World Class Ninja
Rustitution's Avatar
Motorcycle(s): 2002 Ninja 250, 96 VFR750, 79 Yamaha XS1100 Special
I'm not seeing any mechanical damage in the picture with the head there, but though to tell looks like the fairing and the slider took the brunt of the force
+1 for Shogun sliders
Life is not a journey to the grave with the to arrive safely in one pretty and well preserved piece, but to skid across the line, thoroughly used up, worn out, leaking oil, shouting, GERONIMO!
Rustitution is offline   Reply With Quote
Old October 3rd, 2014, 06:11 AM   #7
Qomomoko
Motorcycle(s): 1995 Ninja 250, 2005 R6, 2002 Ducati Monster S4
Suck.. but .. could not tell, her insurance is covering damages right?
Qomomoko is offline   Reply With Quote
Old October 3rd, 2014, 11:25 AM   #8
Scott1620
Scott1620's Avatar
Thanks for the info, yeah maybe that bracket is bent. I'll add that bracket to the things I expect to get replaced. I put it on a front stand and spun the front wheel to make sure it is not bent and I did not see any wobbling.
Judging from the damage to the left of the front fender and right of the bike, I am guessing she was backing out of the spot next to me and cut the wheel too soon hitting the left side of my front fender and knocking the bike over...
Yeah her insurance will cover it, a guy is coming out today to look at it.
Old October 3rd, 2014, 11:30 AM   #9
LittleRedNinjette
You should have a shop inspect the bike.
Normally the insurance adjuster would came out and inspect it at a shop with a mechanic.
Old October 3rd, 2014, 02:48 PM   #10
snot
sammich maker
snot's Avatar
MOTM - Apr '15
I would have all of it fixed, maybe have a dealer look at it like red said.
Old October 3rd, 2014, 09:10 PM   #11
Rustitution
World Class Ninja
I never had to do a claim on my bike because I dumped it without full coverage because well i bought all of my bikes for sub $2000 but is there possibility of total loss because plastics are expensive to repair and replace?
Old October 4th, 2014, 03:58 AM   #12
LittleRedNinjette
Doesn't look like it too me. when my bike fell in the driveway (kickstand gave or wasn't down rite) they wanted to replace $2500 or so in parts (SE fairings are f-ing expensive) without totaling it. i think they will repair it if its less than X% of the value of the bike. I'm not sure of the number so someone probably can fill in the blank there.
Old October 4th, 2014, 07:31 AM   #13
nickjpass
#squid
nickjpass's Avatar
MOTM - Jul '16
Smhhh
Old October 4th, 2014, 12:03 PM   #14
JohnnyBravo
Originally Posted by nickjpass View Post
Smhhh
I expected you to say at least it wasn't your dad that crashed it
Old October 4th, 2014, 01:09 PM   #15
nickjpass
#squid
nickjpass's Avatar
MOTM - Jul '16
at least it wasn't his car lol
Old October 4th, 2014, 01:58 PM   #16
JohnnyBravo
Oh crap... That too
Get it fixed
Old October 4th, 2014, 02:11 PM   #17
nickjpass
#squid
nickjpass's Avatar
MOTM - Jul '16
The car is scratched... Idc about it lol
Old January 19th, 2015, 01:34 PM   #18
Bubba
Motorcycle(s): 300
Most sliders on the market don't do much.
Bubba is offline   Reply With Quote
Old January 19th, 2015, 02:02 PM   #19
Sirref
Private Joker
Sirref's Avatar
MOTM - Mar '14
I've seen some sliders do serious work before
[roadracingworld.com] - Damage To Stoner's Ankle "A Lot Worse" Than First Believed Ninjette Newsbot Motorcycling News 0 August 23rd, 2012 10:50 AM
